Can anyone download the 8000nex patch for download? Tks
The AVIC Development Mod
post #523
Good morning,
Newbie to the AVIC community, I was reading the project notes and all I can say it's WOW!!!
Great to see so much progress and talent.
I hope I can get some help as I have read all the progress and 36 pages of this thread, but want to make sure I'm taking the right steps.
Got a 8100nex unit from a local guy, everything was tested and was working great, got it installed and I was very happy, then realized it was running 1.01, went ahead and tried the upgrade to 1.09 (following all instructions), and now stuck in the loop of "Update FAILED, please reset and wait for the Auto Recovery"
I gather that there are 3 tested keys right, which one can allow to go into recovery only? I do not have a backup of the SD (and if at all possible will like to avoid removing the unit).
What will I need, besides the right testmode key file and the USB/Fat32?
If I do need to make a Jenkins build, which parameters I should use if I wants just to restore to factory?
Or is it a lost cause and I need to replace the internal SD?
and WhatisWhatis mention that the group might have the 8100nex image, how can I get it?
Kinda sad to look at my failed message on the commute to work, please help me ![]()
Ashtonxt
hi. i m newbie and i try install nova launcher on da120, maybe someone can see my script and say if i right
mount -o remount,rw /system cp -f /mnt/udisk/launcher1.apk /system/app/ chmod chmod 755 /system/lib/launcher1.apk sed -i 's/EXTEND_HOME/HOME/g' usr/keylayout /mxckpd.kl sync reboot
не забудь отключить Warp и купи UART
chmod 755 /system/app/launcher1.apk
/system/usr/keylayout/mxckpd.kl
Я заменÑл mxckpd.kl и права не забудь
chmod chmod 755 /system/lib/launcher1.apkchmod 755 /system/app/launcher1.apk
/system/usr/keylayout/mxckpd.klЯ заменÑл mxckpd.kl и права не забудь
о не заметил опечатку, ÑпÑ.
ну лучше заменить да, говорÑÑ‚ на андроиде sed пашет через одно меÑто.
вообще Ñ ÑÐµÐ¹Ñ‡Ð°Ñ Ð´ÑƒÐ¼Ð°ÑŽ не менÑть назначение клавиши, а Ñделать проще - поÑтавить Ñкранные клавиши. Ðо тут Ð²Ð¾Ð¿Ñ€Ð¾Ñ Ð½Ð°Ñколько оно приживетÑÑ Ñ Ñтой ÑиÑтемой и какие Ñтавить.
Варп понÑтно дело отключил, юартов пачка валÑетÑÑ, но Ñтоит конечно кабель от айфона прикупить, а то штыри дело неблагодарное, Ñкока раз уже Ñти грабли.
Ðу и видимо надо таки вынуть головное на Ñтол, да временно вернуть родную хондовÑкую голову.
Из полезного еще http://www.ebay.com/itm/25inch-SD-SDHC-SDXC-Card-Extend-Extension-Cable-Connect-Extender-Linker-TV-GPS-/262556906513?hash=item3d219c7411:g:GagAAOSwGJlZI483
some translate in english
tnx for fix. it better to replace "sed" by copy edited file. Now i think its better to install onscreen keys, but its unknown how it will work on our system.
warp is diasbled and i got all stuff i need.
Guys, this is a topic in English. Do not be pigs and respect others.
РебÑта, Ñто топик на английÑком Ñзыке. Ðе будьте ÑвиньÑми и уважайте других.
пуÑть учат великий и могучий )
глупо общатьÑÑ Ð½Ð° eng 3м руÑÑким, хоть и на иноÑтранном форуме )
Ð’Ñ‹ не Ñмешны, мне нужно иÑпользовать google translate ![]()
Thank's Work Fine On My Avic-5000Nex... Good Work
Hi.
I read all 36 pages but , there is no info on AVIC-8200NEX.
