Or is there a script I can put on the sd card to execute av.exe on boot?
AVIC-MRZ99 Custom Firmware / Testmode
18 hours ago, dzo said:Looks like it's the same as mrz02 so use the .LNG file from that. Try overwriting all the .LNG files.
No words to express my gratitude! Worked like a charm, replaced not only JPJPN, but JPENG, JPMEN and JPMTB and its now in English with the beautiful graphics.
Hi dzo! Could you please help me? I need the software for AVIC MRZ 99.!!Thanks.
On 27/3/2019 at 2:54 PM, EnoKt said:How I solved my problem finally with AVIC CARROZZERIA MRZ09.
I remembered to have saved two backups for USER folder in my laptop. 1) Version before using DZOs auto Japanese-English setup which worked flawlessly in my AVIC MRZ09. 2) Version after successful conversion to English following DZOs programme.
1) I entered in TestMode using buttons and navigated up to USER DIR, then selected all files therein and hit delete. It took time but got it done.
2) Copied the English version of backup folder into the flash disc and transferred the contents in the USER folder of the AVIC MRZ09.. It took quite a bit of time to paste. Finally it got done.
3) Removed flash disc and switched off ACC. Waited for the unit internal fan to stop completely and switched back to ACC.
4) The unit got back alive without black screen and works fine.
I hope this solution may help someone with similar problem like mine.
Hi. I have the same problem but is number 7 in right corner and black screen. AVIC MRZ99.I didn't saved nothing before. Now I have to install a new software or which is the next step??Please help if you can!! Thanks
20 hours ago, Liolic99 said:Hi. I have the same problem but is number 7 in right corner and black screen. AVIC MRZ99.I didn't saved nothing before. Now I have to install a new software or which is the next step??Please help if you can!! Thanks
Hi Liolic99
I had a new issue with error 7 bottom right as shown in my previous image and post addressed to dzo on page 47 I have had no response so far and no solution yet. Probably if dzo is still around he can write a script which will enable automatic pasting to USER follder, which in my case (MRZ09) the DIR is completely empty. Not even the SYSTEM folder exists.. I am stuck.
On 1/9/2017 at 10:26 AM, fanourio said:Option 2 :
Is it at all possible to install any other navigation such as IGO on MRZ?
Dear fanourio,
I am interested for other navigation like IGO. If you manage something please let me know.
On 9/13/2017 at 4:13 AM, fanourio said:Dear all,
I can fix MRZ 03, MRZ 05, MRZ 07 and MRZ 09 as well as others to read ENGLISH instead of Japanese. Also I have a special antenna transformer that can allow the radio to reach all your FM stations for Europe. Further than that I also have the adapter for USB and JACK 3.5 mm etc. I also have maps for Europe which can be easily installed.
The language change is for free, so is the date /time settings.
However you will have to send me the unit and once I fix it I can return it to you.
Drop me a line in a Private Message here as I can not publish my email and I will come in touch with you either via Whatsapp or Viber so please add your number.
The antenna adaptor/converter costs about 20 euro, the adapter for USB and Jack 3.5 mm for your audio/phone is about 10 euro and the maps are between 12 to 20 euros depending on the country, full Europe is about 45. Shipping to Cyprus should not be more than 20 euros. I am NOT selling anything I do this as a hobby but the costs must be covered by you.
I hope this is not understood as an advert because I dont charge anything.
Best
Fanourio
Dear Fanourio,
I am Cypriot, please call me on 99544236.
On 4/18/2019 at 10:48 PM, svgenov said:No words to express my gratitude! Worked like a charm, replaced not only JPJPN, but JPENG, JPMEN and JPMTB and its now in English with the beautiful graphics.
please advice how you have replaced those files and with which files are replaced. I have the same problem. regards.
55 minutes ago, Kyriakos said:please advice how you have replaced those files and with which files are replaced. I have the same problem. regards.
which model you have?
