dzo bro can you tell me plz how to backup /USER
AVIC-MRZ99 Custom Firmware / Testmode
Рв чем проблема при копировании? Вам надо только prg0 и prg1 копировать.выделÑете нажимаете copi потом в Ñд или уÑб входите и жмете pastedzo bro can you tell me plz how to backup /USER
i have mrz07 and i did what you said but didn't work for me can u plz give me the file for mrz07
Ð’Ñ‹ Ñначало выложите Ñюда Ñвои файлы, а DZO поÑмотрит на них и Ñкажет перевод возможен или нет
DZO hi. Tell me please what is the reason, after the translation, and the subsequent compilation of PF090JPJPN.LNG through the command ./recode translated.txt PF090JPJPN.LNG, the terminal produces a segmentation error (a memory dump is made)
There's no error checking so it'll do this if it can't open the input file.
i forgot to backup the file (PF090JPJPN.LNG) ( PF110JPENG.LNG) these to file i have change with the file DZO provide so can you help me with this
i shall be very thankfull to you sir if u can find the solution ![]()
does anyone have a backup of mrz07 i delete the two files in both folders PRG1 PRG0 and the files are (PF090JPJPN.LNG PF110JPENG.LNG ) if anyone have plz help me ![]()
Thank you very much DZO and IInur for your help i succesfully done it with your help now i have only one problem how can i start map for pakistan any procedure if u have plz tell me and again thank you very much for your great support may god help you
Hi DZO,
Can you please advise if there is any instruction how to change boot splash screen on mrz77?
Thank you very much DZO and IInur for your help i successfully changed Japanese to English language on AVIC-MRZ07 with your help. i appreciate you guided me on every step . Thanks again.
I've translated the Japanese language strings for the MRZ99 to English.
I figured out the format of the LNG file, dumped the Japanese, translated all the strings using google translate, then rebuilt the file.
Some of the English is not perfect but it makes the system much more usable.
I've tested it with APP firmware version 3.070200 (installed with platform version 3.000600), other versions may not work.
If the old language file is 93627 bytes long then this will almost certainly work.
To install this, unzip the attachment
mrz99english.zip and put the PF090JPJPN.LNG file on an sd card. (130905 bytes, md5sum is cb3f9cb76330704cc171e2b0acb9f6ad)
Get into testmode by holding the NAVI button (left button with Japanese writing on it) and pressing right..left..right..left..right..left and then release NAVI.
Go to the last entry on the first page (File Maintenance in Japanese) and press MENU (right button with Japanese writing on it)
This opens the file manager which is in English and fairly obvious.
Make a backup of /USER as described elsewhere on avic411.com
Look in /USER to see if there is a file named PRG.FLG
if there is, then the system uses /USER/PRG1, otherwise it uses /USER/PRG0
You can check the file versions by looking at /USER/PRGx/PF090APL.HTM (where x is 0 or 1 depending on PRG.FLG)
go to /USER/PRGx/APL/LANGDATA/
delete PF090JPJPN.LNG
go to /SD, copy the new PF090JPJPN.LNG and paste it into LANGDATA where the old one was.
Switch off the power and when it restarts, it should be in English....
This worked for me but obviously is not 100% safe, be very careful in the file manager.
Update: There's now an installer that also changes the background and most of the important images with japanese text.
Find it here:
Hey Dzo, i followed your installer and extracted it onto USB however when i plug in usb it says copying with red screen then it says done with green screen. However it doesn't seem to work.
I tried to turn off the car when doing installation and after completing restart.
This was for the AVIC MRZ90.
First i was trying to convert to english and once that's done hopefully i can load NZ maps on it
any help would be appreciated it.
Mrz90 is a bit older than mrz99 so it probably has different strings. Can you get into testmode and copy all of /USER to an sd card then post /USER/PRG1/APL/MENU/Image.img and everything in /USER/PRG1/APL/LANGDATA/ here. I'll see what I can do.
I'm in NZ too, I don't think putting NZ maps on these devices will be easy or worthwhile because the english versions never had NZ maps and Google maps is far bettter anyway.
Hi DZO,
Sorry to bother you again, but could you please advise if there is any instruction how to change boot splash screen on mrz77?
