If someone has a tr7, i would like to program it, i have one but its hooked up inside of my car right now, the programming is very intence to do, i have mine used for a starter kill, that requires a series of dash buttons in my car to be pressed within a certain amount of time. The programming for the z1 is not a standard tr7 option and will take some time to get it to work, but im 90% sure i can get this thing to do what i want.
I need to be certain the things that need to go on for the bypass:
is this correct?
1) parking brake has to be grounded on startup.
2) flash the lights 3 times about a second apart.
3) disconnect the parking brake wire.
correct me if im wrong. If this is the case the programming should be fairly eash to do, or i might just create a circuit that i will share.
Please someone let me know if you have a TR7 lying around, i will try and program it and send it back to you after its programmed and tested for your own use.
