Z1/Z2 HDD Replacement Trial and Error Thread
By stryk3r · Aug 21, 2007in Hacks/Mods💬 132 posts👁️ 36,385 views
Page 3 of 6
Posted Aug 30, 2007 · 23:24 UTC#51
For all you bargain hunters out there:
The 2.5 to 3.5 IDE adapters are on sale at NewEgg for $1.99!!!
Rosewill RCW-603 Laptop 2.5" to Desktop 3.5" IDE Hard Drive Adapter Converter - Retail
Item #: N82E16812119020
I purchased one of these as well for $48.99
TOSHIBA HDD2D17 (MK6034GAX) 60GB 5400 RPM ATA-6 Notebook Hard Drive - OEM
Item #: N82E16822149041
Combined shipping and handling was 7 bucks.
I didn't want to take the chance on turning my recently installed X1 (soon to be an X2) into a paperweight.
Now if I can just get the darn files to download without monitoring.
Hope this helps.
Richard
I currently don't use ANY of my music partition. However, I have in the past put a CD on it and seen how much more responsive it is over the iPod interface. So maybe with more space I might invest in some CD-RW and just burn a ton of music.
With that said, the other reasons I would consider upgrading are...
1. I want to do the Z1 -> Z2 image update. It would be nice to keep the original Z1 hard-disk. I am not sure if it is even possible to put it back in the Z1 after it becomes a Z2 though.
2. Speed!
The stock drive is 4200rpm right? So I would love to see faster response on the NAV.
If at some point someone finds an even faster than the drive listed above from NewEgg, man I would even be down for that.
I too have encountered the heat issue in SoCal. Today and yesterday my nav wouldnt POST. I had to wait till my car was cold inside (a/c) and then power off/on my car.
Posted Aug 31, 2007 · 01:40 UTC#52
I finally got around to expanding the music partition on the Z2 image running on the Toshiba 60gb drive, and everything is working flawlessly.
I orignally imaged the 60gb, but left all the unused space as unallocated. I then began the process of ripping the cd's. I made it to 179 albums covering 155 artist before I filled the initial 10gb music partition. After expanding the music partition to use all the unallocated space (40 gb total), I am now only 25% full, and I have been able to start adding cds again (up to 400 albums or 400 artists). I decided to do this because the hdd is much faster than the ipod interface...
I started using cd-rw discs, but it was a pain having to erase them. I decided to pick up some 100 packs of cd-r from Circuit City for $8.99 ea. Can't beat .09 per disc :)
http://www.circuitcity.com/ssm/NexxTech ... tDetail.do
Posted Aug 31, 2007 · 02:18 UTC#53
I've honestly never burned a RW disc in my life. I always have bought CD-R and just throw them away. I didn't know the process included having to 'erase' them. "F" that. I agree with the spindle.
I suppose one issue I have is that all my music is in iTunes. While I can browse the folder structure (../Artist/Album/Song.mp3) I don't have the original CD's. So this might not work perfectly then, because GraceNote won't know about my songs/artists/etc. , right? Hrmmm
Posted Aug 31, 2007 · 09:08 UTC#54
You do not need Gracenotes if you use a burning software that supports cd-text. WMP does not support this. I know that Nero does support cd-text. It will pull the song name from the MP3 tag, and you will only have to type the album title and artist. I use this for any album that Gracenotes is not able to decipher.
Posted Aug 31, 2007 · 16:28 UTC#55
I've figured out the pattern.... doing one more test to confirm. Suffice to say, I'm pretty sure that we can ONLY use Toshiba drives at this point.
Results:
Seagate ST910021A 2.6W max - reboots within 1 hour. After first reboot every 15 mins.
Seagate ST9100823A 2.3W max - reboots within 1 hour. After first reboot every 15 mins.
Seagate ST9160821A 2.0W max - reboots within 1 hour. After first reboot every 15 mins.
Toshiba MK4025GAS 2.6W max - no reboots
Toshiba MK4019GAX 2.9W max - no reboots
Fujitsu MHT2060AT 2.3W max - currently testing
Posted Aug 31, 2007 · 17:41 UTC#56
As posted above, the MK6034GAX looks to have had success too....
Results:
Posted Aug 31, 2007 · 18:40 UTC#57
At this point, I believe any Toshiba drive will work. There's definately a HDD type check in the firmware to ensure only Toshiba drives are used.
Posted Aug 31, 2007 · 18:42 UTC#58
Some of you guys have access to test all these drives, I don't. So if I saw there was a 5400 80GB toshiba with exactly the same specs as the others, I wouldn't want to take the risk in purchasing it. I really rely on you guys testing them, and I *do* appreciate it.
I think I am going to go the route of getting a new drive, restoring the Z2 image to it, rather then unlocking my 30gb and then restoring the Z2...
Now I just need to find the damn image. It is supposed to be on the newsgroups but ah well... anyhow, back to the topic.
