2015 European Map Update for Pioneer AVIC-F30BT, F930BT, F9310BT, F40BT, F940BT, F840BT, F8430BT
By Flomsen · Aug 16, 2015in Hacks/Mods💬 789 posts👁️ 337,085 views
Page 11 of 32
Posted Sep 05, 2015 · 21:24 UTC#251
I have updated 2 f930bt systems.
Both systems updated perfect 45 min of time for 1 system with no problems.
Only prg0 renewell crack like monsterf9
My and my dad are very happy now.
Thnx flomsen,cell, and monst
did you just edit the one hex file or did you do it for both my dad has the same system as well was gonna go through the process of copying the file off his but it if works for both i wont have to ?
Posted Sep 06, 2015 · 06:21 UTC#252
I edit both system the dll file
Posted Sep 06, 2015 · 08:58 UTC#253
Has anyone noticed any other improvements since updating to 2015 maps?
Eg speed improvements, etc.
Also, does this update just update the maps or does it update anything else?
Posted Sep 06, 2015 · 10:37 UTC#255
Help Me!!!
When I enter the password the system asks me to reinsert and uploading is halted.
Posted Sep 06, 2015 · 17:29 UTC#257
Thank you  :-P
seems to be a lot faster / smoother navigating through the menus
Posted Sep 06, 2015 · 20:19 UTC#258
By the way, NAVI.exe from 2013 for skip warning works fine in 2015 as well. Only remove NAVI.exe from USER\PRG0\APL in your 2015 version and copy the NAVI.exe (pionnara mod version for 2013 version).
Personally I would not do this as you are then effectively rolling back any bugfixes/enhancements made to the 2015 version.
Posted Sep 06, 2015 · 21:39 UTC#259
if USER\PRG.FLG file exists you have to patch USER\PRG1\APL\Navi.exe.
Hex edit navi.exe 6.0 @ offset BEC64 0500000A -> 0000A0E1
Posted Sep 06, 2015 · 22:47 UTC#260
Hi there,
I can confirm this works on the F30BT.
As per above, the process I followed was:
1. Run 'supertestmode' from a freshly formatted (FAT32) SD card.
2. Copy RenewallFlib.dll from USER\PRG0\APL and USER\PRG1\APL to SD root.
3. Remove SD card from AVIC and edit RenewallFlib.dll from USER\PRG0\APL and USER\PRG1\APL as per monsterF9's guidance on a PC.
4. Insert SD card with edited RenewallFlib.dll from USER\PRG0\APL and USER\PRG1\APL back into AVIC.
5. Delete RenewallFLib.dll from USER\PRG0\APL and USER\PRG1\APL on AVIC.
6. Paste edited RenewallFlib.dll from SD card into USER\PRG0\APL and USER\PRG1\APL.
7. Remove SD card format it and copy Update, FIRMWARE and CARDINFO.cif onto it.
8. Insert SD card into AVIC and turn on ignition. Follow onscree instructions where you'll be prompted to enter a password. Enter PASSWORDPASSWORD
9. Sit back and wait for 25 minutes whilst the unit updates.
I needed to edit RenewallFlib.dll from  USER\PRG1\APL.
Thanks for support.
If there any questions, feel free to tell me ;)
BT,
Daniel
 I tried this method to skip the warning screen after successfully installing 2015 maps. However, it doesn't seems to be working and I keep getting the warning screen regardless.
Any suggestions?
Posted Sep 07, 2015 · 07:03 UTC#261
Arh, I'll try that.
Cheers
Posted Sep 07, 2015 · 09:03 UTC#262
You got a point!
Posted Sep 07, 2015 · 11:48 UTC#263
I don't know but, everything goes fine ....
Posted Sep 07, 2015 · 11:49 UTC#264
Any suggestions?
Try in PRG1
Posted Sep 07, 2015 · 14:20 UTC#265
Found a bug with the new update on the f930bt i turn the car off when listening to music playing turn it back on music is paused every time
Posted Sep 07, 2015 · 20:04 UTC#266
I have a confirmed F840BT here. (OEM version of F940BT)
The update took 22 minutes and everything went well.
I would like to thank Flomsen for the map files and monsterF9 for the hex guide.
Thanks guys! :)
Posted Sep 07, 2015 · 20:27 UTC#267
Anyone else had the paused music problem I mentioned before ?
Posted Sep 08, 2015 · 05:47 UTC#268
Today i'm gonna find out.. I'll let you know.
Edited Sep 08, 2015 by JazzySOB
Posted Sep 08, 2015 · 08:27 UTC#269
Flomsen, Can you send me the password?
thanks a lot!
Posted Sep 08, 2015 · 09:00 UTC#270
stop messing with all of that, there is an easier way
just be patient ;)
Pionara!!!
Where are you?
Posted Sep 08, 2015 · 09:20 UTC#271
Updated F940BT:
- Replaced RenewallFlib.dll from USER\PRG1\APL
- Replaced Navi.exe from USER\PRG0\APL
Thanks to all.
Posted Sep 08, 2015 · 09:46 UTC#272
thanks a lot!
Posted Sep 08, 2015 · 10:50 UTC#273
1st post is updatet.
Need some info if it works on your devices, so I can update the first post.
About the Voice data (TTS) I will post a link soon to.
Sorry for my English-speaking :/
Flomsen
Edited Sep 08, 2015 by Flomsen
Posted Sep 08, 2015 · 11:18 UTC#274
Flomsen
 Hi, the new link in Google Drive to download zip's file is only viewable but not downloadable...
Posted Sep 08, 2015 · 11:34 UTC#275
Try now
Page 11 of 32
