Z1/Z2 HDD Replacement Trial and Error Thread
By stryk3r · Aug 21, 2007in Hacks/Mods💬 132 posts👁️ 36,385 views
Page 4 of 6
Posted Sep 11, 2007 · 05:20 UTC#76
Xartni is it mild weather where you live
Posted Sep 11, 2007 · 14:56 UTC#77
I live in So. Cal, up until this last week, it has been off the charts hot (95-105+). Before I made the switch my radio would freeze on start-up even if the temps were in the high 80 range. I have not had one freeze in the 90's or 100's (yet). I've had it installed now for about three weeks.
Jason
Posted Sep 13, 2007 · 00:17 UTC#78
Using the stock drive, after sending it in once to Pioneer, it would not start periodically. After I bypassed it there was really no change. Sometimes it booted other times not.
We took it on vacation and it would not boot at all. I stopped at an autoparts store and got screwed on a $10 #9 torx wrench. But then I was able to take the cover off and using a cd case, I directed the AC blower into the HDD slot. After a few minutes of cooling, I cheated the interlock and she booted right up.
When I got home, I bought a Western Digital 80 GB HD from Best Buy. I do not know the exact model number because it is in the Z2. This drive boots everytime no matter what the temperature. It does randomly reset but even while navigating it only takes about 10 seconds to come completely back up without loosing position.
I bet that the Flash drive will work. I have also been looking at a Hitachi Endurastar drive which is rated at 85 degrees C operating. They are impossible to find though and look to be more expensive than the flash drive.
By the way when I formatted and partitioned my WD drive, I made the last 2 partitions 30 GB each. Works fine.
Posted Sep 14, 2007 · 13:41 UTC#79
I saw the links for the Z1 images on the upgrade sticky... but where are you guys getting the Z2 image from? Got a deal on ebay to pick up a Z1 for $800 and i figure i'll upgrade it to the Z2 for a few extra $$... otherwise i'll go with the D3 thats only $650 new. I'm just hoping the Z1 won't freeze up and break in -50f weather
Posted Sep 15, 2007 · 01:06 UTC#80
I have a 60gb Toshiba already upgraded. If anyone is interested you can pm me.
Posted Sep 18, 2007 · 19:13 UTC#81
not sure if this is the right place to ask, but: If I purchase a new drive, do I need to unlock it, so that the image will work? I know the Avic locks the drive after I put it in, but a brand new drive should be ok. Thoughts?
Posted Sep 18, 2007 · 19:53 UTC#82
If you use a new drive, it does not need to be unlocked. You still DO need to turn off the ATA Security feature, to prevent the AVIC from locking the drive when it boots from the new drive. If you do not turn off the security, then you will be in the same boat next year when you want to update... :)
Posted Sep 18, 2007 · 21:18 UTC#83
ohh so it will lock the drive :shock:
Posted Sep 20, 2007 · 23:54 UTC#84
Has any tried to upgrade with MK1234GAX: 2.5" HDD 120GB by Toshiba. Just wanted to know, before I try it.
Posted Sep 21, 2007 · 00:06 UTC#85
i think thats HD is SATA
Posted Sep 21, 2007 · 02:56 UTC#86
Brand TOSHIBA
Model MK1234GAX
Performance
Interface ATA-6
Capacity 120GB
Cache 8MB
Average Seek Time 12ms
Average Latency 5.55ms
Posted Sep 21, 2007 · 03:09 UTC#87
its no use using a HD that large, 40G is about all the file system can handle
Posted Oct 11, 2007 · 18:49 UTC#88
I know this might be impossible and convoluted but I wanted to see what you guys thought. Bear with me on this.
Avic-Z2/Z1 --> Factory supplied IDE cable --> 2.5" PATA Male/Male adapter --> 2.5" to 3.5" PATA adapter
Ok now we have converted the AVIC-Z2/Z1 to use a standard PATA interface but the power adapter on the 2.5" to 3.5" PATA adapter above would have to have a gender change in order to plug into the 3.5" power interface.