Posted Sep 04, 2007 · 05:46 UTC#59
I also really appreciate all the work you guys put in on testing theses drives.
I was thinking about getting a 120 gig toshiba drive, because i would like to have a lot of music on my system. Does anyone think this would be too big?
I was checking out this one from newegg because the specs seem to be the same as the toshiba drives that people are using without reboots.
TOSHIBA 120GB 2.5" ATA-6 Notebook Hard Drive - OEM
120GB
5400 RPM 8MB Cache
ATA-6
$70.99
Any thoughts would be appreciated.
Posted Sep 04, 2007 · 05:50 UTC#60
120GB
5400 RPM 8MB Cache
ATA-6
$70.99
IMHO chances are good that drive will work.
Still, your limitations of the Z1/Z2 will hold you back with the what... 400 artists, 1000 albums? I forget... So with 110GB extra, what will you do with it? Also the possibility you'll drop the $70 bucks and find out it won't work. Good luck.
Posted Sep 04, 2007 · 06:05 UTC#61
Thanks for the info Agro. I wasn't aware of the limits on artists ect.
I am still trying to read and learn as much as I can.
I really love my z1, but I want to get the new maps and upgrade to a z2, and while I'm at it, would like to make the drive bigger for music. but I guess that is limited. :cry:
So what would you reccomend for hard drive size? The 60 gig?
Posted Sep 04, 2007 · 06:16 UTC#62
There are ways around the artist/album thing, if you want to tweak things. Like you could start combining stuff together, etc. Honestly I am just too damn lazy and want it to be easy.
The 60GB with about 50GB free space should give you more than you need to fill up those artist/album limitations. Maybe someday Pioneer or someone else will know how to bypass that and increase them. Then at that point I think we'd look to a bigger drive. IF the bigger drive worked without the restarts AND was faster then I would say that is the way to go, but if it has the same specs, I personally wouldn't waste the extra money for no benefit and also take on the risk of the drive possibly not even working.
I for one placed an order on Saturday for the 60GB Toshiba & 2.5" to 3.5" adapter from Newegg.com They sent me my tracking number tonight, should have it by Thursday. I figure, more space, faster and about the same as paying the unlock code for my 30GB Z1 drive, right? why not!
Posted Sep 05, 2007 · 01:09 UTC#63
Well thanks for your advice. I will probably get the 60 gig, and see how it goes.
Posted Sep 05, 2007 · 22:12 UTC#64
Would anyone be interested in selling me a new hard drive (mk8032 gax) with the Z2 info already on it. I have a Z2 that only works about 25% of the time due to the Houston heat. I would pay for the time and equipment to get this done for me. Or, is there a very simple way to down load this info directly to a new hard drive and then just replace the stock hard drive. I dont mean to sound lazy or stupid but this is not my expertice.
Posted Sep 08, 2007 · 20:45 UTC#65
I also own a z2 that keeps locking up. I would also be interesed in purchasing a loaded z2. I'm in New York and mine bails out in 85 degree weather.
Posted Sep 08, 2007 · 21:08 UTC#66
A big thanks to this thread for helping me avoid the hit or miss drive shoot. I purchased a Toshiba MK6034GAX from newegg and it works great. No reboots and noticeably faster than my Z1 drive.
Imaged and expanded the partitions and now have a fully functional Z2 in Z1 hardware. The added space seems to have showed up, but I usually use an Ipod and haven't had time to upload many CDs.
Anyway, can't thank everyone enough to help me from blowing money on a drive that wouldn't work like stock.
NYMETRANGER: PM me maybe we can work something out if your local. I don't know about the legal implications of that sort of thing. I'm on the island.
Posted Sep 09, 2007 · 19:04 UTC#67
Has anyone replaced their HDD and had it cure the "freezing on startup" issue? Or the skipping through tracks in the library problem? I was thinking of trying to remote mount my stock drive, but if I could just spend $80 and get a new drive I'd prefer to do that.
Posted Sep 10, 2007 · 12:32 UTC#68
ok some one plz post a link to a store i need a new HD
Posted Sep 10, 2007 · 13:49 UTC#70
ohhh this is AWSOME NOT!!!
they don't ship to Canada
Posted Sep 10, 2007 · 13:51 UTC#71
Oh damn. I wasn't even thinking about where you were. Sorry.
Posted Sep 10, 2007 · 13:52 UTC#72
lol its cool ill call them in 10 min see if i can get them to ship 1 for me :D
Posted Sep 10, 2007 · 13:55 UTC#73
LOL
Posted Sep 10, 2007 · 13:56 UTC#74
yaa Canadians always get OWNED !!!
Posted Sep 11, 2007 · 00:50 UTC#75
I was having the freezing on start-up and the library skipping problem. I bought the 60 gig toshiba drive and have not had one freeze-up yet! (Now I just jinxed myself)...
This is on a Z2.
Jason
Page 3 of 6
