New Release F20BT F30BT F40Bt F920BT F930BT F940Bt F840BT Etc 2019
By godzilla · Sep 07, 2019in Hacks/Mods💬 236 posts👁️ 197,668 views
Page 7 of 10
Posted Oct 26, 2020 · 18:03 UTC#151
Colleagues, I have a problem, I can't update the software on my radio avic f840bt, it asks me for a password, the radio is not secured with any password, at least I think so, after installing it in the car it worked without entering the password, when trying to install new software, it asks for the password  , I tried many combinations and nothing, I also tried to remove the password with the given script on the forum and then nothing, still asking for a password, I have no ideas, it seems that this is not a user password but some internal Pioneer, is there anyone who can help me  I just can't handle it and is that simple?
Posted Nov 08, 2020 · 01:10 UTC#152
Big thanks to all.
Everithing working well on my F20BT.
But had to replace the file CARDINFO.cif by the one provide by RonS there :
Without it nothing happend when i put the MAP SD CARD
CARDINFO.cif
Posted Dec 05, 2020 · 17:03 UTC#153
On 11/8/2020 at 2:10 AM, hlekinfr said:
Big thanks to all.
CARDINFO.cif
Thnx this worked perfect!
Posted Dec 23, 2020 · 17:33 UTC#154
Hi. Looking for Scandinavian map (2019 or 2020) for Pioneer F840BT.
Possible? @godzilla
Edited Dec 23, 2020 by callaim
Posted Dec 27, 2020 · 21:57 UTC#155
Hi, I have maps 2015 (ver 6.0) on my F20BT (hack from this forum). Can I do update to 2019?
Posted Jan 17, 2021 · 20:36 UTC#156
thanks a lot! I used hack script, map, TTS and nonag script and everything went flawlessly and took less than 25 minutes on my old F930BT.
As a gift, here are the latest fixed speedcam for France, Germany, Switzerland, Liechtenstein and Benelux (all in one, about 11.000 POIs) :
radars fr-benelux-sw-deu.7z
Posted Feb 01, 2021 · 21:54 UTC#157
hi in f930bt  paswordpassword and 1111111111111111 do not work
you must start short fusescript and you wil update map
Edited Feb 01, 2021 by Zwierz121 — Reason: add answer
Posted Feb 17, 2021 · 15:50 UTC#158
Edited Feb 19, 2021 by rustu
Posted Feb 18, 2021 · 10:11 UTC#159
Does this work for F8430BT? I have a Pioneer F8430BT with card 2015.
Posted Feb 18, 2021 · 23:05 UTC#160
Looks like this unit runs the same firmware as the F40BT, F930BT and F940BT. So yes, it should work.
Edited Feb 18, 2021 by RonS
Posted Feb 25, 2021 · 23:53 UTC#161
Firstly hi from Turkey to everyone. I ve read all the topic about 2019 map update and I could update my f9220bt except for bluetooth.
For this, thanks everyone.
I bought this device second hand and my bluetooth wasn't working. My device version was 07.000 and bluetooth version was: ------------- After updating my device, its version is now 08.000 but I couldn't update my bluetooth to 3.32. so bluetooth version is  still: ------------------(no firmware)
What can I do to solve this problem? Which bluetooth version must be set up first and update? And how?
I will be very pleased if anyone help me. (And sorry for my little English)
Posted Mar 11, 2021 · 14:32 UTC#162
On 10/19/2020 at 12:46 PM, Vincent1979 said:
Can please someone help me out, I have the 2017 maps on my F930BT (hacked version of this forum) , trying to update the system with the 2019 maps,
But it can't read the TTS sd, tried different sd cards but no luck,
The 2019 sd it reads but can't get beyond the password, so the problem lies in the TTS sd that doesn't install?
Tried 3 different sd cards from 2 and 4 GB without any luck,
What I'm doing wrong?? :wacko:
On 10/20/2020 at 11:08 AM, Gopher1973 said:
Same here. Tried a couple SD's all different sizes and reformatted. Placed the ISO, even decompressed the files. When I add the SD with the map update, it will promt directly for the update. Tried the double passwords and the 111. No luck.