10 hours ago, electro said:which model you have?
avid mrz02
I have change the language but some touch icons are not working, specifically the top right and the bottom left. (back, exit, display tilt...)
2 minutes ago, Kyriakos said:avid mrz02
Hi All,
I'm looking for a way to change the image from the blue background back to the stock grey one. Does anyone have the original .bmp file from MRZ09 and the steps to change it to it? Or maybe a precompiled version of the update with the stock grey background?
MRZ05 nothing has worked for me so far any help please
Has anyone been able to translate the Carrozzeria AVIC-RZ33 from japanese? I've been searching high and low but I haven't seen anything about this particular model.
On 30.12.2016 at 2:59 PM, dzo said:Here's a zip file that should automatically update mrz99, mrz77, mrz09 and mrz07 (and perhaps others).
https://github.com/dzo/mrz99/blob/master/updatemrz99.zip?raw=true
Hello. I downloaded zip and there is a question
COPY -c SD\Image.img USER\PRG1\APL\MENU\Image.img
#COPY -c SD\Image.img USER\PRG0\APL\MENU\Image.img
#COPY -c SD\PF090JPJPN.LNG USER\PRG1\APL\LANGDATA\PF090JPJPN.LNG
#COPY -c SD\PF090JPJPN.LNG USER\PRG0\APL\LANGDATA\PF090JPJPN.LNG
#COPY -c SD\PF110JPJPN.LNG USER\PRG1\APL\LANGDATA\PF110JPJPN.LNG
#COPY -c SD\PF110JPJPN.LNG USER\PRG0\APL\LANGDATA\PF110JPJPN.LNG
should i uncomment those lines above? Or first line is enough mrz07 to became enlish?
thanks to Dzo!!!!
Its in English now!
first of all i modified script to make backup (created backup folder on SD card and PRF0 and PRG1folders inside backup)
then i made backup:
COPY -c USER\PRG1\APL\MENU\Image.img SD\backup\PRG1\Image.img
COPY -c USER\PRG0\APL\MENU\Image.img SD\backup\PRG0\Image.img
COPY -c USER\PRG1\APL\LANGDATA\PF090JPJPN.LNG SD\backup\PRG1\PF090JPJPN.LNG
COPY -c USER\PRG0\APL\LANGDATA\PF090JPJPN.LNG SD\backup\PRG0\PF090JPJPN.LNG
COPY -c USER\PRG1\APL\LANGDATA\PF110JPJPN.LNG SD\backup\PRG1\PF110JPJPN.LNG
COPY -c USER\PRG0\APL\LANGDATA\PF110JPJPN.LNG SD\backup\PRG0\PF110JPJPN.LNG
then rebooted, changed ScriptExec.ini to:
rebooted
and its works fine
but NAVI is still in Japanese but i dont care it
Thanks again!!!
Скажите, почему в магнитоле AVIC-MRZ09 переводится на английском НЕ ВСЁ МЕНЮ? Остаётся текст на японском. Почему? Какой файл необходимо редактировать?
On 4/10/2019 at 2:47 PM, EnoKt said:Hi @dzo,
Your contribution is appreciated always. I jump boosted a battery to start my car The AVIC MRZ09 shows the characters in Japanese shown below, translated ''there is no program'' with number 7 at the bottom right of screen. The USER/DIŔ shows no content Any help to revive this unit? I have original USER content backup and the English one from your previous posts. . I tried copying and pasting the backups to the USER folder but nothing happens or shows up. The Unit copies and pastes to any other media like FLASH DISC OR SD but does not paste in USER folder.. Any help to revive it.?
Hi everyone.
I haven't yet got any hint for solving the above problem posted on page 47. Any assistance from this forum is welcome.
On 2017/5/10 at 8:40 AM, dzo said:
Here are instructions on how to change the mrz99 splash screen.
