Tyrant11429 said:
I have a 2000 volvo v70xc cross country double din I measured the opening and its 4 and 3/4 inch tall, would the avic z1 fit in my car, and would I have to cut my factory wires for the install ?
Second I read the smart idea on how to bypass the dvd by flashing the headlight, but I have aftermarket hid headlights and they say frequant flashing of the lights will damage the the ballast for the light.
If I'm going to get the avic z1 is there any other way around this ? I read a post on this subject of flashing the parking light, but does that pulse work to bypass it. I don't want to spend all that money and than than be disapointed if something doresn't work the way I wanted. Would appreciate any help you guys could offer
If it's double din it should fit, you can check crutchfield.com for verification, but FYI they said it wouldn't fit my car when it did, so don't take it as 100% accurate. The main thing is the depth of the deck, this deck is 7" deep. A few people have had to shave the sides of the opening on their dash slightly to make it fit but nothing major that I've heard.
Most people can find wiring harnesses for their cars so they don't have to cut the factory wires, you just plug into the existing harness. Check places like installer.com or crutchfield. It should be something like this:
http://www.tune-town.com/wire/1998-02_V ... 709220.htm
As for light flashing, generally the dimmer wire to the head unit is controlled by the parking lights, not the headlights, so you should be fine. But if it's a variable voltage dimmer wire or non 12v dimmer wire you may need some special components.
