How To: Find your Vehicle's VSS Wire.
By JasonH · Oct 24, 2005in Vehicle Specific Wiring💬 346 posts👁️ 199,818 views
Page 11 of 14
Posted Mar 22, 2008 · 03:51 UTC#251
Anyone know the VSS for a 2008 Honda Civic DX?
I searched various forums and google it, but nothing. It should be the same for the 06-08 models (DX only)
I think the wire is different for the DX since this model doesnt come with a radio and has no cruise control.
THe link from the first post does not have my car
Thanks for the help
Posted Mar 22, 2008 · 04:32 UTC#252
just becuse you have no radio dont mean you dont have the wires int eh same place. look for it there anyway.
mos tof th etime they will throw the same harness in a car no matter what the options are if they are something that is not a seperate harness it is cheaper for them to order 50,000 of the same then 40,000 of one and 10,00 of another.
so i would look for it in the same place any way.
also you can call a dealer ship withc is what i did the other day for s&g and foudn out there really is a Vss wire in the back of the radio but they had two diffrent answer on witch one it was lol so i just hooked it up and the B.C.M and was ovr it
Posted Mar 22, 2008 · 17:14 UTC#253
So on another forum i user reported that he does have a wheel speed wire in the 08 Ford Fusion. Its blue/orange and it is in the d.s. rear. I tried hooking it up in my 06 fusion and i get no pulses.
Is it true that an 08 fusion has a wheel speed sense wire thats blue orange, and the wire in my 06 fusion that is blue orange in the exact same spot he claims is NOT the wheel speed sense wire?
This is getting ridiculous because im getting conflicting stories.
Posted Mar 22, 2008 · 17:25 UTC#254
Hello, I have a 2005 Lotus Elise. Hooked up an Avic N2, but couldn't find any info on a VSS wire.
Anyone have this information? The engine on an Elise is the same as a Celica GTS. Does that help find the VSS?
Posted Mar 24, 2008 · 00:17 UTC#255
Thanks Mickey. My installer Shaan (SR Audio Works, Lebanon, NJ) had figured out the VSS for my ML and hooked it up this weekend.
Thanks again!
Dave
Posted Mar 27, 2008 · 14:08 UTC#256
2003 Ford Excursion with the 6.0 Desiel? I found the backup wire in the PKP Black/Pink (total stroke of luck) any idea on the VSS wire?
Posted Apr 04, 2008 · 02:48 UTC#257
good day,
after doing a search on the site posted at the start of the thread and browsing a few threads on this forum .. i still haven't found what i am looking for, so hopefully someone can point me in the right direction ...
Avic-D3x install .. into an 08 Scion xB without factory nav .. (but it does have the vol controlled by speed option on the factory radio) ... trying to find the VSS wire ...
between that and locating my mic for the BT module .. i will have a full weekend ahead of me
Posted Apr 06, 2008 · 21:53 UTC#258
should be purple in the radio harness
Posted Apr 07, 2008 · 07:48 UTC#259
Were can i find the vss on my 02 ford f150 harley davidson?
Posted Apr 10, 2008 · 14:29 UTC#260
Where can I find the VSS wire on a 2004 Jeep Grand Cherokee?
Posted Apr 14, 2008 · 20:30 UTC#261
Anyone know where I can find the VSS on a 2007 Ford Edge???
Posted Apr 15, 2008 · 01:02 UTC#262
Well I found the VSS wire on the 2004 Jeep Grand Cherokee that I own... It is located way up on passanger side firewall behind the glove box... It is a dark green and yellow wire which was really hard to find amongst the 50 other wires coming through the vehicle at that location... You can also find it attatched to the firewall directly under the hood on the passenger side if you want to go that route as well.... The only problem I am having is that the VSS wire canceled my nav bypass that I had working the AVIC-N4 now realizes that the car is moving and while the car is in motion I loose the ability to type destinations into the navi although as soon as the vehicle comes to a stop all the icons light up again. Also there is another annoying message saying there is a problem with the installation of the parking brake wire. I thought that the VSS would not over ride the parking brake bypass... this is not true it does. Good luck
Posted Apr 18, 2008 · 21:37 UTC#263
Anyone got an idea of where I can find the VSS wire in a 2000 expedition? I think it a grey/black, but I'm not sure where it is.
