We have finally cracked pioneer navigation software (iGO NextGen)
Now, you can put any content on the device for which you have a working license.
After installing the patch, your maps software will take any content with any valid license for that content.
Even if the license from another device (check of license hardware id (SWID) is disabled in our libraries).
You can copy manually content and licenses through File Manager, using copy_script or by inserting internal sd card into your PC.
Don't forget to set proper filesystem rights to newly copied files.
For 5000nex-7000nex and 5100nex-7100nex users it is possible to add all features of 8000nex/8100nex:
- 3D Landmarks,
- 3D City Map,
- Natural Voice Guidance,
- Enhanced Junction View & Realistic Road Signs,
- Free Lifetime Traffic by Total Traffic Network
Instruction to install patch
- Download file corresponding to your navigation version. You can check your version in About/Version information in maps application.
- Unpack downloaded file into FAT32-formatted USB stick, insert stick into USB1 (USB2 isn't working).
- Your device will reboot into testmode.
- Select Write program forcedly => Copy Script, script will patch your system and reboot.
- Remove USB stick after script finishes.
Now you have have cracked version of maps software. This version will accept any valid licenses, even licenses not for your device.
You can find new content and licenses using gpspower.net or 4pda.ru:
http://www.gpspower.net/igo-maps.html
http://4pda.ru/forum/index.php?showtopic=141926
Adding RDS-TMC for the 5000/5100 NEX
TMC UC.zip
pass: 4pda
- Download file
Adding TTS languages
Is available in 16 TTS languages
You can add any of the available languages
TTS download files you can on 4pda
http://4pda.ru/forum/index.php?showtopic=200728&view=findpost&p=46123907
dan.dnk.naja
deu.deu.hans
eng.gbr.amy
eng.usa.salli
fra.can.chantal
fra.fra.celine
ita.ita.carla
nld.nld.ruben
pol.pol.jan
por.bra.vitoria
por.prt.cristiano
rus.rus.tatyana
rus.rus.maxim
spa.esp.conchita
spa.usa.penelope
tur.tur.filiz
if you need the latest information
you can get it on 4pda.ru - rus lang
http://4pda.ru/forum/index.php?showtopic=698751
