The AVIC Development Mod
By bass_rock · Aug 10, 2015in NEX Series💬 720 posts👁️ 589,887 views
Page 23 of 29
Posted Jul 17, 2017 · 15:40 UTC#551
there is image in a thread ? where ? i don't find it ....
Posted Jul 17, 2017 · 17:10 UTC#553
thanks,
when i'll find for my f77 , i upload it and add link;
Posted Jul 17, 2017 · 19:21 UTC#555
How do I make this image? I put it in an usb and I do what? could you explain me. Thank you
If you find an image for your device, F77 or something, it will be about 8GB or 16GB, write it to an SD Card and replace the SD card in your device
Posted Jul 17, 2017 · 19:35 UTC#556
Can not you use the same sd card?
Posted Jul 17, 2017 · 19:48 UTC#557
yes of course
Posted Jul 17, 2017 · 19:57 UTC#558
yes of course
So I have to download the image on the pc then go to a USB and then put it in the usb2 port and I can copy it to the sd card of the device?
Posted Jul 17, 2017 · 20:08 UTC#559
If you cannot access the "test menu" because you overwrote something (like the kernel) in your unit and the displayed message comes from the bootloader, then you have to put the SD card in your PC and copy the raw image from your PC on the SD card. You have to open your unit to extract the SD card from it.
Posted Jul 17, 2017 · 20:12 UTC#560
By putting the SD card in my pc, it gives no signal. There is no driver for the SD card. Can not shake the SD card?
Posted Jul 17, 2017 · 20:19 UTC#561
No because it is password protected, take a new one
Posted Jul 17, 2017 · 20:30 UTC#562
So in that case will not I be able to unlock?
Posted Jul 18, 2017 · 15:50 UTC#563
FAQs
What does this mean?
1. WARP can be disabled
2. Internal SD Password Lock can be removed (Requires a new sd card afterward)
3. Debug can be enabled.
4. We can modify the Internal SD Card by inserting it into the computer with the above turned on.
5. Custom ROM development can truly begin.
What the heck is warp?
A: It's the hibernate function.  At the factory, they hibernate the device and every time it turns on it uses this information. This prevents us from loading custom firmware because the deck chooses this memory loaded information over the filesystem changes that we create.
What is the BSP?
A: The BSP is a special are in the NOR Memory (different from the SD Card), where U-Boot, EasyRecovery and all the low-level U-Boot settings are located. It is 84 bytes in size and has two copies in case one fails.
What is NOR Memory?
A: The NOR Memory is an area separate of the SD Card that contains, boot settings, recovery partitions and the boot loader.
Why do we need to remove the SD Card Password?
A: The Pioneer dev's decided to put a hardcoded password lock onto the Internal System SD Card that prevents you from just putting it into your computer. By removing it we allow the ability to remove the internal SD and to put it into any computer to modify the Platform files, without having to run an Update.
What is the SD Card password?
A: LKPFeD4BcVzESR2Y
Can't we just unlock the password on a computer and not change the BSP?
A: Yes, and no. In order to unlock the SD card you need to have the ability to run CMD42 on the SDCard which most linux distributions and os’s do not have.
What is Debug mode?
A: The Debug mode outputs more logs and turns on a console port somewhere on the device. We still do not know where that is. NOTE: It is most likely possible to patch the kernel to use the iDataLink port as a UART console for ADB.
What are the device paths if I want to change the backup or restore locations?
A:
/mnt/udisk/ for USB1
/mnt/udisk1/ for USB2
/sdcard/ for external sdcard
What is the Partition Map look like?
A: For a 8GB internal SD Card (AVIC 5000) it looks like this:
Disk /dev/mmcblk1: 8069MB
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Number  Start   End     Size    Type      File system                          MY Findings:
 1      538MB   548MB   10.5MB  primary   android      boot A                  BOOT/BOT.PRG
 2      548MB   559MB   10.5MB  primary   android      boot B
 3      559MB   1830MB  1271MB  extended
 5      559MB   590MB   31.5MB  logical   android      recovery A              RECOVERY/REC.PRG
 6      590MB   622MB   31.5MB  logical   android      recovery B              RECOVERYEASY/ERY.PRG ?