Posted May 13, 2008 · 11:29 UTC#264
VSS on Nissan Altima 08? Thanks
Posted Jun 15, 2008 · 09:55 UTC#265
Does anyone know were to find the VSS on a 2003 Lincoln Town Car?
Thanks for any help.
Posted Jun 26, 2008 · 15:28 UTC#266
Looking for the VSS on a 2005 Dodge Magnum SXT. I have it tapped to the Green/Brown at the PCM in the Psgr. side right now per the wiring diagram but not working. Suggestions?
Posted Jun 29, 2008 · 14:03 UTC#267
Well, if anyone else needs it I found it. It's pin #68 on the PCM drivers side engine compartment fire wall. It's gray with black stripe.
Posted Jun 30, 2008 · 23:41 UTC#268
Looking for VSS on a 2007 Avalanche.......
Thanks in advance!
Ron
Posted Jul 01, 2008 · 00:53 UTC#269
2007 & 2008 Chevy Avalanche
PASSIVE ANTI-THEFT YES TRANSPONDER SEE NOTES
This vehicle is equipped with a TRANSPONDER passive anti-theft system. A bypass module may be available which will not require a key. Contact your supplier to find out. If one is not available to you, please see the appropriate security diagram before any remote start installation.
12 VOLTS Red/black In black plug on fusebox under dash +
IGNITION Pink Ignition switch harness +
ACCESSORY Brown Ignition switch harness +
STARTER White Ignition switch harness +
Start wire requires (+) through a 1280 ohm resistor.
KEY SENSE Pink Ignition switch harness +
TACH SIGNAL SEE NOTE
Go to any coil on the side of the engine and use the wire that is not Pink, Black or Brown.
FUEL INJECTOR Opposite from Pink At any injector on engine AC
LOCK Data module required
UNLOCK Data module required
DOORPIN Gray At BCM on the left side of the steering column +
Located in the TAN connector.
FACTORY ARM Data module required
FACTORY DISARM Data module required
The OEM alarm will disarm automatically on remote start.
BRAKESWITCH Blue/white At switch or BCM on left of steering column +
Located in the BROWN connector.
PARKLIGHTS (-) Lt.blue At light switch or BCM on left of steering column -
HAND BRAKE Lt.blue At BCM on left of steering column -
HORN Tan At steering column or BCM -
Located in the BROWN connector. The BCM is located on the left side of the steering column.
VSS WIRE Yellow/black In Black connector on ECM AC
The ECM is located on the driver's side of the engine compartment behind the headlight
Posted Jul 01, 2008 · 01:53 UTC#270
What about a 2005 nissan altima? the site only showed a sentra for that yr. I thought I found it in a thread on here, but apparently didn't bookmark it. :(
Posted Jul 01, 2008 · 01:57 UTC#271
Thanks James Av07!!!! :D
Ron
Posted Jul 05, 2008 · 22:29 UTC#272
James Av07,
Hey!
Question,
Is the ecm behind the L/H headlight...... and does it have 3 connectors....2 fwd facing and 1 aft?
Both forward facing connectors are black..............looking to tie into the VSS.
Ron
Posted Jul 12, 2008 · 18:11 UTC#273
for any vehicles not listed on the rostra site, or vehicles that are CAN-BUS, wheel speed sensor only, or you just dont feel like doing the work of finding VSS, i have an adapter plug for VSS. Its the easiest thing in the world! :D It simply plugs onto the OBD2 port and has a wire coming off of the adapter plug that is VSS you just connect this wire to your VSS input and VIOLA! done like dinner! :)
let me know if anyones intereested works on all vehicles up to and including all 2009 models Porsche, VW, Audi, Mercedes, Chev, anything and everything! i am yet to find anything that they dont work on!
Posted Aug 06, 2008 · 08:59 UTC#274
anyone know where the VSS wire is on a 2004 UK renault megane dci???
cheers
Posted Aug 16, 2008 · 21:25 UTC#275
I have search all over Google and here and can't seem to find anyone who knows where I can tap the VSS in my car, 2006 Mazda MX5. If anyone can help I would be forever in your debt.
Page 11 of 14
