New Release F20BT F30BT F40Bt F920BT F930BT F940Bt F840BT Etc 2019
By godzilla · Sep 07, 2019in Hacks/Mods💬 236 posts👁️ 197,668 views
Page 8 of 10
Posted May 25, 2021 · 12:25 UTC#176
3 hours ago, pmc2 said:
Hi,
do we have to install shortscript or not (this message let me understand that apart from transferring the files provided by godzilla, there was nothing else to do).
Nothing in that post says not to follow the instructions (run Shortfuse). It was about whether the user needed to replace Cardinfo, and not modifying any other files on the SD. Shortfuse does not modify the installation SD, it modifies files on the headunit before installing the map update.
Posted May 25, 2021 · 12:36 UTC#177
ok thanks,
so: 1/ shortuse for password 2/map 3/ tts (optional) 4/ speedcam (optionnal).
Posted May 25, 2021 · 14:18 UTC#178
Yes on 1&2. I'm in US so I can't help with 3&4. We don't need additional TTS and no speedcam support.
Posted Jun 24, 2021 · 07:29 UTC#180
I updated my F920BT which worked well (used the old cardinfo file).
I did have some issues to find the instructions so i posted them here again.
Update Pioneer Avic series MY2011 ENGLISH.pdf
Posted Jul 02, 2021 · 17:35 UTC#181
Can anyone tell me if this is supposed to be working for F950DAB?
I got super testmode working (key), but trying to locate the files requested RenewalFlib.dll is impossible.
Attached is the information from PRG\APL
Menu
Which as far as I know is the only thing related to PRG / APL in the whole system.
From what I understand there are others with F950+ that used the same procedure as explained, but I can't grasp how as it has different file mappings.
Edited Jul 02, 2021 by thorin
Posted Jul 04, 2021 · 09:11 UTC#182
Can anyone tell me if this will work with the Z710DAB?
I've searched for quite a while on this forum, but cannot seem to find anything about it.
And since this unit does not have sd card slots, but only a usb port, how should I then proceed to update?
Any help is appreciated
Posted Jul 04, 2021 · 11:28 UTC#183
Do the same for the USB as others do with SD cards, if it works, which I'm not sure about.
Posted Jul 08, 2021 · 15:22 UTC#184
Witam. Aktualizowalem jakieś dwa lata temu swojego Pioneera F930BT do map z 2017 i z tego co pamiętam to zmieniałem jakieś liczby w systemie i aktualizacja map 2017 potem poszła bez problemu. Teraz chciałem zaktualizować mapy do 2019 pobrane tutaj i w ogóle nie chce nic ruszyć za każdym razem uruchamia się radio nie widząc karty SD. Jak mam to zrobić żeby zadziałało. Dziękuję
Posted Jul 17, 2021 · 17:55 UTC#185
On 6/10/2019 at 12:40, spoon1 said:
On 8/9/2019 at 01:47, godzilla said:
Va bene due anni e un'altra release per tutte queste macchine. L'ultima volta che ho acquistato il software e ho diffuso la ricchezza, questa volta ho bisogno di aiuto perché la mia situazione è cambiata. Per prima cosa ho bisogno di acquistare il software con il donatore più alto che riceve il pacchetto originale e la chiave inutilizzata, tutti gli altri riceveranno il software gratuitamente ogni euro, dollaro o sterlina aiuterà il mio indirizzo di pagamento è
paypal.me/salsatnav
Ti terrò aggiornato con aggiornamenti quotidiani fino a raggiungere £ 125, quindi lo pubblicherò qui GRATUITAMENTE ho la sensazione che l'hack di Rons Shortfuse lo farà di nuovo
Aiutiamoci tutti a vicenda
Donato
Posted Aug 08, 2021 · 13:16 UTC#186
you have to use the naviextras program, that's the only way to install new maps that i know.
Posted Aug 09, 2021 · 19:21 UTC#187
Will this work with the F700BT or is this model too old? The last update I installed was this Russian AvicNet hack from 2014 which allowed to use iGo Primo. If this one here doesn't work but there's another new version I should use, then I'm thankful for a hint. Thanks!