Any tips?
Not sure if you guys figured this out, but the TTS.iso needs to be unpacked and only the VOICE folder goes on the SD card. You then need to go into settings -> regional settings -> voice -> setup -> change voice -> choose desired voice. It will then update from the SD card. This will take several minutes. There is an instruction pdf on the iso which I've attached here.
1771457610_TTSinstallation.PDF
Posted Mar 15, 2021 · 14:28 UTC#163
Maybe a silly question..
Do i need to put both the files from godzilla on 1 SD card?
and for instructions i just follow the guide from spoon and everything will be going ok?
first time i'm doing something like this!
Posted Mar 20, 2021 · 13:00 UTC#165
Yeah no problem,
Posted Apr 04, 2021 · 20:38 UTC#166
moi avec succès MAP 2017 avec HxD et la 2eme mise a jour 2019a avec grand succés sur avic f9210bt merci
Posted Apr 11, 2021 · 16:53 UTC#167
Hi all,
I found these awesome files and have them. And a F940BT in desperate need of an update.
However, am super not so techy with this.
Would anyone be willing to explain in super simple language what to do?
Question already coming up for me:
- Do I use micro SD card, and put it next to where the CD goes in?
- Do I need to do something to the SD card (how many GB?) before loading the files on it? exfat?
- Am in Netherlands, do I need to change that .cif file?
- Will I need to enter a password and if so, do I try the 1-ones or the double password in caps?
- Can I do it terribly wrong and f* up the old version that is on there now?
Thanks sooo much if anyone is patient enough to assist me with my lack of expertise and jargon :)
UPDATE:
I managed to do it without expert assistance :)
for F940BT did not need to the other 2017 cardinfo file, just the one from godzilla.
I did need the shortfuse thing, tried without and didn't accept the password.
I used a 2GB for shortfuse, and a 32GB for the update files.
At first I had them formatted as exFat discs, and I got a notificated that the drive was incompatible with the device. Reformatted as MS-DOS (FAT) and then it did work.
Feeling like a super expert now :).
Thanks to all of you for the information provided here, couldn't have figured it out without it.
Edited Apr 15, 2021 by Iniminie
Posted May 03, 2021 · 12:40 UTC#168
Hello, is it possible to upgrade my F930BT with godzilla's files directly from device factory default or do I have to patch it with any previous version? Thanks a lot for your reply.
Posted May 03, 2021 · 13:18 UTC#169
If you are asking if you need to install all the intervening updates first, no you don't.  You will need to run the ShortFuse hack.
Posted May 03, 2021 · 13:31 UTC#170
RonS: thank you
Posted May 03, 2021 · 15:28 UTC#171
Hi, I updated my F9310BT with ShortFuseScript and 2019a maps provided in this tread, and everithing worked perfectly! It was not necessary to change the CARDINFO.cif file, therefore I simply used the one included in the 2019a maps package.
Thanks everybody for your excelent job!
Now I'm looking for LATEST ITALY UPDATE SPEED-CAM / RADAR. Does anyone have an idea where to find them?
Thanks a lot guys!
Posted May 03, 2021 · 19:31 UTC#172
Have you tried this? http://www.speedcamupdates.com/pioneer-avic-f9310bt
Italy is part of Europe 1 region there and it costs EUR 10 which is probably reasonable offer, isn't it?
Posted May 04, 2021 · 06:53 UTC#173
I've just updated my F930BT – everything seems to be ok. Just one little question – where could I find the map version within my device? Thanks
Posted May 10, 2021 · 09:43 UTC#174
All working great. Thanks!!!!
Posted May 25, 2021 · 08:27 UTC#175
Hi,
do we have to install shortscript or not (this message let me understand that apart from transferring the files provided by godzilla, there was nothing else to do).
Page 7 of 10
