Bypass instructions for the Z1
By Jamesdat · Mar 31, 2006in Hacks/Mods💬 427 posts👁️ 155,139 views
Page 2 of 18
Posted Apr 23, 2006 · 02:43 UTC#26
I drove about 40 miles roundtrip testing the bypass,everything worked like a charm. make sure you do not pull the ebrake up at anytime during your travel otherwise it will lock up.
Posted Apr 23, 2006 · 02:50 UTC#27
Thats Awesome!!!
Tomorrow I'll start working on designing a relay that will do it automatically.
About how long is the time window in which you can flash the lights?
Most relays need a half a second to switch over.
Posted Apr 23, 2006 · 04:32 UTC#28
just use a pac tr7 and program it for 3 positive pulses upon turn on, easy as that.
Posted Apr 23, 2006 · 04:57 UTC#29
Sweet. I'm gonna go buy one before Pioneer fixes this.
Posted Apr 23, 2006 · 05:01 UTC#30
Ah! Your right! That's a great idea, just saved me a lot of time! Who would think it would be so simple? hehe.
Posted Apr 23, 2006 · 13:29 UTC#31
looks like i will install my z1 after i go golfing today, hopefully i can have it done by 7pm. if this works i will post video of it in action.
the only problem i have is with flashing the headlights is i got thoes stupid daytime driving light and i dont think they are able to turn off completely, if anyone knows how to shut them off let me know, its a 2002 toyota sequoia.
here is a link to the switch http://www.soundoffaudio.com/item.cfm/id/2084
im sure it can be found cheaper
looks like ebay is the place to buy http://search.ebay.com/search/search.dll?cgiurl=http%3A%2F%2Fcgi.ebay.com%2Fws%2F&fkr=1&from=R8&satitle=pac+tr7&category0=
Posted Apr 23, 2006 · 13:47 UTC#32
will the pac tr7 work with z1? and also the time window for flashing your lights is about 2 seconds
Posted Apr 23, 2006 · 15:17 UTC#33
It should work. Just program the TR7 to send 3 pulses over 2 seconds.
Posted Apr 23, 2006 · 20:13 UTC#34
you can even set it to turn on with the remote out wire on the deck, so everythime it turns on the bypass will activate.
Posted Apr 24, 2006 · 01:08 UTC#35
So you just flicker the lights three times before the music comes on. I have a honda civic 06 will this work........any i don't know how to set up the Tr7 or how to install ?....can anyone help me pls........ :roll:
Posted Apr 24, 2006 · 01:27 UTC#36
that was my comment above....pls someone help me ......
Posted Apr 24, 2006 · 01:31 UTC#37
I do not have a Z1, and can't test this, but you either:
1. Flash the headlights 3 times while the Z1 turns on.
2. Get a TR7 and program it to send 3 pulses over 2 seconds upon power up.
Posted Apr 24, 2006 · 11:12 UTC#38
So even if i have running daytime lights will this work? What wires do i hook up the TR7 to?.........thanks for the help :lol:
Posted Apr 24, 2006 · 19:34 UTC#39
Just ordered an avic-z1...wanted to get one before they correct this problem. ;-) Can someone tell me what all this unit comes with, ie remote, mic, etc?
Posted Apr 24, 2006 · 19:43 UTC#40
If you connect the speed pulse wire will it affect this bypass? Is the speed pulse wire necessary?
Posted Apr 24, 2006 · 20:02 UTC#41
it says failure to make this connection will increase errors in the location display. now is that true ? i dont know. but personally im thinking of just selling my z1 and getting a unit that will do video and nav at the same time, ie the eclipse.
im kind of on the fence to hook up the z1 without being 100% that the headlight flashing will bypass the safety features. and right now its only hearsay on wether this trick actualy works
Posted Apr 24, 2006 · 21:13 UTC#42
The speed pulse wire allows navigation (dead reckoning) to take place when GPS Signal drops out. (ex: mountains, tunnels, etc.)
I would install it if the bypass isn't bothered by it.
Posted Apr 24, 2006 · 21:44 UTC#43
I installed the Z1 in my 06 Dodge Ram. I do not have the speed pulse wire connected because I guess the new chrysler vehicles don't come with actual wires, i guess everything is computerized, but the location of the car on the map is pretty accurate without it, so i say its works pretty good with just the GPS antenna. I am gonna try the light flickering thing when i get off work, but I actually bypassed it another way, requires a little work, but not tough. Considering your not using a backup camera or having extra tv's in ur car, I ran a really short RCA cable from the rear monitor outputs ( since those can be watched while the car is in motion or not ) into the backup camera input. I then installed a switch on the reverse wire and turned on the rear display to DVD. Now all I do is flick on the reverse toggle switch and bam, it tricks the unit into thinking its recieving a rear view camera image when really its getting the image from the rear tv outputs. The neat thing about this is that when ur using navigation and u hit the rear view map, you can actually watch the video and see the map on the side at the same time :D ... so ya.. i have the parking brake on a switch too so i can use the nav controls while im in motion. It works like a charm... i just have to deal with two switches...
Posted Apr 24, 2006 · 22:11 UTC#44
So I just tried the illumination wire bypass without much luck. Will it work with FM as the default source or does it HAVE To be xm or sirius to work?
Posted Apr 24, 2006 · 22:21 UTC#45
that sounds great, only i need the rear view camera. let us know how the light flicker works out for you. also do you have any pics of video and nav on the same screen ?
Posted Apr 24, 2006 · 22:24 UTC#46
I did not have the illumination wire hooked up so I installed it last night. I too can't seem to get it to work. I did have the tuner set to XM, and flashed the lights 3 times while it was booting. The E brake was off, and it is hooked up correctly according to the installation manual. Do you wait till you see "Pioneer navigation loading" on the screen or can you do it anytime as long as the music hasn't started? Actually I tried it 4 times today and still can't seem to get it right. Any thoughts???
Thanks,
Kevin
Posted Apr 24, 2006 · 22:30 UTC#47
I know that the ebrake ground does not work for most people (even if you don't hookup the speed wire). The unit takes a bit longer before it will disable (about 1-2 minutes) but it will generally still disable and give you a faulty ebrake warning message.
Posted Apr 24, 2006 · 22:56 UTC#48
I have the z1 in my ford truck. I can say for a fact that the light flickering works every time for me. The z1 works like your parked when Im going 70mph. Everythings work perfectly. I just hope that it doesnt hurt the unit at all.
Posted Apr 24, 2006 · 22:59 UTC#49
Thanks,
Kevin
Is your brake wire grounded? It needs to be.
Posted Apr 24, 2006 · 23:04 UTC#50
Nope.....it's hooked up as it says to connect. I will ground it and try it. Thanks!!!
Page 2 of 18