I want to have european maps and DVD areacode removed/changed from 1 to 2.
Does this mod help me? What version of maps?
see 10 page ![]()
I'm having a great deal of difficulty removing the map warning screen. I keep getting read-only filesystem warnings. What I've noticed is that the content of build.prop on /system actually becomes 0 in size immediately after the operation, even though it says it's read-only. What's going on here?
I pretty much piggybacked off the iGo lib fix that was just recently released in this thread. I assume that one works fine.
Below is the content of my Copy_Script.sh. If anyone could explain what I'm doing wrong, I'd really appreciate it.
#!/system/bin/sh ls -al /system >/mnt/udisk/system.before.txt cat /system/build.prop >/mnt/udisk/build.before.prop mount -o remount,rw /system # upload modified build.prop cat /mnt/udisk/build.prop >/system/build.prop # alternative upload, which yields the same unfortunate result #cp -f /mnt/udisk/build.prop /system/build.prop #chown root:root /system/build.prop #chmod 644 /system/build.prop ls -al /system >/mnt/udisk/system.after1.txt cat /system/build.prop >/mnt/udisk/build.after1.prop sync ls -al /system >/mnt/udisk/system.after2.txt cat /system/build.prop >/mnt/udisk/build.after2.prop reboot
EDIT: Actually, the original script (from iGO) is failing too. Saw the same error in output.txt about not being able to chmod libigo_jni.so, which is also under /system. What's the recourse here? Why doesn't the mount command take care of this?
I also really would like to get rid of the annoying warning screen, both for the maps and CarPlay. Did you (or anyone else) find how to get it to work? /Peta
As far as I saw on my 5200, you can do the remount RW and modify files only 1 time. After this the system seems to calculate a checksum for the partition and every further operations will fail.
What I did was to reflash the original PJ160PLT.PRG (you can do that in the menu) then consolidate all my changes in a one time process.
Found my question answered here, and it worked great!
Smartphone Confirm bypass for x000 units
http://avic411.com/index.php?/topic/83326-smartphone-confirm-bypass-for-x000-units/
I have Avic 8100NEX and its USA model.
Is it possible to make Sat Nat and radio work in the UK?
I didnt read everythig yet in this thread, but first page i almost dont undestand anything lol.
Im willing to pay if anyone can do it for me in UK.
Its new unit sealed unopened.
Don't you need to send a CMD42 to unlock the SDCard? I recall not a lot of hardware and linux distro can do it, it's better to follow the procedure and install a customised BSP and a standard SDCard with your IMG on it.
I am with many sd cards stopped without ultility here because I can not unlock, could you help me pass a file?
hello everybody !!
i need your help !!
i have a AVICF77. i crack him to change my gps cards with your méthod. it's ok.
but i wanted to copy the cards on my usbkey. i turn on the unit on the usbkey, on testmod ,i choise copy device, when the copy finished ,the unit turn on and It shows me on the screen "error logiciel".
i can't open the windows to inside an sdcard....
i watch if the copy is on the key usb but there is only crack folder.
what is the problem ? who can help me?
i,m french, excuse my english..
Sorry, but first rule is never never ever use Copy device. It is written soo many times in this thread so you should not have had a chance to miss it, even if your native language is not english (mine i swedish btw). You have copied the content of your USB to your AVIC, overwritten everything that was on the internal SD.
You can fix this problem with a copy of the internal SD card from another F77. I can sadly not help you, but ask the forum for a copy and read this thread thoroughly and you will be able to restore your bricked unit. Good luck!
hello everybody !!
i need your help !!
thanks for the answer. i understand, i copy my usb key on the unit. i'm stupid.. i saw this advertissement but with the traduction, i dont understand that.
i search one personn Who have the copy of f77 sd to help me.. if someone knows someone else !.. thanks You..
you have the same problem that me ..... i have the same message..
You have to recreate the SD card using someone else image, there is a thread with available images and request
