2015 European Map Update for Pioneer AVIC-F30BT, F930BT, F9310BT, F40BT, F940BT, F840BT, F8430BT
By Flomsen · Aug 16, 2015in Hacks/Mods💬 789 posts👁️ 337,085 views
Page 18 of 32
Posted Sep 19, 2015 · 19:48 UTC#426
Good to hear flomsen, thnx mate
Posted Sep 19, 2015 · 19:48 UTC#427
Posted Sep 19, 2015 · 19:56 UTC#428
I speak of the creation of a standard procedure for F940BT!
do the same as for the f9220 or other?
cardinfo and VERINFO files are not the same
which may explain clearly?
Thank you
Edited Sep 19, 2015 by seti75
Posted Sep 19, 2015 · 20:14 UTC#429
You can include AVICF10-BT series
Okay Thx ;-)
Posted Sep 19, 2015 · 20:15 UTC#430
Thank you
easy. an SD card, at its root, looas copies folders and decompress after you change verinfo.dat by which you have fallen and now this. the password to copy them to a sd you the'll put in a private message.
and you explain me
Edited Sep 19, 2015 by gemma99
Posted Sep 19, 2015 · 21:13 UTC#431
ok gemma99 , mp , thanks.
Posted Sep 20, 2015 · 07:41 UTC#432
Read page 1 and you no where you can find the pasword
Posted Sep 20, 2015 · 10:01 UTC#433
My 930bt is up to date, great! Flomsen you just received a donation ;)
Posted Sep 20, 2015 · 15:03 UTC#434
help. i have the pioneer avic f9310bt unit
i run 2011 maps en the RenewalIFLib.dll i have on the unit dont have the lines to replace.
Offset 000019F0:  0350A0E3 replace with 0050A0E3    this one i have
Offset 00001A10:  0350A0E3 replace with 0050A0E3    this one i have
Offset 00001AD8:  0350A0E3 replace with 0050A0E3    not in my list
Offset 00001C1C:  0250A0E3 replace with 0050A0E3    not in my list
Offset 00001C24:  0150A0E3 replace with 0050A0E3    not in my list
Offset 00001A3C:  0350A0E3 replace with 0050A0E3    not in my list
what now to do?
is there someone that can send me the good file for the 2015 version?
please help
Edited Sep 20, 2015 by kelty
Posted Sep 20, 2015 · 15:26 UTC#435
what now to do?
please help
ok
Edited Sep 20, 2015 by gemma99
Posted Sep 20, 2015 · 15:35 UTC#436
a tutorial with pictures for the various avic would be more than necessary!
no wonder some avic destroy them!
example some say you must change verinfo.dat else say you must change cardinfo.cif
others say that if once was used in the moin testmod, it is impossible to update because it must restore the original configuration in avic !! ?
(I had testmod used for anything else on my F940BT ... which means after some of it is impossible to update the card 2015)
I personally do not do anything more because it's not clear it all !!!
Posted Sep 20, 2015 · 15:55 UTC#437
i dit the update 2015 and dit no editing on the file.
but after 25 min the unit restarts and the 2015 version is working.
thanx all
Posted Sep 20, 2015 · 17:01 UTC#438
My F940BT was new in 2011, I had updated with the 2013 map (in 2013) I also used the testmod (1.4)
to back up files from the avic (which everyone should do before touching his avic)
now I have the card in 2013 for 2 years I wanted to put the card in 2015 but too many uncertainties about what is written here!
so I do nothing, I will wait quelqun spells.
when the idea was that if we used testmod its avic, it is no longer possible to make the updating of the card,
I do not believe it, that the testmod is to save no more (testmod 1.4)
it means that all those people who made the update to the map for 2015 have not backup before?
what risk they took crazy !!!