Posted Sep 13, 2021 · 11:05 UTC#188
does anyone know if this update works on the AVIC-F77*series HU?
happy to contribute to paypal for this if this works!!!
regards
A
Posted Sep 13, 2021 · 12:18 UTC#189
can someone repost the cardinfo.cif file for the 2010 F920BT
Posted Sep 16, 2021 · 21:21 UTC#190
regards
A
Only with naviextras Nobby
Posted Sep 16, 2021 · 21:22 UTC#191
You cant use this on your 700 model brunowillis
Posted Sep 19, 2021 · 18:18 UTC#192
Hi guys,
Thank you for this post!
I tried to install it on a F40bt but can't go further the password step.
I did the shortfuse and when the update asks me for the password i input PASSWORDPASSWORD and it ask me to insert password again!
1111111111111111 doesn't work either!
Did anyone go through the same issue? How did you manage it?
Regards,
Posted Nov 25, 2021 · 00:42 UTC#193
Hello, I have the f9220bt, could you pass me the latest update available? Thank you so much
Posted Dec 02, 2021 · 19:48 UTC#194
Thanks, working like a charm on my f930bt. Before i found this, i had a higher software installed. The hack caused my system to downgrade to 8.000. Now i have everything installed, can i safely update my system again to 8.6 though the official site? Or can this harm the system since i used the hack?
cheers!
Posted Dec 05, 2021 · 03:32 UTC#195
Buongiorno ragazzi sono appena iscritto e dovrei aggiornare il mio F940 BT ma mi manca il  hack ShortFuse. qualcuno puo mandarmelo ve ne sarei molto grato
Edited Dec 05, 2021 by pierluigi.baldassari
Posted Dec 05, 2021 · 14:11 UTC#196
Shortfuse
Posted Dec 29, 2021 · 21:15 UTC#197
I have updated the maps on F30BT and everything worked great. After restart i noticed i do not have tts voice for my country - Simona TTS (romania) and i tried to install it but after 10 minutes it gives me an error saying it could not install the TTS voice. What am i doing wrong?
Thank you!
Posted Jan 08, 2022 · 18:43 UTC#199
Hi,
I would like to update my old AVIC-F320BT to the latest possible software and maps.
My device is showing version 1.0000 and device nr 243##########39E
Pioneer navigate on the device is from year 2010.
Pioneer does not support this device anymore.
Can you please guide me, or send me a link
  1. Update instuctions
  2. software
  3. maps
Edited Jan 08, 2022 by gaga3000
Posted Mar 30, 2022 · 16:34 UTC#200
On 01.05.2020 at 13:15, spoon1 said:
да, это прекрасно работает ... я купил карты 2019 года и работает в каждой модели:
у меня есть оригинальный SD или микро SD с путем для этой модели:
- AVIC-F30BT - AVIC-F930BT - AVIC-F9310BT - AVIC-F40BT - AVIC-F940BT - AVIC-F840BT - AVIC-F8430BT
и для этой модели:
- AVIC-F10BT - AVIC-F20BT - AVIC-F920BT - AVIC-F9210BT - AVIC-F9220BT
хорошо, я могу дать вам каждые две резервные копии с английской инструкцией, чтобы обновить ваш Pioneer
но скажи Годзилле, чтобы он прислал мне деньги... я заплатил за эти карты, так что я не могу дать бесплатно...
Конечно, Годзилла болен, но все участники заплатили ему, поэтому, если этот участник хочет это обновление, мне нужно ваше пожертвование ... я заплатил 160 евро .... так что мне нужны деньги, потому что я работал, чтобы найти правильное идеальное рабочее решение SD!
у меня также есть карты европы 2018 для этой модели:
 Pioneer AVIC-F50BT, F950DAB, F950BT и F850BT
я могу дать их сейчас, без проблем .. у меня есть эти карты с 6 маунта! и он протестирован и отлично работает без каких-либо проблем
Hello, can you share the 2018 maps update for avic f950?
Page 8 of 10
