Tyrant11429 said:
hey guys I was wondering I just got ducati's bypass circuit and going to have it installed with my z1 tomorrow(customizing my volvo interior trim myself didnt work out right lol) Will the bypass work with the engine off with the car in the acc position ?
Yes it will. It doesn't know the difference if the car is running or if the key is just in the acc possition.
Tyrant11429 said:
nav, dvd etc and with the hand brake down or would I have to put it up with the engine off, just curious cause I thought only with the engine starting up ducati's devise works.
Nope, if connected properly, like in my instructions... any time the Z1 turns on, so will my circuit. Just make sure the hand brake is "down" or off or not activated... better yet, if you are going to have this installed, just don't have them connect the parking brake line. You won't need it.
Tyrant11429 said:
Also I have a remote starter and the ign stays on for a sec or 2 before the engine cranking it wouldn't short anything out would it in the devise or the z1 ? Am really siked to have this installed in my car.
It won't matter. Actually I guess that depends on the skill of the installer of the auto start. If some hack did something dumb when installing the auto start, it could short something out. But if it's installed correctly and working correctly, then it's fine. When your auto start turns on for 2 seconds, the Z1 will start to boot up for those 2 seconds, but when it cranks over, generally the switched 12V will turn off for a split second (I guess that depends on the auto start device) which would cause the Z1 to reboot and so would my circuit... but if the 12v doesn't go away while it cranks, then the Z1 won't restart, and neither would my circuit.
Basically, if my circuit is installed like I said, any time the Z1 is running, so will my circuit. Should work any time.
