How To: Find your Vehicle's VSS Wire.
By JasonH · Oct 24, 2005in Vehicle Specific Wiring💬 346 posts👁️ 199,818 views
Page 9 of 14
Posted Nov 20, 2007 · 00:59 UTC#201
05-07 Ford Mustang GT
DARK BLUE/YELLOW
(AC)
PIN 3 OF THE 50 CONNECTOR (C175E) OF THE PCM
The PCM is under the hood - right front.
:D
Posted Nov 28, 2007 · 22:06 UTC#202
Looking for VSS wire on Nissan Maxima GLE
Please Help!
Posted Dec 07, 2007 · 21:43 UTC#203
2007 Toyota Camry. Need to know vss wire please
Posted Dec 12, 2007 · 04:10 UTC#204
does anyone know the vss wire for Saturn Outlook 2007? I just purchased the AVIC D3 and i've been searching the forums and google, but can't find it... thanks in advance
Posted Dec 16, 2007 · 09:44 UTC#205
Doing a D3 Install in a 1997 Acura 3.2 TL. Where's the VSS wire and what color is it? Tks. :?:
Posted Dec 31, 2007 · 02:13 UTC#206
the speed senser wire can it be attached to the tach wire??
Posted Dec 31, 2007 · 16:44 UTC#207
I have a Honda Jazz (GD1) 1.4LS CVT from 2007.
Have also installed a Pioneer AVIC-HD3BT unit and are searching for the VSS wire but are not able to find it.
I've searched the web and found the description for a Honda Fit, but when I opened my gauges the colors on the plug was diffrent. The description said it was on plug C pin 10 and it was a Blue/White wire, but there was no Blue/white wire there at all. And the numbering on the plug seems to be the other way around on my car vs the description I found online
(http://www.hondafitjazz.com/manual.htm)
And the adress in top of this thread did not support Honda.
Anybody know other places (online) I can find information about this?
Posted Jan 05, 2008 · 14:33 UTC#208
you guys on the first page of this thread theres a site that tells you your VSS wire by make/model/year
Posted Jan 07, 2008 · 21:25 UTC#209
And when that did not work, where do I go then?
I've google it with no result on the Honda Jazz, but I got hits on the Honda Fit, but those does not match my car.
Posted Jan 09, 2008 · 23:34 UTC#210
I have a 2007 Pontiac g6 coupe with monsoon radio. It does get louder the faster I go. Where in the hell in the VSS wire for my avic-D3? lol You all seem to be great help to everyone.
thanks
luke
Posted Jan 10, 2008 · 00:02 UTC#211
lorien86 - the vss wire is in the factory harness for your radio. I used the Metra GMOS-LAN-01 GM Onstar LAN Data Bus Interface and wired in per instructions, except for the brake wire, since I did the bypass. Also, there is room for your gps antenna under your storage compartment above the radio in between the center speaker opening and the two mounting screws. I have a full strength signal. Also, I used the factory xm antenna and dropped the xm box in the back compartment where the jack and factory xm box are.
Posted Jan 11, 2008 · 02:58 UTC#212
JasonH said:
Simply enter your Vehicle Year/Make/Model here, and it will tell you where the VSS Wire is.
http://www.rostra.com/techsupport-main.asp
No listing for a 2000 Buick Regal GSE.
Also, anyone familiar with Metra harness 70-2018 - 32 pin factory adapter with rca plugs for external amp??? Guys at Metra say I need this to hook up to GM harness since I have the optional "Monsoon" system. Install.com not sure if this will work.
Thanks.
Posted Jan 11, 2008 · 20:22 UTC#213
Speed sensor / VSS wire for 2002 Nissan Maxima per Crutchfield tech support:
Driver's side console center
White 18-pin connector
Pin #2
Pink wire with blue stripe
Posted Jan 11, 2008 · 23:11 UTC#214
This is a great forum! I have the Z2 now, and want to put it in my 2002 Tundra, S with ext cab. That car isn't listed on the rostra site. Anyone have any ideas where the VSS and reverse lines are that I can tap? I have the bypass to install also. Thanks much - keep up the great dialogue!
Posted Jan 12, 2008 · 01:13 UTC#215
Dont know about the rev lt(I usually go to the light when i cant find info)
BUT, speed sense is Green/Oarnge at the gauge cluster.
Posted Jan 12, 2008 · 21:21 UTC#216
thank you! I'll look for it and see if I can locate it.
Posted Jan 12, 2008 · 21:48 UTC#217
found the answer on another forum. (Green wire with white stripe in the gauge cluster harness)
Posted Jan 13, 2008 · 00:50 UTC#218
Found the VSS wire for the 2002 Tundra Extended cab, automatic, V8. IT IS the Green/Orange as I was told above - thanks! Good news - it runs thru a junction box, J7, directly behind and to the left of the radio cluster - back on the firewall. So - didn't have to putz with the instrument cluster. It is also on the ECM, plug E4 (second from the left), behind the glove box, pin 5. Hope this helps the next guy!
Posted Feb 02, 2008 · 04:50 UTC#219
just wondering where the V.S.S and the reverse wire hookup could be made nice and easy. i see that if you have the auto volume feature , it should be on the stock harness, but would it be the same color and tracer as under the hood, which says it is green/white? also is it just easier to run the reverse wire to the taillight , or try to find it in a fuse panel or something? thanks, i dont really feel like paying two hundred bucks for some jackass to hook this up . any help is definately appreciated
Posted Feb 08, 2008 · 01:48 UTC#220
is the vss and car speed signal input the same thing if so how do i find it 2004 ford f-250 diesel
thanks
Posted Feb 08, 2008 · 07:04 UTC#221
yes it is the same , and your vss wire is grey, with a black tracer Passenger’s Side Fender Well (Between Engine Bulkhead & Shock Tower)
Pos3 of Black 10 pin Speed Control module. you can also use the search on here , put in f150 and vss and im sure you will get a post that relates to you
Posted Feb 08, 2008 · 22:25 UTC#222
does anyone have the VSS wire location / color for a 2006 Suzuki Grand Vitara ?
They changed it in 06' and it is totally different
Posted Feb 08, 2008 · 22:29 UTC#223
Blue/Black at the abs module in the engine bay is what i have listed.
Posted Feb 08, 2008 · 22:46 UTC#224
Do you know where in the engine compartment ? The ECM is over the D/S wheelwell and the BCM is supposedly above the D/S kickpanel. Thats as much info ive found
Posted Feb 09, 2008 · 04:56 UTC#225
I vaguely remember it being in the front center of the engine bay. I don't remember exactly since the only one I did was shortly after the vehicle was publicly availible. Was my first and only foray into sidework for a dealership...... Big mistake that was....
Page 9 of 14
