2015 European Map Update for Pioneer AVIC-F30BT, F930BT, F9310BT, F40BT, F940BT, F840BT, F8430BT
By Flomsen · Aug 16, 2015in Hacks/Mods💬 789 posts👁️ 337,085 views
Page 10 of 32
Posted Sep 05, 2015 · 06:47 UTC#226
Hello, i'm very confused. Everything is prepared for the update. The sd Card is correctly formated( i still used this card for the 2013 update too). The root of the card looks like
FIRMWARE
Update
If i put the card in the Slot and Start the engine, the Radio normaly starts, no update question is coming? Parking break activated
Anybody can help? It's the f930bt
Sry for my bad english
Thx
Have you included > CARDINFO.cif
Posted Sep 05, 2015 · 07:56 UTC#227
I tryed it with & without Cardinfo..... Nothing happens...... What is with verfinfo file?
Posted Sep 05, 2015 · 08:18 UTC#228
Hi there,
I can confirm this works on the F30BT.
As per above, the process I followed was:
1. Run 'supertestmode' from a freshly formatted (FAT32) SD card.
2. Copy RenewallFlib.dll from USER\PRG0\APL and USER\PRG1\APL to SD root.
3. Remove SD card from AVIC and edit RenewallFlib.dll from USER\PRG0\APL and USER\PRG1\APL as per monsterF9's guidance on a PC.
4. Insert SD card with edited RenewallFlib.dll from USER\PRG0\APL and USER\PRG1\APL back into AVIC.
5. Delete RenewallFLib.dll from USER\PRG0\APL and USER\PRG1\APL on AVIC.
6. Paste edited RenewallFlib.dll from SD card into USER\PRG0\APL and USER\PRG1\APL.
7. Remove SD card format it and copy Update, FIRMWARE and CARDINFO.cif onto it.
8. Insert SD card into AVIC and turn on ignition. Follow onscree instructions where you'll be prompted to enter a password. Enter PASSWORDPASSWORD
9. Sit back and wait for 25 minutes whilst the unit updates.
I needed to edit RenewallFlib.dll from  USER\PRG1\APL.
By the way, NAVI.exe from 2013 for skip warning works fine in 2015 as well. Only remove NAVI.exe from USER\PRG0\APL in your 2015 version and copy the NAVI.exe (pionnara mod version for 2013 version).
Thanks for support.
If there any questions, feel free to tell me ;)
BT,
Daniel
I followed the above process, I downloaded the map files from here> https://docs.google.com/uc?id=0B3I8g0z3jQBJT3k1RGVsU0QtY3M&export=downloadand I used http://mh-nexus.de/en/downloads.php?product=HxD for the Hex editiing all worked fine
Posted Sep 05, 2015 · 08:58 UTC#229
During the process of copying the RenewallFlib.dll from USER\PRG0\APL, I somehow managed it to delete it from the unit. But I did manage to make a copy of the file from USER\PRG1\APL. Is this the same file? So when I edit the extracted file, can I copy the same file back to PRG0 and PRG1? Or are they two different files in the first place?
If so, how can I get my RenewallFlib.dll from USER\PRG0\APL back?
edit: unit is a F840BT
Edited Sep 05, 2015 by PatrickPR
Posted Sep 05, 2015 · 10:30 UTC#230
I used USER\PRG1\APL for both of mine and it worked fine
Edited Sep 05, 2015 by bertie21
Posted Sep 05, 2015 · 10:42 UTC#231
Must the verinfo.dat replaced with the one from the 2013 update @ the avic f930bt?
Posted Sep 05, 2015 · 10:48 UTC#232
No verinfo.dat not replace.
You need the update firmware and originel cardinfo.
Posted Sep 05, 2015 · 11:22 UTC#233
Confirmed update from 5.0 to 6.0 on F9220
Apply these changes to your RenewallFlib.dll on your Unit:
Offset 000019F0:  0350A0E3 replace with 0050A0E3
Offset 00001A10:  0350A0E3 replace with 0050A0E3
Offset 00001AD8:  0350A0E3 replace with 0050A0E3
Offset 00001C1C:  0250A0E3 replace with 0050A0E3
Offset 00001C24:  0150A0E3 replace with 0050A0E3
Offset 00001A3C:  0350A0E3 replace with 0050A0E3
Users with units older than F30BT will have to use cardinfo from this post:
I'm trying to edit the RenewellFlib.dll that I extracted from USER\PRG0\APL, but the only values from monsterF9's post that I can find are at Offset 000019F0 and Offset 00001A10. Do I have to replace only these two?