From this point you could possibly use a standard 3.5" drive and mount it external in the dash. There may be a power and shock issue here and you would still need a Toshiba drive which I am not sure Toshiba makes 3.5" drives. I don’t see why would couldn’t use an external power supply for the drive. However using a standard 3.5†drive isn’t my end goal. Keep reading...
Know lets convert this 3.5" PATA interface into a 2.5" SATA interface.
2.5" to 3.5" PATA adapter --> SATA Hard Drive to IDE PATA ADAPTER --> New Toshiba 7200 2.5" SATA drive!!
First of all I don't have my AVIC-Z2/Z1 yet so my thought process may very well be off. I know this is a lot of extra hardware and I assume there is no room in the AVIC chassis for it even if you wanted to put it in there. My thought was to somehow channel the factory IDE cable out of the chassis and do the conversion and hard drive mount external. At least it would be cooler that way. You could even use a separate power supply just for the hard drive that would power up on ignition. My other concern is will the drive still be recognized as a Toshiba during the SATA/PATA conversion. I think it will but don't have a way to test this.
Posted Oct 15, 2007 · 01:52 UTC#89
I tried a hitachi 40 gb drive -- reboots after 15-30 minutes
fujitsu 80 gb drive -- same (sorry, I forgot to write down the models on them)
Tried Toshiba 120 gb drive (mk1234gax) -- drove around the city all day saterday, no reboots at all. Works perfectly !!! .................
Haven't had a chance to expand the music partition yet, just wanted to see if the drive will work with the unaltered z2bypassed image first.
Posted Oct 15, 2007 · 04:00 UTC#90
I am definatly intrested in finding out if you got the 120gb to work with an extended partition. Let me knwo what program you used to expand the partition and how big was too big because i am sure you will be able to get to that part.
P.S. if anyone wants a New 80gb Toshiba hard drive with a Z2 image on it let me know, cause i have a working spare. I would probably let it go for $100.
Posted Oct 15, 2007 · 05:21 UTC#91
max is 30 gig for music
Posted Oct 16, 2007 · 17:26 UTC#92
yaa Canadians always get OWNED !!!
Hey Mazdaspeed,
I found the Toshiba MK6034GAX at Tigerdirect.ca for only $73.99 CAD if you are interested. I am thinking of buying this drive myself and loading the Z2 image. here is the link:
http://www.tigerdirect.ca/applications/ ... etailspecs
any ways, good luck with the upgrade.
later,
Soundfx
Posted Oct 16, 2007 · 17:30 UTC#93
meh i had mine done long time ago
its gets better i always had a Z2
did it for 5400RPM HD :P
Posted Oct 16, 2007 · 17:36 UTC#94
Awesome then... I guess you don't have any problems with the faster RPM drive and the cold weather? You are using the MK6034GAX right?
Posted Oct 16, 2007 · 17:39 UTC#95
MK8034GAX
they stoped making MK6034GAX so if you get one its by luck
Posted Oct 16, 2007 · 19:25 UTC#96
http://www.newegg.com/Product/Product.a ... 6822149041
is this the hdd that works? im lookin to get a bigger drive and update to z2 image. what is the one drive that works? im not worried about unlocking the stock one. thanks
Posted Oct 16, 2007 · 19:28 UTC#97
thats the one :D
Posted Oct 16, 2007 · 19:34 UTC#98
better be *shakes fist*
Posted Oct 18, 2007 · 03:15 UTC#99
Just did the update with the help of Mr. Mazdaspeed!!! Thanks by the way... and everything works fine, used a new Toshiba MK6034GAX drive and put the z2 image using acronis true image 10. When you first install the drive, the unit will go through a update procedure that takes approx. 5 min and then the unit started to work right away... my only problem is that for some reason, the updated maps actually don't show my home address, the previous z1 maps that was previously installed showed my street but the new updated z2 maps, did not??? weird but I don't care, since i never use the "go home" feature. other than that, everything works amazing... THANKS AGAIN TO MAZDASPEED :D
Posted Oct 18, 2007 · 03:58 UTC#100
no prob man it was fun :P
i always help my club members out :D
Page 4 of 6