( exemple for tesmod .... post 133 ...  http://avic411.com/index.php?/topic/81488-2015-european-map-update-for-pioneer-avic-f30bt-f930bt-f9310bt-f40bt-f940bt-f840bt-f8430bt/page-9  )
( tutorial no ok for f940bt  post 138 ,  http://avic411.com/index.php?/topic/81488-2015-european-map-update-for-pioneer-avic-f30bt-f930bt-f9310bt-f40bt-f940bt-f840bt-f8430bt/page-10
to end !...pionara poste 200 -->  http://avic411.com/index.php?/topic/81488-2015-european-map-update-for-pioneer-avic-f30bt-f930bt-f9310bt-f40bt-f940bt-f840bt-f8430bt/page-14
Edited Sep 20, 2015 by seti75
Posted Sep 20, 2015 · 20:59 UTC#439
Some people say that you should not use testmodekey if we want to make a putting has in the daytime,  ... surprising ?...
,I you advice to make a backup complete before doing odd jobs inside the avic!!
I propose you my video when I made the backup of my f940bt, was very slowly to avoid the problems
not attention has my finger!! He  took a blow before :mrgreen:
http://www.wat.tv/video/files-system-backup-avicf940bt-7lzaj_4lu1r_.html
Posted Sep 20, 2015 · 21:02 UTC#440
I can have the passw. please. Thank you so much :eek:
Posted Sep 20, 2015 · 21:07 UTC#441
Please send me the PW for the File.  THX
Posted Sep 21, 2015 · 15:47 UTC#442
Hello everybody,
I've also got a F930BT. On my default startup screen i can't find a version number (except the 2011 copywright thingy)
With testmod i found that my version is 3.0. Can i safely update with the version of Flomsen? of do i need to find my version number on a diffrent way.
BTW. i've copied the userfiles from the avic. Is this enough if i want to restore my system or do i need to have more files?
Thanks in advance from a dutch guy.
Kansloos
Ps. Everybody keep up the good work
Edited Sep 21, 2015 by Kansloos
Posted Sep 21, 2015 · 19:26 UTC#443
Big thanks to Flomsen, Pionara, Monsterf9, Sjarrel and all others!
I updated my F30BT !!!  :-P  :-P
Posted Sep 21, 2015 · 20:15 UTC#444
To those asking for the password, go back to the first post and read it thoroughly!
Flomsen, I'll sign up to DP through your link when I get a spare min  :)
Hello everybody,
Kansloos
I'd also like to know the same things (especially the backup files bit). From what I can gather the 3.0 is the firmware, rather than the map updates? So I assume we still need to do this update. But, I'm new to this so not sure!
Posted Sep 22, 2015 · 05:55 UTC#445
Hi seti75,
There are so many guy's who updated the navigation without any problem. If you have the wrong card info then the update say's this isn't the good card. If you have the wrong verinfo.dat the navigation will ask you about the password. If you had to make an backup of your system the will never release this update in public :)
Posted Sep 22, 2015 · 05:58 UTC#446
Hello everybody,
Kansloos
Heb je dit topic al gelezen of ben je gelijk naar de laastste pagina gegaan? volgens mij heeft iemand versie 3.00 al vernoemd. Check het even
Posted Sep 22, 2015 · 11:15 UTC#447
-->Sjarrel
1) Quelqun wrote, if we once used testmodkey, Impossible to update after-use of testmodekey ?  Truths or false?
    ( I think that it is false).
2)  What is the vérinfo.dat for my f940bt ? A link ?
3) Cardinfo.cif, it is necessary edit or not ?
4) what RenewallFlib.dll ?  Some people say it is necessary to edit ?  Yes ? No ?
5)  sorry , I do not want to kill my avic
Edited Sep 22, 2015 by seti75
Posted Sep 22, 2015 · 15:36 UTC#448
Hello everybody,
Kansloos
Me again, I can now tell you that yes you should be able to safely update with this version. I've just finished doing it and it now says version 6. Just follow the instructions linked to and you should be fine.
Posted Sep 22, 2015 · 19:01 UTC#449
Everybody who is aking for the password should be banned for one week or so...
If you are not able to read, you should not update your unit!
just my 2ct
Posted Sep 23, 2015 · 11:02 UTC#450
-->Sjarrel
Questions no answer! Or then, to make you putting has in the daytime at random without understanding
Page 18 of 32
