2015 European Map Update for Pioneer AVIC-F30BT, F930BT, F9310BT, F40BT, F940BT, F840BT, F8430BT
By Flomsen · Aug 16, 2015in Hacks/Mods💬 789 posts👁️ 337,085 views
Page 17 of 32
Posted Sep 16, 2015 · 19:10 UTC#401
Big thanks to all
The update worked perfectly on a F930BT but i've lost my speedcam. Have you some link for me
Edited Sep 16, 2015 by Tango
Posted Sep 16, 2015 · 20:32 UTC#402
For the f930bt is very simpel. Download the 2015 map from flomsen put the the maps firmware map update and cardinfo on the root from the sd card
You only need another cardinfo when you have a pioneer system older then the f30bt/f930bt system
Confirmed - the update on F930BT went smoothly - only challenge I had was with the copy&paste function when being in supertestmode to exchange the lib file - thank you all for your contributions!
Posted Sep 16, 2015 · 21:29 UTC#403
Can I update my Avic F20BT with F5.0?
Yes you can , i updat my AVIC F20BT :D
1. dowload "2015_European_Map_Updat_for_Pioneer" and copy both folder FIRMWARE, UPDATE and file CARDINFO.cif on the root of the SD card.
2. replace CARDINFO.cif  with this one : http://s000.tinyuplo...814939960980540 (Here the modded CARD.INFO file, 2015 edition for F20/ F920 / F9210 / F9220)
3. replace VERINFO.DAT by this one http://s000.tinyuplo...351922687174507, (located on UPDATE folder)
4. Insert SD card into AVIC and turn on ignition. Follow on screen instructions, no password need.
5. Sit back and wait for 25 minutes.
Edited Sep 16, 2015 by hlekinfr
Posted Sep 16, 2015 · 22:51 UTC#404
 Hallo sory for my english,then'ks  Flomsen for this update...
 Meny times i wait this update?ang now this take :mrgreen:,I am doing this job a long time ago for my first avic F900 after 930,30 and now F50
I have next questions,will it be possible update my F50 for this map 2015
 Previously, I was able to introduce the cards 2013 even before the official update,but now is not so simple,map is displayed but the search is not working properly and eventually crashes error,impossible to get directions...
    If you have good ideas I will be very grateful :mrgreen:
Posted Sep 17, 2015 · 08:31 UTC#405
Thank you all. Please someone send me the password. Thank you.
Edited Sep 17, 2015 by r4d3n
Posted Sep 18, 2015 · 07:34 UTC#406
Read the first topic and you find the password.
Posted Sep 18, 2015 · 15:28 UTC#407
The update worked perfectly on a F9220BT.
With this easy steps
1) 2015 European Map Update
   (from Flomsen)
2) Changed VERINFO.DAT
   (From Pionara)
3) Changed CARDINFO.CIF
    For those who are wanting to run this on other earlier headunits then try this cardinfo file that Travolta supplied:
Thnx Guys
Posted Sep 18, 2015 · 19:40 UTC#408
Edited Sep 18, 2015 by gemma99
Posted Sep 18, 2015 · 19:47 UTC#409
ok
Posted Sep 18, 2015 · 20:00 UTC#410
someone can give me the password for private?
Posted Sep 18, 2015 · 20:01 UTC#411
If you read the thread, you know where to find the password...
Posted Sep 18, 2015 · 20:04 UTC#412
Posted Sep 18, 2015 · 20:54 UTC#413
Hi Flomsen,
I did as you described in your posts and in my F940BT everything worked at the first try. No has been needed manage TTS files, and all works properly. The iPod icon now appears as a musical note, instead of the old symbol. Nothing new about the bluetooth firmware, is still the same of 2013 upgrade (v.3.32, if I'm not wrong).
II want to say thanks to you for sharing and also to everyone who worked to make available this upgrade. I did a little donation, but surely if all users are doing the same, you can recover the costs.
supergecko
Posted Sep 18, 2015 · 21:19 UTC#414
ok
Posted Sep 18, 2015 · 21:51 UTC#415
I can have the passw. please. Thank you so much :eek:
Posted Sep 19, 2015 · 00:18 UTC#416
so sorry. I did not understand how to F930BT? instructions please ... mount map on sd ..... then? :?
Posted Sep 19, 2015 · 11:05 UTC#417
What is the password of the file ?
thanks
Posted Sep 19, 2015 · 11:33 UTC#418
thanks
What is the password of the file?
You find your answer in my first post ;-)
Posted Sep 19, 2015 · 11:41 UTC#419
I will save the donation to next update there comes out.
And to all who donated big thanks, you will be the first who get next update in first order :-)
Thx again ;-)
Posted Sep 19, 2015 · 12:40 UTC#420
Hey guys,
did you do anything special for the F940BT update? I mean did you run the supertest mode and did you edit the RenewallFlib.dll? And if I need to run the supertest mode how should I do it? Just copy the test.key to the root sd directory or something else?
Posted Sep 19, 2015 · 13:09 UTC#421
thanks for password  :mrgreen:
Edited Sep 19, 2015 by seti75
Posted Sep 19, 2015 · 18:47 UTC#422
is ok for f940bt  ? ( same process ? )
Posted Sep 19, 2015 · 19:03 UTC#423
Flomsen please password
.i registered through the link
Posted Sep 19, 2015 · 19:44 UTC#424
mmmmmmmmmmm.......................
Posted Sep 19, 2015 · 19:47 UTC#425
Official Map update for the following Pioneer device:
- AVIC-F30BT = WORKS AND READY TO INSTALL
- AVIC-F930BT = WORKS AND READY TO INSTALL
- AVIC-F9310BT =WORKS AND READY TO INSTALL
- AVIC-F40BT = WORKS AND READY TO INSTALL
- AVIC-F940BT = WORKS AND READY TO INSTALL
- AVIC-F840BT = WORKS AND READY TO INSTALL
- AVIC-F8430BT = [WORKS AND READY TO INSTALL
Improve the performance of your Pioneer Pioneer'11 - '12 High navigation system with this Pioneer Sat Nav map update, covering 10 988 384 kilometers of road in Europe.
Benefit from updated road data including new motorway junctions, trunk roads and roundabouts as well as adjusted speed limits and turn restrictions.
These features are considered by your Pioneer navigation system to ensure accurate route planning according to your preferences.
The latest POI database will enhance your navigation driving experience.
In this Pioneer map update 4 997 332 Points Of Interest are covered.
These include petrol stations, airports, restaurants and parking facilities.
This navigation product includes 1 SD card 1 CD Voice data (TTS) covering Europe.
This HERE map is compatible with the following Pioneer Sat Nav: Pioneer'11 - '12 High.
In addition to providing updated HERE map data, this update also enables new features such as AppRadio Mode to allow you to display and operate certain iPhone 4/4s apps on the Pioneer Navigation system (for AVIC-F30BT/930BT/9310BT only and if device wasn’t already updated with the 2012 European Map
Update File: Use at Your Own Risk! "Password is in my profile"
Voice Data: TTS
No hacks needs to this files :)
All donation Can be send to PayPal [email protected] ;)
Manual:
Upgrade Instructions and Operation Manual (EN, ES, DE, FR, IT, NL)
Upgrade Instructions and Operation Manual (DA, SV, FI, TR, PT)
Have you questions about to download or install the files use this forum.
Need some help to earn some more space to my family pictures on Dropbox.
I will get 500 MB bonus when you install Dropbox on your computer.
If someone will help me just click on this link thx. https://db.tt/IBq2WHNG
Maybe it give some bonus, have a nice day 8)
Flomsen
You can include AVICF10-BT series
Page 17 of 32
