Bypass instructions for the Z1
By Jamesdat · Mar 31, 2006in Hacks/Mods💬 427 posts👁️ 155,139 views
Page 4 of 18
Posted Apr 26, 2006 · 03:51 UTC#76
This will work for watching video but doesn't help with the disabled nav functions. The flashing lights trick does, plus some of us use the reverse cam.
tman40 said:
if you read my reply earlier you dont have to flash your lights just run your video out rca jack to your camera in jack in back of your radio this is step by step on how to. first after doing the above push the AV button to AV SETTINGS to SYSTEM SETTINGS, CAMERA INPUT (ON) AV INPUT (VIDEO)
AUX INPUT (ON) in the AV SOURCE MENU make sure REAR SCREEN DVD IS ON now after all that has been done PUSH THE MAP BUTTON hit REAR VIEW
watch movies and DRIVE SAFELY repeat you donot have to flash your lights.
1 more thing i did ground parkbrake
:wink:
Posted Apr 26, 2006 · 04:07 UTC#77
Here is what we have figured out. Works great. Except having to do it every time you start up your vehicle.
Start up your vehicle
When the prompt on your avic z-1 comes up in the top left hand corner when it is first booting up you turn your parking lights on and off one time and presto your off watching dvd with no problems, just don't use or parking brake or will have to do over.
Posted Apr 26, 2006 · 04:10 UTC#78
So then in theory you can have the TR7 send only one pulse to the dimmer wire and never hook up the brake wire. Do you have your speed sense wire attached?
Posted Apr 26, 2006 · 06:00 UTC#79
I have my entire Z1 hooked up. That includes speed pulse, xm, ipod, no damn bluetooth yet though. And It works fine. I have been doing 3 pulses, with the brake wire grounded. Sometimes It doesn't work, but that's probably just because sometimes I am retarded and miss the timing. :roll:
Posted Apr 26, 2006 · 06:28 UTC#80
Kudos to whoever found the bypass trick...and thanks for sharing! Some pricks on the other forums found the bypass weeks ago, but did not share. Does not sharing makes them feel superior? :roll:
Anyways, mine WORKS great now, everything is unlocked. Never thought the bypass would be so simple. Wonder why Pioneer would built-in such a hack, or is it an unintentional flaw that they will soon "patch"?
Regardless, the AVIC-Z1 will be selling like hotcakes now that the bypass is leaked.
And JasonH thanks for creating this great forum. Best site on the web for AVIC info period.
Posted Apr 26, 2006 · 16:02 UTC#81
So some of you that did this trick and had it work have your parking break wire grounded?
And what about the rest of you guys did you have the parking break off, or on and then do the 3 pulse then turn the parking break off?
Posted Apr 26, 2006 · 16:21 UTC#82
whatever happened to that Bpz1s.kwi info, was there any truth to that? I e-mailed Pioneer, but of course they told me there is no bypass for this unit.
Posted Apr 26, 2006 · 17:12 UTC#83
It doesn't matter if your Parking Brake Wire is grounded or not, it will work either way.
Just pulse your light ONCE at the startup screen. No need to 3X.
You don't even need to turn the light fully on, ONE parking light pulse will work.
Posted Apr 26, 2006 · 17:30 UTC#84
Here's what I've done.
1) Parking brake cannot be connected. I installed a switch to ground anyway, because you might need to in the future.
2) You must flash, or power-up illumination wire once while that message is on in the upper left hand corner. Not when the Pioneer screen comes on.
3) I connected a TR-7 to be triggered by the amp turn-on wire, wait 3 seconds, and then pulse the illumination wire once. I installed a diode on the ill. wire, so I can still use it without it back feeding to the parking lights.
4) You get that TR-7 programming from the website. There are 5 bonus features you get there. Not in the instructions, and not from tech. The instructions it comes with only go to #16, you need #17.
How is that for sharing!!
Posted Apr 26, 2006 · 17:45 UTC#85
Good info. So it worked for both of you ^ with just doing 1 pulse?
Posted Apr 26, 2006 · 17:47 UTC#86
yes, CONFIRMED, a single pulse works.
Posted Apr 26, 2006 · 17:50 UTC#87
When you say "parking brake cannot be connected", do you mean to just cap off the wire from the AVIC Z1 and not hook it to anything????