Hi DZO,
Here are instructions on how to change the mrz99 splash screen.
First get an 800x480 image to use. Save it in 16 bit rgb565 format, strip the header off so it is exactly 768000 bytes long.
add a 512 byte header that starts like this:
00000000 a5 5a 5a a5 00 b8 0b 00 bc ea cd 15 00 00 00 01 |.ZZ.............|
00000010 01 00 00 00 00 00 00 00 4e 41 30 39 30 4f 50 4e |........NA090OPN|
00000020 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff |................|
with the other bytes 0xff
call it NA090OPN.DAT
compile the makever.c program from my github and run it with NA090OPN.DAT to generate NA090OPN.VER.
On a usb stick or sd card create a directory called AVICMRZ90 with a directory OPN090 inside it.
copy NA090OPN.VER to AVICMRZ90 as PF090OPN.VER and OPN.VER (I can't remember which is correct so just put both in there)
copy NA090OPN.DAT to the OPN090 directory and rename it as PF090OPN.DAT
start testmode and select "forced firmware update" in japanese, I think it's the third entry but check first using google translate.
select "opening image", i think it's the last entry but again, check.
select usb or sd card and a new version number should appear, if not, check your directory structure and file names.
hit menu (or it could be another key) and it will write the splash screen.
I have done this and it works but as you can see it's not a simple process, it took me a long time to figure out the directory structure and
when it finally worked I had the DAT and VER files in lots of places with different names so the above may not be 100% correct but with some trial and error you should be able to get it to work. There is no way to go back to the standard image.
I'm happy with the splash screen I have now so I'm not going to change it or spend time making this process easier.
I'm definitely not going to take requests to convert splash screen images into dat and ver files!!
thank you, will try
hey would this work for the mrz-099? If not do you know how i can get the test mode files for a 099?
No, mrz099 looks like a different platform and the generic testmode key for 99 doesn't work on it.
Привет!
dzo огромное ÑпаÑибо за проделанную работу! Пробовал перевеÑти MRZ-09 Ñ Ð¿Ð¾Ð¼Ð¾Ñ‰ÑŒÑŽ updatemrz99 в автоматичеÑком режиме - ничего не получилоÑÑŒ, Ñ…Ð¾Ñ‚Ñ Ð²Ñе запуÑкалоÑÑŒ. в конце было Ñообщение done, но поÑле перезагрузки Ñзык оÑталÑÑ ÑпонÑким. Потом зашел в testmode (ÑƒÐ´ÐµÑ€Ð¶Ð¸Ð²Ð°Ñ Navi+right, left, right, left, right, left), вручную поменÑл файлы PF090JPJPN.LNG и PF110JPJPN.LNG в папке USER/PRG0/APL/LANGDATA на файлы Ñ Ð¿Ð°Ð¿ÐºÐ¸ updatemrz99. Перезагрузил уÑтройÑтво. Ð’Ñе заработало)))
Ð”Ñ€ÑƒÐ·ÑŒÑ Ð¸Ð· РоÑÑии, где взÑть Ñамые поÑледние файлы Ð´Ð»Ñ Ð¿ÐµÑ€ÐµÐ²Ð¾Ð´Ð° на руÑÑкий Ñзык?
Is this method and files will work on MRZ77 ? I'm willing to give it a shot...Thnx
Yes, it will very likely work on mrz77 but make a backup first just in case.
Привет. Я MRZ0047 на руÑÑкий переводил, аж два раза, впринципе ни чего Ñложного, но муторно, Ñлишком много текÑта,как Ñто делать DZO опиÑывал.Привет!
Вот еÑли бы DZO выполнил работу по уÑтановке карт цены бы не было, ведь в ÑоÑедних ветках люди Ñмогли уÑтановить иные программы навигации, думаю что и на наших получилоÑÑŒ бы
УдалоÑÑŒ победить проблему Ñ Ð¸Ð½Ñ‚ÐµÑ€Ð²Ð°Ð»Ð°Ð¼Ð¸?
Ðет не удалоÑÑŒ , по прежнему большой интервалУдалоÑÑŒ победить проблему Ñ Ð¸Ð½Ñ‚ÐµÑ€Ð²Ð°Ð»Ð°Ð¼Ð¸?
