Tried several SDCards with the same result.. no write protection.
Not sure if i understand you correctly.. there are two version of the hacked dll in the unit? And the overwriting is "random".. seems strange..
Not random. There are two complete sets of firmware on the unit (PRG0 and PRG1). When the unit installs a map update, it alternates overwriting one of them. It should overwrite the oldest. This is controlled by the presence or absence of /USER/PRG.FLG. From memory, it works something like this: When the unit is brand new, PRG0 and PRG1 are identical and PRG.FLG does not exist. The next map update overwrites PRG1 and creates PRG.FLG. The next time the unit is updated, it sees that PRG.FLG exists and overwrites PRG0 then deletes PRG.FLG. Then this cycle repeats ........
I don't know why only you seem to be having problems installing the hack. In the future you could edit the script on your PC to remove the section where it creates backup copies of those files by writing them to the SD.
still happy user!
It worked and a next time i will skip the copy part..
Hello! Can you help me. I can't install the Romanian voice on the card since the last update.
Succesfully updated my F9220BT using CARDINFO from 2017, thank you very much!
Succesfully updated my F940BT ,thank you very much!
On 30/05/2020 at 11:51 AM, spoon1 said:@ Topchaca did you uese hack ?
because if you not put sd card with hack before update maps then you have situation like your screenshot !
@spoon1i think something was wrong with the update file I switched it with a file that was previously uploaded and it worked fine
@godzillajust checking in to see how you are doing in health terms ! And to also thank you (and the other major contributors like @spoon1 and @RonS)
Just got feedback from my dad that he is so happy with the new updates on the device. Apart from the new maps, also the firmware upgrade seems to have had a positive effect on how the device works.
When anybody thinks they can benefit from me sharing the pictures/screenshots here that I made during the process (i haven't gotten through to that yet...), please let me know, and I'd be happy to speed that up.
Got it! (F-930BT)
but two little things..
1) in volume settings i can't set the navigation volume level
2) any way to avoid theNag screen at startup ?
greets
I just did a binary file comparison between the 2019 (v8) navi.exe and the 2017 (v7). They seem to be just re-compiled from the same source. So the same patch address should work. I patched it and attached here. Is someone brave enough to try? Use the same instructions as for the 2017 Nag Screen Removal, but use this file instead. 2017 No-Nag patch Instructions Use section 2 only. Do not try to install the old v7 Navi.exe. They have different internal version numbers.
On 26-6-2020 at 3:32 PM, RonS said:I just did a binary file comparison between the 2019 (v8) navi.exe and the 2017 (v7). They seem to be just re-compiled from the same source. So the same patch address should work. I patched it and attached here. Is someone brave enough to try? Use the same instructions as for the 2017 Nag Screen Removal, but use this file instead. 2017 No-Nag patch Instructions Use section 2 only. Do not try to install the old v7 Navi.exe. They have different internal version numbers.
Yes, you are right. The 2017 No-Nag Patch instructions is working fine.
Today I updated my F920BT. Everything works great !!! My old Pioneer from 2010 backed to Life !!!. I used Cardinfo 2017.
Thanks All Especially:
Godzilla for Maps
spoon1 for tutorial
jape91 for cardinfo2017
jape91 for ShortFuse.zip
Hello, I'm really new to Pioneer devices. I have several issues with F920BT. I did the following. Installed ShortFuseScript and it went without problem. After that, I tried to install these maps with CARDINFO.cif from 2017., because it wouldn't start with one provided in this map package, as my device is MY2010. It offers me an update, I click Yes, it asks me for confirmation, I click Yes again, but afterwards all the fonts and everything are grayed out, except backspace arrow in the bottom left corner. And in the place where password is to be written, it just says "PASSWORD" (see the 3. picture). Also, most of the options in the main and navigation menu are grayed out. I updated the firmware from official website "avicf20bt_apl2.00300". I even edited "RenewallFlib.dll" and replace them manually, but still no luck...
I use Kingston 16GB SD, the device is on my table and not in the car, if that matters... Every accessory is connected to the device, except for the CAN (GPS antenna, USB, mic...).
What am I doind wrong?
Cheers
I did use your patched Navi.exe and wrote a small script so by putting the contents of the zip archive on the root of an SD and inserting it before ignition the patched version for 2019/v8.0 can be installed very easy.
16 hours ago, peniko said:No, I just bought it, as my RCD510 died...
Finally did it. I had to ground the parking brake wire (light blue) and forced the device to think that the imaginary car is parked. Thanks for help...
The cardinfo.cif from 2017 does not work with F10BT.
It took me a while to make my unit work at least with the 2017 SW again, as it was asking all the time for the right SD card. (I used the script before to replace the renewal dlls , and the password was accepted too.)
I made a few experiment with patching the cardinfo with the string from 2017, but no success...
At the end I removed the USER\RW\RENEWAL\VERINFO.DAT , which was copied from the 2019 update already there (I know because I checked the content), which apparently does not match the 2017 cardinfo, and put in the 2017 update SD to repair the unit.
Any further suggestions with the cardinfo?
Hello, I tried to install this new update on my F9210BT, but the password didn't work although I changed the cardinfo file. Then I tried the Condis HAckmode 2.1.
That was a mistake. I was able to remove this hackmode. But now if I start my Navi, there is only "There is no application availabe". Is it possible to install this new update with testkey? If so, how can I do it? I don't know where to paste the backup files in the radio with testkey.
Big thank you to RonS and Pioneer snow. Nag screen removed on my old F920BT.
Been wanting that gone for years, but only just discovered this forum. ![]()
How to install please ?
12.05.2020 o godzinie 23:33 godzilla powiedziała:Zaczynamy chłopaki
https://drive.google.com/open?id=1o7rfWz2qB67V5p9CfuMb0SpmMTGNjLuN Oprogramowanie
https://drive.google.com/open?id=13k1m5B19rP-D3lhQbGSbvUqpp5OryJMJ - TTS CD
jak obiecano
pozdrowienia
godżilla
Is it compatible with f900bt?
Is it a different platform?
On 27-9-2020 at 8:09 PM, Pilot9510 said:Is it compatible with f900bt?
Different Platform Pilot9510
Can please someone help me out, I have the 2017 maps on my F930BT (hacked version of this forum) , trying to update the system with the 2019 maps,
But it can't read the TTS sd, tried different sd cards but no luck,
The 2019 sd it reads but can't get beyond the password, so the problem lies in the TTS sd that doesn't install?
Tried 3 different sd cards from 2 and 4 GB without any luck,
What I'm doing wrong??
22 hours ago, Vincent1979 said:Can please someone help me out, I have the 2017 maps on my F930BT (hacked version of this forum) , trying to update the system with the 2019 maps,
Same here. Tried a couple SD's all different sizes and reformatted. Placed the ISO, even decompressed the files. When I add the SD with the map update, it will promt directly for the update. Tried the double passwords and the 111. No luck.
Any tips?