 7      622MB   1159MB  537MB   logical   ext4         /system                 PLATFORM/PLT.PRG
 8      1159MB  1293MB  134MB   logical   ext4         /cache
 9      1293MB  1830MB  537MB   logical   ext4         /data                   USERDATA/DAT.PRG
 4      1830MB  7702MB  5872MB  primary   ext4         /extdata
How can I unlock my SD Card?
A: Follow the following steps:
1. Set SDCard password in BSP
2. Place Test Key N3 on USB stick
3. Power on unit
4. When screen goes black turn unit off and back on
5.  When unit shows Mode Change OK screen, remove the SDCard and power off the unit.
Update 8/16/2015: Added how to unlock an SD Card.
Could you give me more information on how to unlock the sd card of the avic
device by computer? What system / program can I perform this unlock?
Posted Jul 18, 2017 · 16:05 UTC#564
A lot of this info comes from https://fail0verflow.com/blog/2014/enhancing-the-avic-5000nex/ (there's a part 2 too).
I never unlocked my SD card, the procedure is there but somewhat cryptic I agree... Put the password in the BSP, boot the unit with a USB with the N3 key, someone who know better could put better step by step explanations.
Posted Jul 18, 2017 · 18:53 UTC#565
In this sait only speaks as it does via JTAG. I want to see if anyone can unlock via any operating system. Type linux command
Posted Jul 19, 2017 · 15:18 UTC#566
Hi guys.
Nice work, not a Pioneer owner myself so I cannot test/try/brake/etc I have scanned through the topic but I couldn't see an exact answer.
Can you install any app on the units now? If yes can you also remove any of the factory apps like (Android Auto)?
I'm curious to find out if the factory provide Android Auto app can be replaced with my version ( http://forum.xda-developers.com/general/paid-software/android-4-1-headunit-reloaded-android-t3432348 ) which potentially could give a few benefits over the standard version:
1) It supports unlimited browsing
2) It allows you to connect to AA over Wifi as well.
If anybody is interested in trying it out give me a shout on [email protected] and I can send you a copy of the apk for trial purpose.
Posted Jul 21, 2017 · 09:52 UTC#567
So if I can find and put a 4100 IMG sd card into my 4000 nex it will be a 4100nex? Android auto and everything will work ?
Posted Aug 10, 2017 · 09:22 UTC#568
If someone is kind wnough to explain me how to do it, I could provide him with an image backup for the F77 DAB unit, but I don't know yet how to do it
Posted Aug 13, 2017 · 07:39 UTC#569
Hello. I have a F60DAB with firmware 1.15. Is there already a test mode with Igo Patch?
Posted Aug 15, 2017 · 07:57 UTC#571
I have an F77DAB currently running 1.05 with patched iGo and OK button bypass.
If I update to 1.10 can I install the same patch (only version I can find just states for 1.05) using the new test mode key?
Posted Aug 15, 2017 · 15:04 UTC#572
yes
Posted Aug 19, 2017 · 14:28 UTC#573
Hi experts...
has anyone tried to install a Mexico map on an avic 8100????
Best
Klaus
Posted Sep 02, 2017 · 19:01 UTC#574
Hi Guys, i can t paste new map on my avic F60 Dab, he says Failed to paste....Patch ok with good version, and copy ok , but i can t paste new file in exdata/igo/content...
helpppppppppppppppppp :shock:
Hi.
I Have same problem. I can copy all other files, but not Maps or licenses! I get "failed to paste" . Are those content/Maps and content/licence folders somehow write protected? I got to delete all files from content/map folder..
I did not delete licence.
My unit is 8200
script worked beautifully. I get "OLD" and "NEW" .TXT files.
I am trying to copy Map files that I downloaded from here:
https://www.gpspower.net/igo-maps/345485-igo-r3-europe-here-2017-q2.html
EDIT: My firmware is 1.01
Edited Sep 03, 2017 by jhalttu
Posted Sep 03, 2017 · 11:44 UTC#575
Hi.
My unit is 8200
i deleted the folders (maps and lic)  first, then re-added folder incl new files
Page 23 of 29
