How To: Find your Vehicle's VSS Wire.
By JasonH · Oct 24, 2005in Vehicle Specific Wiring💬 346 posts👁️ 199,818 views
Page 7 of 14
Posted May 25, 2007 · 00:08 UTC#151
Probably. If I remember the truck, in the smaller of the 2 plugs there should be a dark/green white wire. That's vss.
Posted May 25, 2007 · 00:48 UTC#152
Thank you
I'll take a look tomorrow.
Posted May 26, 2007 · 03:26 UTC#153
Well its a no go on either dark green with a black stripe behind the radio. But green white stripe under the fuse box under the hood driver side by the firewall works perfect :D
2007_GM_SUV_vss.pdf
Posted Jun 03, 2007 · 02:42 UTC#154
VSS on 2001 Audi TT quattro? What is the actual purpose of this wire. I was hoping to just hide the brain and gps antenna and then solder my wires from my harness to the back of the head unit. Thanks a lot
Posted Jun 05, 2007 · 15:46 UTC#155
Any chance anyone knows where the VSS is on an 93 Acura Vigor? Just about nothing can be found on this car. Thanks
Posted Jun 14, 2007 · 20:45 UTC#156
Trying to find the VSS for a 2005 Sebring Convertible
no Orange/white at the PCM, and the Light Green and white we have now does not work!
Any idea's?
Posted Jun 26, 2007 · 03:25 UTC#157
2000 FORD F350 Desiel.......VSS and Reverse??
Posted Jun 26, 2007 · 13:21 UTC#158
For the F350, they would be long wires, but grab reverse from your trailer harness at the back of the truck. While you're at it you can grab the VSS from on top of the rear differential. The VSS has two wires, if one doesn't work try the other.
Posted Jun 26, 2007 · 13:50 UTC#159
Any idea where they are inside the cab? Maybe a little closer to the head unit......
Posted Jun 26, 2007 · 14:44 UTC#160
FORD, F SERIES SUPER DUTY, 2000
VSS - gray/black wire, at PCM. The PCM (Powertrain Control Module) is located on the driver side of the firewall under the hood.
Reverse - black/pink wire at relay box under hood
Posted Jun 26, 2007 · 20:20 UTC#161
I have a 05 Altima without the Bose, but the stock deck had the vehicle speed control for the volume. On the factory harness I have the light pink wire. Is this the correct wire or do I need to use the blue/white wire behind the cluster. If it is behind the cluster, how do I access it? Thanks in advance for any help.
Posted Jun 26, 2007 · 20:54 UTC#162
Test it with a multimeter. If thats it, the voltage will fluctuate as your car moves.
Posted Jun 28, 2007 · 22:02 UTC#163
Anyone know where is VSS for 02 Acura RSX? :D
Posted Jun 29, 2007 · 01:49 UTC#164
Can someone tell me where the easiest place to find the VSS wire for a 1998 toyota camry.
Pictures would be helpful.
Thanks.
Posted Jun 30, 2007 · 12:33 UTC#165
1997 Nissan 240sx- VSS and Reverse ?
1998 Nissan 200sx SER VSS and Reverse?
Posted Jul 05, 2007 · 18:26 UTC#166
01 Expedition
Reverse
Black/pink driver's kick.
merry xmas
Is this neg or Pos??
Thanks a bunch!!!
Posted Jul 08, 2007 · 03:31 UTC#167
I found a post here asking about VSS info for a 2007 Toyota Matrix and posted info about a 2004, but we just bought a 2006 Toyota Matrix that we want to install a D3 in and were wondering where the VSS wire was and where the best place to steal reverse power was (without going to the taillights unless it is best) for this year.
Jay
Posted Jul 08, 2007 · 04:40 UTC#168
01 Expedition
Reverse
merry xmas
Thanks a bunch!!!
positive. Not too many cars have a negative reverse wire.
Posted Jul 08, 2007 · 04:42 UTC#169
Jay
Here ya go
Speed Sense purple/white ECM, second plug from right, pin 17
Notes: The ECM (Engine Control Module) is behind the glove box.
Reverse Light red/black + front of fuse box, 10 pin plug
Also the same color in the driver's harness to the rear of the vehicle.
merry xmas
Posted Jul 08, 2007 · 11:57 UTC#170
Thanks a lot!
Jay
Posted Jul 08, 2007 · 20:48 UTC#171
Hey Jay could you help me out here because I tried the link and the info i've gotten seem to be incorrect i used the yellow/green wire for the 1997 240sx and its not working?
1995 Nissan 200sx SER VSS and Reverse?
Posted Jul 14, 2007 · 00:33 UTC#172
See thread here or post reply in this thread. Edit: Request for VSS & reverse wire for 1999 Toyota Landcruiser. Got the Metra adapter to stick with factory amp on AVIC-D3. Still looking for what the loose wires are from the adapter (just heading over to Metra's site now). Do they correspond with the same colors coming off the D3, or Toyota's wire colors?
http://www.avic411.com/forum/viewtopic.php?t=8596
Thank you for your help!!!
-James
Posted Jul 14, 2007 · 02:09 UTC#173
My wife just got the z2 installed over at Circuit City. I was checking various screens and found that her VSS isn't connected (unit is in Simple Hybrid Mode). Anyone know where to find the wire on a 2004 Ford Freestar? She didn't have speed sensative volume (that I'm aware of) but she does have cruise control.
Thanks in advance.
~Nyte
Posted Jul 14, 2007 · 04:01 UTC#174
2002 Volvo S60.. I can't seem to find any information for the VSS location..can you help me?
Posted Jul 22, 2007 · 17:16 UTC#175
is there anyway to verify that the vss wire has been hooked up correctly?
Page 7 of 14