Could someone upload they're working version of the RenewellFlib.dll for a F940/F840?
Posted Sep 05, 2015 · 11:49 UTC#234
Okay, no i see the update Mode.... But i think i have to prepare the other dll in prg1 too.
Is it the same File or can i copy the File from the prg0 folder directly to the prg1 folder?
Posted Sep 05, 2015 · 12:03 UTC#235
I'm waiting on pionara's version
Posted Sep 05, 2015 · 12:11 UTC#236
hi all
what is the zip code?
someone can send me?
thanks
Posted Sep 05, 2015 · 12:39 UTC#237
@PatrickPR: as i explained every unit has its own dll. It´s unique to every serial number and i think this is the reason why you normaly have to enter your serial number to get the password for the buyed version of the update,
You could use my script to patch your dll.
@sstroehl: if i correctly remember it´s not the same version. Because there is only  1 prg folder active. in the each prgfolder is a EU090APL.HTM file. copy this file form the Avic a take a look at these file. If you have the 2013 Version installed
there have to be a line like "Release Version : 5.000000". If its 5.0000 then this is the folder where you have to patch the dll. if you look to the other prg folder there should be the same file bur with realease version 4.0000. After the update the release version is 6.0000. you also should use the cardinfo.cif which is in the download package from flomsen or bolle.
Posted Sep 05, 2015 · 12:48 UTC#238
00001AD8 is found by locating 00001AD0 move along to column 08 then change the values there.
Each of the offsets end with the column number
Offset 00001C1C:  0250A0E3 replace with 0050A0E3            column 0C
Offset 00001C24:  0150A0E3 replace with 0050A0E3             column 04
Offset 00001A3C:  0350A0E3 replace with 0050A0E3            column 0C
Posted Sep 05, 2015 · 12:52 UTC#239
Hi there,
Thanks for support.
BT,
Daniel
Updating F940BT RIGHT NOW
i moodified both RenewallFlib.dll and it accepted the Password. Its right now on 27% updating...
i will be updating this post for more informations....
56% -----> 80%
Confirmed update on F940BT with this tutorial...
For questions in: Portuguese, German and English, send me a PVT
Edited Sep 05, 2015 by helder89
Posted Sep 05, 2015 · 13:12 UTC#240
Hello,
im new in this board,
can someone send me the passwort for the file?
forgive my bad english, i`m from germany.
have a nice day :mrgreen:
alberto
Posted Sep 05, 2015 · 14:22 UTC#241
I changed the dll from prg1 folder and now my radio said "wrong Format, pls contact Service center".... I think i changed the dll incorrect in the hex app. Anybody can help?
Posted Sep 05, 2015 · 14:22 UTC#242
I just finished updating my F840BT. I copied the modified RenewallFlib.dll (that I extracted from USER\PRG1\APL) to USER\PRG0\APL and USER\PRG1\APL. After entering the password as mentined in this topic, the unit started updating. System version is now 6.0000, and all the settings are remained.
Confirmed update on F840BT. Thanks for all the help.
Posted Sep 05, 2015 · 16:30 UTC#243
Everything done. Perfect. Thx to all helping members
Posted Sep 05, 2015 · 17:12 UTC#244
Hi there,
How can I get speedcams in my Avic F30BT?? Without pay of course 8)
I was seeing on Internet and I found nothing.
Thanks in advance :)
Edited Sep 05, 2015 by F920bt
Posted Sep 05, 2015 · 17:26 UTC#245
LOL
Posted Sep 05, 2015 · 17:28 UTC#246
There is people who have some moral :)
Posted Sep 05, 2015 · 17:29 UTC#247
F930BT
I edited both files dll (PRG0 and PRG1) but system doesn't accept the password....
Posted Sep 05, 2015 · 17:39 UTC#248
I have updated 2 f930bt systems.
Both systems updated perfect 45 min of time for 1 system with no problems.
Only prg0 renewell crack like monsterf9
My and my dad are very happy now.
Thnx flomsen,cell, and monsterf9
Posted Sep 05, 2015 · 18:05 UTC#249
stop messing with all of that, there is an easier way
just be patient ;)
Pionara, I was afraid you left forever. I guess a cracked VERINFO.DAT file v2015 is being prepared. I can not wait to use it !
Posted Sep 05, 2015 · 19:12 UTC#250
pionara is working on it but he is very busy at the moment. He let me know if he find the way to crack, so plz wait and I let you know!! All credits to pionara!!!
Page 10 of 32
