sorry for my English.
I want to update my 940bt and 840bt
I did not understand what to do.
Could you help me?
Could you help me?
Hello,
excuse my bad english ...
i have send a private message to Flomsen for PW but it seems not to be here
can someone help me ?
Thank's for all
I don't know if we had any speedcams on it before, we've not long had the unit so haven't looked into everything. I'm trying to work out the speedcam thing at the moment but can't make much sense out of it.
I certainly haven't found an obvious setting for it though, so I'm trying to add them myself as POIs.
Mrt71 says that ca works the detection of radars with f40, that worked before on mine also but since 2/3 month no speedcam
I do not find any more the parameters of setting if you find, or if quelqun knows coment to make?...
I am has the listening
Hm, I had yesterday update the F40BT.
I still could not festellen whether the speed camera warning function.
The Aha app is missing.
Can I Audio via Bloototh with the Samsung Phone mobile play ??​
Read my first post, and you find your answer.Hello,
Thank's for all
Quelqun can give me its "navi.exe" of prg0 ? ( Avif940bt ) I made a false manipulation and I think of having destroyed my navi.exe
I wanted to modify " skip warning "
Thank you
With that , black screen gps --> http://www.zupimages.net/up/15/39/4vsf.jpg
edit: Solved !! I found files nav.exe saving 2013 (similar) , skip warning ok
There is a warning radar problem
Not indicated speedcam !
I updated my f20bt. thanks a lot.
I see the map are 2015, but the map layout and the program are the same then 2013?
There is the possibility to change the screen map during navigation?
There is the possibility to order the mp3 in alphabetical order?
Please can anyone send me the password for the zip file?
hello can you please give me the password of the zip file?
Thanks in advance .
Update File: Use at Your Own Risk! "Password is in my profile"
Seriously people, it's not rocket science!
I think that those who have the last firmware version, cannot have any more the detection of radars!! (speedcams)
What is strange, it is that some people say that that works, but he does not say which is the firmware version
the f940bt and f40bt No detected radar (speedcams)
Before I updated our f930bt I didn't find any option for speedcameras and that was version 3.
I'm still trying to work out if I can have them detected as POIs.
Like you I'd like more information on the whole thing as we've obviously missed something if other people have it working. Maybe it is just our model numbers though?
It's certain !! My Avic F940BT before the radars detected very well
since 2 or 3 months , Before making modify my avic, he stopped to detect radar
Going off topic here but so many comments about this in this thread... From v3 software onwards the AVIC F30/40-BT (930/940) need a 3rd party Database for speed cameras from POIbase.com
You load the database on to your head unit via SD card and then It will alert you. Note the head unit doesn't detect, it just warns you of cameras logged in the database against your GPS location.
That said I used POIbase for a year as I got a free subscription with the satnav. But I ditched it for CameraAlert from Pocket GPS World that runs on my phone and alerts via Bluetooth to the head unit regardless of whether I'm using the satnav or not. Oh and the database is updated weekly and covers Europe... Miles better than POIbase in my opinion.
Thanks very much for this post. I looked into POIBase but decided against it, I have however found another place to get files from. I downloaded them as kml format as the unit reads that format, but I'm not sure if I'm doing it correctly.
Not sure if you can help, but here's what I did -
I used the navgate software on my pc to make the proper folder on the sd card, then put the kml files into it.
When the sd card is in the unit I can select them under the custom poi settings, but the navgate app on there wont read them as there's so many in the file - I realise that the app is only for if I wanted directions to one which I obviously don't, but I wasn't sure if it meant they wouldn't work properly when simply selected as custom POIs.
We haven't been out anywhere near a camera to test it yet, so haven't been able to find out for myself if I've worked it out properly.
Sorry if that didn't make sense, I'm not great at explaining things!
Very interesting!
Or find a link for a tutorial ? ..files...?
tanks
Worked like a charm on my F840BT from 5.0 to 6.0. Thank you.
The solutions to put radars on of other forums, tell to add files in the file APL2.
On the former AVIC there is a file APL2 in them avicf940 f40 it no file APL2 only APL.
I understand nothing! Why that worked before?
If it is necessary to modify something it is in this file RW\POINT (Points of Interest)
I see no something else
Flosmen la password dei zip ? sto cervellando nel primo post....ma non ci arrico...grazie
How are so many people missing this piece of info from the first post?! It's right next to the download link!
Hello guys!
With this update can I use the Appradio with my android device (Samsung galaxy s5)?
Thank you
This is a post for dutch and belgium users that are using speedcams.
http://s000.tinyupload.com/?file_id=09205970760400181779
This is only Holland and Belgium ,
Just put the PC dir on a sd card and insert this in the navigation, just install zwarte punten and the should be in your navigation.
Dus gewoon de map PC kopiëren op een sd en dan de zwarte punten installeren, ik heb het alleen zelf met 6.0 nog niet geprobeerd en hoop dat iemand mij kan vertellen of het werkt ![]()
Nel primo post a circa metà c'è scritto "Update File: Use at Your Own Risk!" subito a fianco più in piccolo è specificato che la parola chiave è visibile nel suo profilo. Per accedere al profilo basta cliccare sulla foto del suo avatar, comparirà una schermata con varie voci, li troverai ciò che interessa a te.
Ciao ciao.
