How To: Find your Vehicle's VSS Wire.
By JasonH · Oct 24, 2005in Vehicle Specific Wiring💬 346 posts👁️ 199,818 views
Page 10 of 14
Posted Feb 13, 2008 · 01:30 UTC#226
Any clue where the VSS is for an 2008 jeep commander please help me i going crazyyyyyyyyyyyyyyy :evil:
Posted Feb 20, 2008 · 02:12 UTC#227
where would i hook my vss wire in a 1999 expedition? i'm new to all this stuff and would like a little help. where would i hook the reverse wire as well? thanks
Posted Feb 22, 2008 · 14:49 UTC#228
what set of wires in the dash can i hook it to?
Posted Feb 25, 2008 · 16:42 UTC#229
anyone know? thanks
Posted Feb 26, 2008 · 06:11 UTC#230
just trying to locate the vss wire for a 2002 nissan altima. is the 2002 the same as the 2005-2006?? does it matter if your car is an automatic or stickshift? my car is a stickshift 2.5s... please help
Posted Feb 26, 2008 · 12:00 UTC#231
Speed Sense blue/yellow pin 9 @ instrument cluster
If vehicle has the midline audio system or BOSE, the vehicle speed sense is also found at the radio, it is pink.
Posted Feb 27, 2008 · 05:49 UTC#232
can anyone tell me where I can find the VSS wire on a 2002 GMC yukon Denali
Posted Feb 27, 2008 · 13:37 UTC#233
Speed Sense dk.green/white ECM
The ECM (Engine Control Module) is located near the battery, down low, between the fender and the fan under the black plastic cover. On the 4.3L, the VSS wire is at pin 3 in the connector labeled black. On the 4.8L, 5.3L, and 6.0L, the VSS wire is located in pin 50 of the red connector.
Posted Feb 27, 2008 · 15:35 UTC#234
Hey guys,
I've search for a long while trying to get the info on the location of the Vss wire and rev wire for my 2008 4runner SR5. Tried the rostra site and no luck there either. Putting in the D3 today and hopefully you guys can help. Also, do I really need to worry about these wires? I know it will make the navi more exact but is it worth the trouble? Thanks!!!
Posted Feb 28, 2008 · 01:17 UTC#235
do i need to hook the vss wire up? what does it do?
Posted Feb 28, 2008 · 12:56 UTC#236
I found it. I searched and found a how to on a 04 4runner and it was in the same place in the 08. The vss wire will make the gps more accurate basically.
Posted Feb 28, 2008 · 17:15 UTC#237
thanks. now i need to find out where to hook it on a 99 eb expedition
Posted Feb 28, 2008 · 19:13 UTC#238
OK, I put the D3 in my 4runner and my wife changed her mind on keeping her 08 Sequioa stock. Of course with hers she wants the new back up cam, bluetooth, and the D3 hooked up correctly. So I pose the question again, this time for a 08 Toyota Sequioa. Where can I find the Reverse wire and VSS wire for the 08 Sequioa? Thanks all!
Posted Feb 29, 2008 · 02:39 UTC#239
where can i find the vss wire in a 99 eb expedition?
Posted Mar 03, 2008 · 08:17 UTC#240
Hello, can anyone tell me where the VSS, and reverse wires are located in a 2005 chevy suburban?
Posted Mar 08, 2008 · 01:15 UTC#241
can some one help with a 2003 monte carlo SS
i dont have the on star but i did have the speed sensor on the radio and it would go up and down with the speed. So i know it is there some place just havent been abel to find it yet.
Posted Mar 08, 2008 · 01:17 UTC#242
Speed Sense green ac gray 16 pin plug @ BCM
The BCM (Body Control Module) is located above the brake pedal. It is a plastic box with three plugs that face the firewall.
Posted Mar 08, 2008 · 01:50 UTC#243
thanks Mis Fit.
I will look there. Someone said it was also int he radio harness and i was hoping to catch it there so i didnt have to splice a wire. I could just do it in the plug and see if i can do it around the adaptor plugs for the new stereo
Posted Mar 08, 2008 · 04:18 UTC#244
Did I stump the whole crowd on the vss and reverse wire on a 2008 Toyota Sequioa? Been better than a week and no help. Anybody????
Posted Mar 09, 2008 · 16:13 UTC#245
where can I find the VSS & reverse signal wires for an '02 nissan pathfinder SE and what color are they? I've already installed my avic-d3, and only have these 2 wires left to connect.
Posted Mar 09, 2008 · 19:10 UTC#246
Speed Sense white/blue cruise module in DKP
Reverse Light yellow + kick panel, harness to rear
Posted Mar 10, 2008 · 19:43 UTC#247
Mickey, MisFit is right you have to get your VSS from the BCM. It is the dark green wire. There is no VSS at your radio, it used a class 2 signal for the speed sensitive radio.
Posted Mar 16, 2008 · 02:32 UTC#248
Hi, how about for ML320 '02. I just got mine installed yesterday without VSS connected. I would highly appreciate your input/suggestions on this.
Thanks, DR
Posted Mar 16, 2008 · 23:10 UTC#249
Thanks, I finally broke down and did it yesterday and took it off the BCM,
Was one of those things wished i could have found something easier to tap them this was. (I'm old and not as flexible LOL )
Posted Mar 20, 2008 · 15:53 UTC#250
I have a Dodge Avenger 2008 and installed the AVIC-D3 but still need to hook up the speed pulse wire.
Anyone know where the wire is located? I have heard it is somewhere under the hood. but that was about it.
I have been looking for some time now.
Any help would be great.
Thank you.
Page 10 of 14
