so, i made a litte script to patch your own Renewallib.dll
You have to be use autoit for this. I could make a exe-file for patching, but since i never trust download exe-files i decieded to post the source
ATTENTION: Backup your original DLL !!!! Every Avic has its own DLL !!!
Bevore pasting the patched DLL back to your AVIC be sure to delete the DLL in the AVIC, because Testmode do not overwrite files sometimes (that was my mistake an i wasted 4 hours on this issue) !
Functions are copied from Autoit forum and only the specific lines for patching are from me
Here we go:
#include <MsgBoxConstants.au3>
#include <FileConstants.au3>
#include <WinAPI.au3>
Local Const $sMessage = "Select RenewalIFLib.dll"
Local $sFileOpenDialog = FileOpenDialog($sMessage, "c:\##\", "(RenewalIFLib.dll)", $FD_FILEMUSTEXIST)
If @error Then
MsgBox($MB_SYSTEMMODAL, "", "No file were selected. End.")
FileChangeDir(@ScriptDir)
Else
$sFileOpenDialog = StringReplace($sFileOpenDialog, "|", @CRLF)
FileCopy($sFileOpenDialog, $sFileOpenDialog & ".original")
$bData = _HexRead($sFileOpenDialog, 0x19F0, 4)
if $bdata <> "0x0350A0E3" Then
MsgBox($MB_SYSTEMMODAL, "", "Error")
Exit
EndIf
_hexwrite($sFileOpenDialog, 0x19F0, Binary("0x0050A0E3"))
$bData = _HexRead($sFileOpenDialog, 0x1A10, 4)
Exit
EndIf
_hexwrite($sFileOpenDialog, 0x1A10, Binary("0x0050A0E3"))
$bData = _HexRead($sFileOpenDialog, 0x1AD8, 4)
Exit
EndIf
_hexwrite($sFileOpenDialog, 0x1AD8, Binary("0x0050A0E3"))
$bData = _HexRead($sFileOpenDialog, 0x1A3C, 4)
Exit
EndIf
_hexwrite($sFileOpenDialog, 0x1A3C, Binary("0x0050A0E3"))
$bData = _HexRead($sFileOpenDialog, 0x1C1C, 4)
if $bdata <> "0x0250A0E3" Then
Exit
EndIf
_hexwrite($sFileOpenDialog, 0x1C1C, Binary("0x0050A0E3"))
$bData = _HexRead($sFileOpenDialog, 0x1C24, 4)
if $bdata <> "0x0150A0E3" Then
Exit
EndIf
_hexwrite($sFileOpenDialog, 0x1C24, Binary("0x0050A0E3"))
MsgBox($MB_SYSTEMMODAL, "", "RenewalIFLib.dll patched!")
EndIf
Func _HexWrite($FilePath, $Offset, $BinaryValue)
Local $Buffer, $ptr, $bLen, $fLen, $hFile, $Result, $Written
;## Parameter Checks
If Not FileExists($FilePath) Then Return SetError(1, @error, 0)
$fLen = FileGetSize($FilePath)
If $Offset > $fLen Then Return SetError(2, @error, 0)
If Not IsBinary($BinaryValue) Then Return SetError(3, @error, 0)
$bLen = BinaryLen($BinaryValue)
If $bLen > $Offset + $fLen Then Return SetError(4, @error, 0)
;## Place the supplied binary value into a dll structure.
$Buffer = DllStructCreate("byte[" & $bLen & "]")
DllStructSetData($Buffer, 1, $BinaryValue)
If @error Then Return SetError(5, @error, 0)
$ptr = DllStructGetPtr($Buffer)
;## Open File
$hFile = _WinAPI_CreateFile($FilePath, 2, 4, 0)
If $hFile = 0 Then Return SetError(6, @error, 0)
;## Move file pointer to offset location
$Result = _WinAPI_SetFilePointer($hFile, $Offset)
$err = @error
If $Result = 0xFFFFFFFF Then
_WinAPI_CloseHandle($hFile)
Return SetError(7, $err, 0)
EndIf
;## Write new Value
$Result = _WinAPI_WriteFile($hFile, $ptr, $bLen, $Written)
$err = @error
If Not $Result Then
Return SetError(8, $err, 0)
EndIf
;## Close File
If Not $Result Then Return SetError(9, @error, 0)
EndFunc
Func _HexRead($FilePath, $Offset, $Length)
Local $Buffer, $ptr, $fLen, $hFile, $Result, $Read, $err, $Pos
If $fLen < $Offset + $Length Then Return SetError(3, @error, 0)
;## Define the dll structure to store the data.
$Buffer = DllStructCreate("byte[" & $Length & "]")
;## Open File
$hFile = _WinAPI_CreateFile($FilePath, 2, 2, 0)
If $hFile = 0 Then Return SetError(5, @error, 0)
$Pos = $Offset
$Result = _WinAPI_SetFilePointer($hFile, $Pos)
$err = @error
Return SetError(6, $err, 0)
EndIf
;## Read from file
$Read = 0
$Result = _WinAPI_ReadFile($hFile, $ptr, $Length, $Read)
$err = @error
If Not $Result Then
EndIf
;## Close File
If Not $Result Then Return SetError(8, @error, 0)
;## Return Data
$Result = DllStructGetData($Buffer, 1)
Return $Result
EndFunc
Func _HexSearch($FilePath, $BinaryValue, $StartOffset = Default)
Local $Buffer, $ptr, $hFile, $Result, $Read, $SearchValue, $Pos, $BufferSize = 2048
;## Parameter Defaults
If $StartOffset = Default Then $StartOffset = 0
If $StartOffset > $fLen Then Return SetError(2, @error, 0)
If Not IsNumber($StartOffset) Then Return SetError(4, @error, 0)
;## Prep the supplied binary value for search
$SearchValue = BinaryToString($BinaryValue)
$Buffer = DllStructCreate("byte[" & $BufferSize & "]")
;## Open File
$hFile = _WinAPI_CreateFile($FilePath, 2, 2, 1)
$Result = _WinAPI_SetFilePointer($hFile, $StartOffset)
$err = @error
Return SetError(5, $err, 0)
EndIf
;## Track the file pointer's position
$Pos = $StartOffset
;## Start Search Loop
While True
;## Read from file
$Read = 0
$Result = _WinAPI_ReadFile($hFile, $ptr, $BufferSize, $Read)
$err = @error
If Not $Result Then
EndIf
;## Prep read data for search
$Result = BinaryToString($Result)
;## Search the read data for first match
$Result = StringInStr($Result, $SearchValue)
If $Result > 0 Then ExitLoop
;## Test for EOF and return -1 to signify value was not found
If $Read < $BufferSize Then
Return -1
EndIf
;## Value not found, Continue Tracking file pointer's position
$Pos += $Read
WEnd
;## Close File
If Not $Result Then Return SetError(7, @error, 0)
;## Calculate the offset and return
$Result = $Pos + $Result - 1
Return $Result
EndFunc
