Z1/Z2 HDD Replacement Trial and Error Thread
By stryk3r · Aug 21, 2007in Hacks/Mods💬 132 posts👁️ 36,385 views
Page 6 of 6
Posted Jun 07, 2008 · 00:25 UTC#126
Kuj,
Yep. Go for the 60g drive. I have the 40 and it's performing flawlessly. Much faster than the stock drive.
How much faster? I just purchased the Z2X package from crutchfield and it will be delivered monday. Do you think it will have the latest maps or maybe even a newer/faster hard drive? How will I know if it has the latest maps?
To be quite honest, the speed is noticed mostly upon startup (for me at least). With the stock drive I used to start the truck and get to the end of the street (15 houses down) before the dvd would kick in or th elibrary music would start. Now it's about 1/3 that distance.
It's not mind blowing speed difference, but you can tell it's quicker. Latest maps (2008) can be found here along with instructions on how to load. At first it looks intimidating, but just follow the road map and take your time and it will be well worth it.
If you end up getting the new drive, I'd suggest putting the 2008 maps on that first. Do the security disable and unlock as well. Get your practice on the spare drive before you go messing with the stock one.
Later,
B-F 8)
Posted Jun 07, 2008 · 04:50 UTC#127
thanks for all the info. i ended up buying the MK6034GAX. i've already downloaded the z3 image. instructions seem straightforward. i even own a copy of Acronis True Image. all i need now is the drive. :D
Posted Jun 12, 2008 · 15:28 UTC#128
Hello,
I was reading thru the forum and noticed that there is no need for drive unlocking if the drive is new. Reading this forum it states to disable security with MHDD. http://avic411.com/forum/viewtopic.php?t=728, Then you need to unlock the drive.
But in other postings it says you don't need to if the drive is new.
What I did thus far is use the MHDD tool and disabled the security feature, then I used Acronis true image to place the Z3 image on the drive. Is there anything else i need to do before place back into my vehicle?
Can some pls clarify this for me?
Thanks, G
Posted Jun 12, 2008 · 19:00 UTC#129
Hello,
Thanks, G
If you don't disable the security of your new drive, it will be locked as soon as you insert it in the Z and power the unit up.
Posted Jun 13, 2008 · 01:26 UTC#130
Hello,
Thanks, G
G, You're good to go :!:
If you're working with a brand new drive (not the drive that came with your Z), then all you need to do is what you did; use MHDD and disable the security on the drive.
Now when you insert that new drive into the Z, the Z cannot lock it.
Unlocking and disabling security are two totally different procedures. In a nutshell:
Stock drive has security feature enabled. Because security is enabled, the Z locks the drive. If you want to disable the security featur, you have to unlcok the drive and then remove the security feature.
Aftermarket drive (brand new) has security feature enabled. Since it hasn't met the Z yet, it's still unlocked. All you need to do is disable the security and now when it gets inserted into the Z, it cannot be locked.
Hope that helps some 8)
Posted Jun 17, 2008 · 16:15 UTC#131
Hello,
Thanks, G
big-fokker couldn't said it clearier. You are good to go.
Best
Posted Jun 19, 2008 · 13:02 UTC#132
I have 2 Toshiba models that worked perfeclty with NO REBOOTS
Toshiba MK4026GAX 40GB consumes 1.0amps
Toshiba MK4025GAS 40GB consumes 0.7amps
Page 6 of 6
