New Release F20BT F30BT F40Bt F920BT F930BT F940Bt F840BT Etc 2019
By godzilla · Sep 07, 2019in Hacks/Mods💬 236 posts👁️ 197,668 views
Page 5 of 10
Posted May 15, 2020 · 16:43 UTC#101
36 minutes ago, Navigator2017 said:
In my F930BT PASSWORDPASSWORD does not work.
In 2017 I had edited the files RenewallFlib in PRG0 and PRG1.
What is the problem? Thank you.
Me the same, i didn't put the original back... I tried @spoon1
aand now it ask to put again password, like it doesn't accept
Posted May 15, 2020 · 16:45 UTC#102
Hi there, tnx it is ok with @godzilla and thanx for sharing. @spoon1what can i use for the 9220BT?
Im not that handy, i need the document what you post, and is that also for the 9220? and about the dutch file, is that afther te update?
Best regards,
Jan
Edited May 15, 2020 by brommie
Posted May 15, 2020 · 17:03 UTC#103
@spoon1Thank you for the quick respons,  so i need the link from godzilla and  can use your guide? the card info frrom the car i need? or is that thje old onefrom 2017 form the site?
sorry for al these questions
Posted May 15, 2020 · 18:07 UTC#104
2019 Bluetooth ver 3.32 - 2017 bluetooth ver 3.32   It's ok ?
Posted May 15, 2020 · 18:40 UTC#105
This is 8.000
Edited May 15, 2020 by bubuu77
Posted May 19, 2020 · 22:00 UTC#106
Quick response:  I updated my father's AVIC-F930BT this evening, and everything was successfull (I'll share a more detailed document accompanied by screenshots later on). So please be informed that - in my case at least - it accepted the 'PASSWORDPASSWORD' combination without complaining, and completed the upgrade in about 20-30 minutes time.  Perhaps it is worth mentioning that I got a different message about the password. In Dutch of course, and it stated 'Geef het wachtwoord van Pioneer in om door te gaan met de update. Druk op annuleren om update te stoppen'.  I was offered 3 options 'Yes', 'No'  and 'Cancel', and chose 'Yes'. That seems very different than what @maunav90 got in Italian ('Inserire password nuovamente?') , which seems to suggest a question to CHANGE the password, not to merely enter it..  Final note: I came from a 2011 (hence very old) firmware. Could that be the difference here between what I got and what @maunav90 got ?
Basic steps that I followed  (based upon the guide from @spoon1 and input from @RonS as well on how to proceed):
- Prepare SD-cards (#1 with ShortFuse hack files, 2 Gb minimum/FAT32-formatted and #2 with 2019 map update  (see files shared by @godzilla,  8 Gb minimum/FAT32-formatted)
- Install SD1 and install the ShortFuse hack
- Install SD2 and install the 2019 map data (note: firmware device updates were automatically installed after the 2019 map data was loaded successfully)
- Prepared/Reused SD1 for the TTS (Voice) files and chose/installed the navigation voice language (in my case Dutch) from the menu
IMPORTANT NOTES:
- Since the AVIC-F930BT is a "MY2011" device, there was no need to modify or manipulate the CARDINFO file. In other words: I simply included/recursively copied the one from the 2019 Map Update ZIP file that @godzilla shared with us already.  Obviously, the ShortFuse hack will do the magic trickery already, and there's no need to modify the CARDINFO file either.
Edited May 19, 2020 by mroset — Reason: Some enhancements on the general steps used to install the 2019 update
Posted May 19, 2020 · 23:15 UTC#107
According to Italian section of the map installation manual, the prompt to enter the password is preceded with this screen:
I don't speak or read Italian (or Dutch), but this is probably equivalent to what you described for your installation. After responding "Si", it prompts the user to enter the password.  I think the image @maunav90 posted is after he entered "PASSWORDPASSWORD" and it was rejected. So it was asking the user to re-enter the password. I suspect that he never (or incorrectly) installed the Shortfuse hack, so the password it was expecting was the "real" one registered for this unit's serial number. Not the hacked one "PASSWORDPASSWORD".
Edited May 19, 2020 by RonS
Posted May 20, 2020 · 04:52 UTC#108
sorry for my english.
hello friends my navigation is with maps from MY2010 - original map, never update , should I change cardinfo -file with 2017y or follow the steps described in the forum?
