How To: Find your Vehicle's VSS Wire.
By JasonH · Oct 24, 2005in Vehicle Specific Wiring💬 346 posts👁️ 199,818 views
Page 12 of 14
Posted Aug 16, 2008 · 21:41 UTC#276
I can get u an adapter plug that plugs into ur obd2 port and igves u a vss output. Any car up to and including most 2010 models. $129
Posted Sep 09, 2008 · 05:13 UTC#277
I have a 1993 Honda Accord EX and would like to connect the VSS wire. Can you tell me where it is located and the color?
thank you
Posted Sep 11, 2008 · 19:30 UTC#278
Anyone know where the VSS wire on the 2007 Elements are?
Posted Oct 03, 2008 · 00:00 UTC#279
I have a 2004 Cadillac CTS and am getting ready to instal the Avic-F90BT. I can't find out where my VSS wire is to save my life... Any help?
Posted Oct 03, 2008 · 00:10 UTC#280
Try This:
Cadillac CTS 2004-2004
Function Color Location
Tach Signal WHITE ECM **
** ECM (Engine Control Module) is under the cover passenger side.
Posted Oct 08, 2008 · 16:42 UTC#281
Where is the VSS wire on the 2009 hyundai sonata
Posted Nov 22, 2008 · 05:13 UTC#282
JasonH said:
Simply enter your Vehicle Year/Make/Model here, and it will tell you where the VSS Wire is.
http://www.rostra.com/techsupport-main.asp
FYI 2004 Corvette not in the list
Posted Nov 25, 2008 · 23:10 UTC#283
I have a 2007 Ford Escape and I am trying to locate the VSS. It has the Audiophile 6-disk changer with speed sensor. Is there any chance the VSS is in the OEM radio harness? Maybe CAN BUS? If not what is the easiest location of the VSS?
Posted Dec 01, 2008 · 01:13 UTC#284
2000 Saab 9-5. Speed sensor wire. Color, location, DLC?? TIA
Posted Dec 11, 2008 · 01:01 UTC#285
I have a Ford Escape Hybrid 2009 with Microsoft Sync NAV. Has anyone found the VSS wire or the needed wiring to get the POI & Video working while in drive?
Posted Dec 11, 2008 · 01:54 UTC#286
VSS Wire Red or Blue Engine Compartment ABS Module
Posted Dec 26, 2008 · 23:50 UTC#287
F900 going into 08 Charger and can't find VSS or e-brake.
The site mentioned doesn't list it either.. Thanks in advance!
Posted Jan 05, 2009 · 00:07 UTC#288
I've asked this question in Club Titan and Titan Talk and no one can give me a solid place to tap into the VSS. I will not tap into the wire at the ECM in the engine compartment, it has to be in the cab. All of the white/red wires I tested did not show a voltage spike while moving. Unless I tested them wrong. And that link at the beginning of this forum turned up with nothing for my truck. Can somebody please help :?:
Posted Jan 17, 2009 · 17:36 UTC#289
I have been looking EVERYWHERE. Anyone know where the VSS (and ILLUM) is on a 2007 Audi A3 (bose, non-nav).
Thanks in advance!
Posted Jan 24, 2009 · 17:54 UTC#290
Anyone? :(
Posted Jan 26, 2009 · 02:55 UTC#291
i'm been looking too, but for a 2006 audi a3. no luck. i read somewhere that they don't have a vss wire any more on the 07. not 100% sure about that tho.
Posted Jan 29, 2009 · 02:51 UTC#292
I'm 99% sure they have one. Installed the D3 this last weekend, but didn't connect the illum or VSS :(
I hope someone can find it, as the GPS seems a little jumpy w/o it.
Posted Feb 02, 2009 · 05:25 UTC#293
Anyone know the VSS location on a 2004 Nissan Maxima without Bose? I looked around here, on the website listing in the OP, and on Maxima.org, but couldn't come up with any clear answer.
Posted Feb 08, 2009 · 15:32 UTC#294
Any body knows were is VSS for smart car passion? need help :? Thanks
Posted Feb 09, 2009 · 01:14 UTC#295
Smart Car:
Speed Sense PURPLE (AC) ECU MODULE TO THE RIGHT OF GLOVE BOX PIN 14 OF A 26 PIN PLUG
Nissan Maxima:
Speed Sense BROWN (AC) IN INSTRUMENT PANEL HARNESS
Dodge Charger:
Use Peripheral CHYAH0 module. VSS is can-bus
Nissan Titan:
Speed Sense WHITE/RED (AC) IN HARNESS TO GAUGES
Audi A3:
Speed Sense BROWN (AC) AT ABS MODULE ON LOWER SIDE OF RIGHT FRONT STRUT TOWER (THIS WIRE IS TWISTED WITH A BLACK WIRE IN THE HARNESS)
Posted Feb 09, 2009 · 01:25 UTC#296
2000 Saab 9-5 Wagon?
Posted Feb 11, 2009 · 11:03 UTC#297
Hi all!
I'm a new member as of today. Currently i'm doing an install of a F900BT into my 1995 JDM 300zx.
Can anyone tell me where to pick up the vss wire? My info so far is that it should be a yellow/green wire at the ECM but i've also been told that I should pick it up at the rear of the instrument cluster, very confusing, can anyone enlighten me?
Many thanks in advance,
Ade.
Posted Mar 14, 2009 · 14:53 UTC#298
I'm installing today and could use some help. Searched but could not find my car on website recommended at beginning of this thread. Any help would be appreciated. Also need assistance with locating positive side of parking brake wire.
Posted Mar 16, 2009 · 17:18 UTC#299
Hey guys http://www.the12volt.com and rosta.com both tell me different colors for my vss wire its on a 1999 ford escort lx, near the pcm there is a wire that is black and has VSS F2 writen on it. Does anyone know what is the right color? confused as hell at this point :?: I just want my navi to work.
Posted Mar 19, 2009 · 20:57 UTC#300
Hello,
I am looking for an Adapter for my AVIC F-700BT to connect it with my Renault Megane (ISO). I found some on German Ebay, they all fit in ISO (in my Megane as well) but I dont know which one of them fits in AVIC F700BT??? There are 18 types: with different pol/pins, white, black!!!
Can somebody help me finding the right one?
Here is the link for Ebay Adapters.
Thanks.
Page 12 of 14