Posted Apr 26, 2006 · 17:58 UTC#88
some info from a Civic forum
okay, extensive experimentation...
green wire grounded (no connection to e-brake)
:start car and at "starting pioneer navigation screen" flicker your lights
:you have to hit "okay" to confirm connection is legal
:you also have to hit "okay" to confirm the e-brake isn't properly connected
:the dvd will then play regardless of the position of the e-brake
:you can switch in between navi, dvd, am/fm, and library
green wire properly connected to e-brake
:e-brake must be off
:the dvd will not play if e-brake is engaged and then released (must restart car and redo the whole process in order to get dvd w/o e-brake on)
note: when i say "flicker", it means the first initial screen will show a message at the very top stating the pioneer navigation is initializing and at that very moment you turn your lights on and off. the good thing with this is they can even be your parking lights so it's not as obvious that you're screwing around. if you do it at that very moment (since this screen is on for only a second or so), you only need to flicker your lights once. if you miss that screen i would just recommend restarting from the beginning, but i also had luck flickering my lights about 5 more times during the loadup screen following the initialization screen when i intentionally missed the first queue.
to me, the best way to do it is the grounded way, because then it doesn't matter how you start the car or if you have to use your e-brake for some reason, but there is an extra "okay" screen you have to touch because it knows that it's not connected properly
this is pretty much directed toward gaspar, but i'm sure it's informative to anyone else interested in the Z1.
Posted Apr 26, 2006 · 18:11 UTC#89
So what happens when you start your car at night and need the lights on. You would have to pulse twice instead of once. Does that make a difference?
Posted Apr 26, 2006 · 18:22 UTC#90
Makes no difference. The Z1 just need to read at least ONE pulse. You can then fully turn on the headlights afterward the Z1 is fully booted.
Posted Apr 26, 2006 · 18:53 UTC#91
what feature did you use and how was it programmed?
Posted Apr 26, 2006 · 19:05 UTC#92
So can you be moving and the DVD picture does not go away? Mine goes away, and leaves the audio, at precisely 20 km/h
Posted Apr 26, 2006 · 19:08 UTC#93
Whats the website? I can't find it.
Posted Apr 26, 2006 · 19:13 UTC#94
Did you pulse your headlight at least ONCE at the Z1 startup screen? If you don't do it fast enough, you may have to redo it.
1. Insert key into ingition.
2. Start the car.
3. Wait to see "Start up..." on AVIC-Z1
4. Pulse your light Once (turn headlight on and then off)
That should do it. If not, then maybe you don't have your illumination wire connect properly. :?: Read the entire thread, lots of good info posted.
Posted Apr 26, 2006 · 19:18 UTC#95
I have a question that has not been asked yet.. Has anyone who is not a guest or a sudden member got this to worK?????? I am starting to think maybe this is a big joke. I could be wrong but it seems like everyone who got this to work was not around a couple of weeks ago when everyone was looking for a bypass... just keep this in mind while racking you brain why it does not work for you.. Or who knows maybe pioneer let this little Joke out.. :P
Posted Apr 26, 2006 · 19:25 UTC#96
Miker,
I am finding new forums everyday. I am a long time member of f150 online, truckmoxie, and the12volt.com. I have been "looking" for this info since I got the unit over two weeks ago.
I finally found it on the 12volt.com and a few hours later the post "vanished". Screw that forum and their legal obligations.
Since then I have found different variations leading up to the flash parking lights once during "starting Pioneer navigation" screen.
This is confirmed and working.
Posted Apr 26, 2006 · 19:27 UTC#97
www.pac-audio.com
When you find the adobe TR-7 instructiions, it will tell you about the bonus features.
Posted Apr 26, 2006 · 19:28 UTC#98
how this is said, the second one seems better to do, since you are leaving the e brake off it is not grounding the wire, so why not leave the wire off all together and then you wont have the "ebrake is not properly connected msg" and you dont have to press "ok" and you will never have to worry about the e brake being set to have to start over.
Posted Apr 26, 2006 · 19:28 UTC#99
Funny, I thought of the same thing. I've been looking for the hack since I bought my Z1 back on March 24th. A few members from other forums I lurked at confirmed that they found a hack weeks ago, but none were willing to share or if they did share, moderators from those forums quickly deleted the info. On a side note, did anyone notice many threads from other forums are being deleted about the hack. This is the only forum so far that still shows instruction how to do it.
My guess is that Pioneer built-in the hack to minimize "complaints" that could potentially lead to lawsuits for disabling features. They waited awhile after the initial release to see people respond to the crippled features. Apparently, someone from Pioneer finally leaked the info.
It's not JOKE, it does work. Many people have confirmed this. I'm hoping no permanent damage will result from this hack.
Posted Apr 26, 2006 · 19:32 UTC#100
Granted I am new, but I do belong to other forums. I found this forum when I was looking for info on the Z1 and when it would be out. I did get this to work as well. Granted I haven't played with it as much as the rest of you have, but I can confirm it works.
Page 4 of 18
