Has anyone installed a Z2 in a new Thunderbird? My certified Pioneer install shop went to the speed sensor wires on the wheels but neither wire did the job. We then used the auto volume speed wire that went to the radio. I got a irratic pulsing of numbers from zero to 17 but mostly zero. Someone suggested tapping into the brown wire in abs line at the rear wheel before going into ABS module. Does that sound logical? Have not tried it.
How To: Find your Vehicle's VSS Wire.
anyone know where to find the vss wire in a 2008 ford superduty? thank you
Your truck is a new model year and a redesign year as well, could be tough. If your rig has the speed sensitive volume on the stock radio the VSS will be in the one of the radio harnesses. In many Ford truck models of the last few years this has been a grey/black wire. However, your rig is new so proceed with caution. You should also pose this question to the guys over at ford-trucks.com.
2k3 pathfinder looking for the vss wire
thanks
Can someone please help with an install of a d3 in an 07 Yukon. I have the CD/DVD stereo with Rear Entertainment. What do I need to get complete usage in the vehicle(Stereo, Steering Wheel controls and Rear Entertainment, along with Onstar)
Please help!!!!
Simply enter your Vehicle Year/Make/Model here, and it will tell you where the VSS Wire is.
I couldn't find Vehicle Speed Sensor (VSS) for 2005 Kia Sorento.
I found http://www.sorentosite.com/diy/vss.pdf that shows a picture, however, the description is unclear!
Also, by searching for my vehicle and looking under "Body Electrical System"->"ETACS (Electronic Time"->"ETACS Module"->"Schematic Diagram" in http://msw.kiausa.com/viewer/default.asp
I see that On Connector "A", Pin 10 is Speed Sensor.
Is this the correct wire? If not, then where is it ![]()
Please keep your discriptions simple.
I'm a newbie, and this is my first attempt to work on my car :]
tnx
07 Toyota Tundra CrewMax. Non-JBL radio. Either need a wiring harness that includes VSS and illumination wire or need to know location of wires.
Thanks in advance.
need vss wire for 2004 maxima se with bose. i been told it was like 2 different wire colors but that dosent help at all so if someone says 2 wires please let me know if i can use both wires or what.
anyone have any insight to help me out here?
Guys having problems hooking up the VSS wire with your AVIC-D2 & D3 and have it installed in:
-Chevrolet Colorado
-GMC Canyon
-Hummer H3
-Isuzu i-290
Go here:
Any body know were its at on a 03-06 navigator? hell the reverse to if it in a easier spot? My tech site is down.
I need help locating the VSS for my D-3.
It is in a 1995 Porsche 968.
Brian
Illumination line is from lamp on clock in cubby;
Reverse line is from reverse lamp line in trunk.(GR/BK)
VSS line in pin 9 on the 50 pin DME computer plug under passenger foot panel. (RD/BK)
Brian
Okay, having trouble here. I have an '00 Eclipse GT and installed my Z1, but need to hook up the vvs wire. From my searches I have found that it can be found near the cruise control piece and it is a blue/white wire.
Is there a more specific/easier location to access this wire? I had my Z1 installed in my '06 Mustang GT (got totaled) with no problems, but I'm having trouble with the Eclipse ![]()
I dont know if my car is too old, but would anyone know where it is for an
Acura Legend L 1987 2DR Coupe
Thanks for all your help
Thanks for this sticky! I have a 2005 Hyundai Sonata. The site on the first message does not have a Sonata listed; however, all the other Hyundai's that year show the VSS wire to be the brown wire in the seventh position on the diagnostic plug.
I'm assuming that will be correct for my Sonata? If anyone knows, please confirm. Thanks!!
Hey,
Can you tell me the VSS for a 2007 Dodge RAM quadcab? I had my D3 installed and the installer is saying the VSS is controlled by CAN Bus so would need a CAN BUS to analog converter. Do you guys know what he is talking about? Is it that difficult or is there a VSS wire for him to use?
Thanks,
S.
Use the link at the beginning of this thread and you should see the information you need for the VSS wire.
Hi i was wondering if some one can help me
the site provided here did not have my car listed.......can someone please tell me th vss info for my car.....i do know that it has the sound level increasing proportionate to the car acceleraion feature. thanks
Any clue where the VSS is for an 03 E46 BMW? ? ? ? ?
Anyone know the VSS for an Mercedes SLK 350?
Does anyone know where to locate VSS for 07 Toyota 4 Runner? Thanks in advance.
Does anyone know where to locate the VSS for 07 Mustang GT Coupe
97-02 Expedition and 98-02 Navigator VSS Location:
Pull instrument cluster, black/grey wire on harness. 15min. install of VSS.