First get an 800x480 image to use. Save it in 16 bit rgb565 format, strip the header off so it is exactly 768000 bytes long.
add a 512 byte header that starts like this:
00000000 a5 5a 5a a5 00 b8 0b 00 bc ea cd 15 00 00 00 01 |.ZZ.............|
00000010 01 00 00 00 00 00 00 00 4e 41 30 39 30 4f 50 4e |........NA090OPN|
00000020 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff |................|
with the other bytes 0xff
call it NA090OPN.DAT
compile the makever.c program from my github and run it with NA090OPN.DAT to generate NA090OPN.VER.
On a usb stick or sd card create a directory called AVICMRZ90 with a directory OPN090 inside it.
copy NA090OPN.VER to AVICMRZ90 as PF090OPN.VER and OPN.VER (I can't remember which is correct so just put both in there)
copy NA090OPN.DAT to the OPN090 directory and rename it as PF090OPN.DAT
start testmode and select "forced firmware update" in japanese, I think it's the third entry but check first using google translate.
select "opening image", i think it's the last entry but again, check.
select usb or sd card and a new version number should appear, if not, check your directory structure and file names.
hit menu (or it could be another key) and it will write the splash screen.
I have done this and it works but as you can see it's not a simple process, it took me a long time to figure out the directory structure and
when it finally worked I had the DAT and VER files in lots of places with different names so the above may not be 100% correct but with some trial and error you should be able to get it to work. There is no way to go back to the standard image.
I'm happy with the splash screen I have now so I'm not going to change it or spend time making this process easier.
I'm definitely not going to take requests to convert splash screen images into dat and ver files!!
Nice to meet you.
I got Nissan genuine MP310-A and Daihatsu genuine NMDP-W59.
Both are equivalent to the MRZ 99, and the splashstart launch screen displays the Nissan and Daihatsu logos.
I want to rewrite this.
However, I first want to know how to back up the car company's original [NA090OPN. DAT].
Also, if you do not know how to create NA090OPN.DAT, can you send me a sample?
1 hour ago, yoppi2010 said:Nice to meet you.
I don't think there is an easy way to dump the existing splash screen because it's on a separate partition and not accessible to the file manager.
Attached is a data file with a pioneer logo, you can view it in gimp by importing it as raw 800x600 rgb565 with a 512 byte header.
The important thing to get correct is the directory structure for the update, I think the main directory name has to be the same as the product name in:
/USER/PRG0/PF090APL.HTM
Yours probably won't be AVICMRZ90.
22 hours ago, dzo said:I don't think there is an easy way to dump the existing splash screen because it's on a separate partition and not accessible to the file manager.
Thank you for your quick response.
There are two more questions.
The first question is Attached [PIONEER.DAT] How do you check the image preview on the PC?
Second question.
What software should I use to convert bmp to 16-bit RGB565 (NA090.OPN) on Windows?
I am sorry for the basic questions.
4 hours ago, yoppi2010 said:Thank you for your quick response.
Second question.
Just use gimp.
On 2019/7/9 at 10:16 AM, dzo said:Just use gimp.
Thank you for your prompt response.
Is it safe to convert the image (BMP) you want to change with fixbmpheader.c, change it to the NA090OPN.DAT name, and add a 512-byte header?
If I want to display PIONEER.DAT on Windows, will I use extractbmp.c to change to BMP?
I do not know how to use DZO's .c script published on github. I use Windows. I am glad if you can tell in detail.
Compilation and generation of NA090OPN.VER succeeded.
Thank you very much.
It can not be installed in Navi.
The navigation side is not aware.
Is the file structure of the SD card OK?
-SD
--OPNXXX
---NAXXXOPN.DAT
---NAXXXOPN.VER
My navigation was NA100OPN and NA092OPN.
Internal system file are almost the same as NA090.
When I made NAXXXOPN.DAT and NAXXXOPN.VER, I changed it to NA100 or NA092, including the inside part of NA090.
Please give me advice.
