Hey guys. need some help finding my vss wire to connect to Avic-D3 in my 1996 Acura integra 1.8 4dr..
everything else is going really smooth and should have it done tomorrow ![]()
Blue/white at the cruise control module under the drivers dash. God I love old hondas they're all the same.
Right on, big thanks for the help ![]()
2006 Lincoln Zephyr
Would it be at the radio harness?? If I knew the color of the wire out of the sensor, would that stay that same color all the way up into the harness?
Thanks,
Burn
Greetings. I have a 2006 Ford Fusion which should be wired the same as the Zephyr. I also have speed sensitive volume. Am I as out of luck as the rest of the more recent Fords having to go to the wheel speed sensor? Thanks.
2006 Lincoln Zephyr
Thanks,
Burn
Yep.
Yep.
Holy crapwhistle, Batman! That blows. Anyway, could you point out ye olde reverse wire? Thanks in advance.
I think it is a grey and black wire, but where is the easiest place to connect to it?
MadTxn
Ye olde Reverse wire
Reverse Light green/white + driver kick or SJB, conn. E, pin 21
Notes: The SJB (Smart Junction Box) is part of the fuse/relay box under the driver side dash.
Speed Sense GRAY/BLACK (AC) PIN 68 OR 58 AT PCM under the hood on the passenger side.
MadTxn
Thanks. For anyone else who ends up searching on a 2006 Fusion, that connector has two green/white wires. It's almost impossible to see which one goes to what pin. The reverse is 20 gauge, and the other is 18 gauge.
Looking for the VSS on 99' corvette (coupe) I assume it should be in the harness somewhere cause it has that "speed compensated volume" thing.
( I did search btw)
Speed Sense PURPLE (AC) ECU MODULE TO THE RIGHT OF GLOVE BOX PIN 14 OF A 26 PIN PLUG
PSC/ECU TO THE FAR RIGHT BEHIND GLOVE BOX
Anyone know where the VSS wire on a 2007 Suzuki Gand Vitara might be? It's hiding really well... ![]()
Looking for the easiest place to connect VSS wire and back-up wire for a 2007 Silverado (new body style). Using an os3-bose adapter, and the wires are not part of the harness as someone else suggested. I would think that both wires would be somewhere in the factory harness.
I could not find the VSS wire as pointed to in the link I have a 2003 Jeep TJ (It was a great deal of fibreglassing but worth it for the Z2) If someone could let me know where to find this wire I would greatly appreciate it.
Also VSS for 1999 GMC Sierra SLT is it available at the radio harness? It comes equiped with speed controled volume.
Thank you in advance for your help.
2007 Chevy Silverado
Speed Sense yellow/black ac ECM, black 73 pin plug, pin 57
Notes: The ECM (Engine Control Module) is on the driver side fender, behind the headlight.
Reverse Light dk. blue + BCM, natural plug, pin 22
Notes: The BCM (Body Control Module) is to the left of the steering column.
2003 Jeep Wrangler (TQCGF J Niner)
Speed Sense white/orange PCM, white plug, pin 27
Notes: The PCM is on the passenger side firewall under the hood.
Reverse Light purple/black + driver kick, harness to rear
1999 GMC Sierra
VSS is dark green/white at the radio harness.
Does anybody know where to find vss for Mercedes Benz 2001 ML-320
thank you very much
Does anybody know where to find vss for Mercedes Benz 2001 ML-320thank you very much
yeah check you other post...
can't find anything on a 2005 malibu maxx. The vss wire that is. Any ideas?
'05 Malibu Maxx
Speed Sense brown (3.5L only) PCM, blue plug, pin 22
Notes: The PCM (Powertrain Control Module) is in front of the battery on the driver side fender.
thanks
Hey guys just wundering if the vehicle speed sense would be the same from 1999 gmc sierra to 2000?
yup same truck. from 99-02
HI, 2007 Chevy Avalanche VSS. Is there one located by the radio or do i have to go into the engine compartment? Car had a Bose 6 disk in dash radio factory.