Edited May 23, 2020 by chasovnik
Posted May 20, 2020 · 08:06 UTC#109
That makes total sense and yes, this is exactly the same popup window that I got in Dutch (Man, never would have expected that this forum would improve everyone's language skills right :lol: ). I suggest that @maunav90 gets back to us and let us know in detail whether that was the case and/or how he resolved the issue.  In any case, it all worked brilliantly and without a glitch for my father's AVIC-F930BT (maps upgraded from 2011=>2019, firmware upgraded  to 8.000) , so thanks for all the efforts @RonS, @godzilla and @spoon1 , also on behalf of my happy father !  I even hooked up his relatively new Samsung smartphone to Bluetooth in the car while I was at it. That was also a real eye-opener for him, and it was clear that this will result in safer driving.
Edited May 20, 2020 by mroset
Posted May 21, 2020 · 09:44 UTC#110
It is installed and it works well, just a pity that some street names are not known suddenly, or a roundabout that is not in the right place, but it works well.
Thank you
Posted May 24, 2020 · 13:38 UTC#111
Thank you friends!
Posted May 26, 2020 · 17:44 UTC#112
@spoon1 Hello! If I have a hack and update installed from 2017, can I only install the new maps? Only 8 Gb card? F930BT? Thank you.
Posted May 27, 2020 · 12:23 UTC#113
@djexplorer i did the hack, and afther that i installed the maps. Just for sure.
Posted May 28, 2020 · 08:50 UTC#114
On 14-5-2020 at 9:33 PM, ds70 said:
I have updated my F10BT with a changed CARDINFO. Works perfect. Thanks to all !!!!
what cardinfo did you use ?
cheers and thanks!
Posted May 28, 2020 · 09:17 UTC#115
Posted by RonS in the 2017 thread:
Cardinfo file
Posted May 29, 2020 · 10:55 UTC#116
I'm stuck it's saying incorrect sdcArd how do I fix this
Posted May 29, 2020 · 10:56 UTC#117
@spoon1assist me plz
Posted May 30, 2020 · 07:08 UTC#118
Update done on f920bt. Procedure the same as 2017.
Thx. @godzilla for maps and @spoon1 for the Infos.
Edited May 30, 2020 by fred_feuerstein
Posted May 30, 2020 · 12:39 UTC#119
That's correct. Without the hack, the password from the maps update is not accepted.
I tried it without the hack, because I used the hack with the 2017 maps, but it don't work.
Then the short hack and after that, the map update was no problem.
Posted Jun 01, 2020 · 22:25 UTC#120
Hello, first of all thanks to the friends who contributed.
- I have a F940bt device, I have updated 2017 before. But how I did it, I don't remember exactly.
Anyway, I want to make a 2019 update;
For this, I downloaded the files of the first godzilla.
https://drive.google.com/open?id=1o7rfWz2qB67V5p9CfuMb0SpmMTGNjLuN  Software
https://drive.google.com/open?id=13k1m5B19rP-D3lhQbGSbvUqpp5OryJMJ  - TTS CD
Posted Jun 01, 2020 · 22:33 UTC#121
- the files I downloaded; I copied it to an 8Gb memory card formatted as fat32. (Not tts)
I plugged it into the unit, but it didn't update. I updated Bluethoot manually to 3.32.
- cardinfo.cif should be updated?
Can you share the necessary files for the next steps and explain the necessary steps as simple as possible?
Thank you
Posted Jun 02, 2020 · 17:38 UTC#122
I have updated my F920BT with a changed CARDINFO. Works perfect. Thanks to all !!!!But im missing german TTS-Datei ???
Posted Jun 03, 2020 · 21:52 UTC#123
Hello guys! I have a problem after I updated the maps I can no longer install the audio language tts gives me error any language I put from the SD card
Pioneer f940Bt
Posted Jun 05, 2020 · 13:53 UTC#124
i already used the shortfuse hack on the 2017 files..  This was the result. BUT: the update to 2019 worked even with this error!
So it seems an already hacked .dll accepts the new update with the same PASSWORDPASSWORD.
Edited Jun 05, 2020 by seth_space — Reason: removed quote
Posted Jun 05, 2020 · 14:43 UTC#125
On 6/5/2020 at 9:53 AM, seth_space said:
That error is probably  because the SD was write-protected (or some other problem the script had while writing to the SD).
The 2017 hack overwrote both copies (PRG0 and PRG1) of RenewalIFLib.dll, and installing the 2017 maps overwrote one of them with an "un-hacked" version. As long as PRG0 has the hacked version, you can get away without re-running the ShortFuse hack. Odds are 50/50 it will work. You got lucky. It all depends on how many updates have been installed over the life of the head-unit.
Edited Jun 06, 2020 by RonS
Page 5 of 10
