New Release F20BT F30BT F40Bt F920BT F930BT F940Bt F840BT Etc 2019
By godzilla · Sep 07, 2019in Hacks/Mods💬 236 posts👁️ 197,668 views
Page 9 of 10
Posted Apr 17, 2022 · 17:20 UTC#201
Does it works on a F80DAB? If yes should I need to change cardinfo?
Regards
Posted Apr 20, 2022 · 06:10 UTC#202
Regards
This doesn't work on F80 you need to use naviextras toolbox to update ( paid update )
Posted May 04, 2022 · 15:03 UTC#203
Hello, first of all, thank you very much for these programs, I have an avic f9210bt from 2011, and the bluetooth does not work, I thought I would have to throw it away, with this update I have managed to make it work a few times, but it has failed again and it no longer works .
The bluetooth firmware version is 3.11, it was not updated to version 3.32, I think it was this one that had to be updated?
If anyone has had this problem or know how to solve it please
Posted Aug 10, 2022 · 16:58 UTC#204
Hello, did you managed to achieve it? if so can you tell me how?
Thank you in advance.
Posted Dec 08, 2022 · 07:13 UTC#205
thank you all, who help for this solution! Yesterday i updated my old avic f-9210bt (maps from 2015) without any problems. After a few years without function is it now my headunit in a vw scirocco. I'm very happy.
Posted Feb 06, 2023 · 19:09 UTC#206
Is there someone who has this working on a f980dab, and most importend, how
Posted Feb 07, 2023 · 02:19 UTC#207
 o
No. This is not compatible. This firmware is for much older units.
Edited Feb 07, 2023 by RonS
Posted Dec 04, 2023 · 11:07 UTC#208
On 9/8/2019 at 12:47 AM, godzilla said:
Okay two years and another release for all these machines. Last time i bought the software and spread the wealth this time i need help as my situation has changed . I firstly need to  buy the software with the highest donator getting the original pack and the unused key, Everybody else will get the software for free every Euro , Dollar or pound will help my payal me address is
paypal.me/salsatnav
I will keep you in the loop with daily updates till we reach £125 then i will post it here  for FREE have a feeling Rons Shortfuse hack will do it again
Lets all help each other
Hi, did you reach your target?
Posted Dec 05, 2023 · 15:51 UTC#209
Hi end how to get file
Posted Dec 09, 2023 · 16:35 UTC#211
Hello guys I have AVIC-F9310BT, will map updates work for this model? If so, how do I install these files and can I do these updates with usb?
Keypoints:
Also what is shortfuse hack and do i need it?
Should I change cardinfo and how do I do it?
What does TTS have to do with all of this?
Posted Dec 11, 2023 · 03:32 UTC#212
Keypoints:
Shortfuse hack : http://avic411.com/index.php?/topic/83535-map-update-hack-using-shortfuse-method-z110-z140x920-x940/&do=getNewComment
Cardinfo needs to be changed only if the model you have is different that what godzilla has posted.
I don't use TTS, so I can't help. TTS generally refers to Text To Speech, so it might be useful if you need a different language.
Posted Dec 13, 2023 · 23:12 UTC#213
Hey so I tried to download shortfuse and do rest of stuff but this happened.
Btw what do ya think does this avic have custom os or something, just asking
Posted Dec 14, 2023 · 07:34 UTC#214
The script attempts to make backup copies of the two original RenewalIFlib.dll files onto the SD before overwriting them.  For some reason the copy command failed.  Maybe there was no more room on the SD or it was write-protected, or the file already existed on the SD (if you ran the script more than once).  Anyway the copy of the original files failed and the hacked versions didn't occur since the script crashed.
Regardless,  you can edit the script (named ScriptExec) on your PC and remove that 1st and 2nd COPY command. Then rerun it by reinserting it into the head unit.
No way I can tell if it is a custom OS - probably not
Edited Dec 14, 2023 by RonS
Posted Dec 17, 2023 · 16:19 UTC#215
Hey, so i just need to install 2019 maps, so what software can i use to edit script? And also I heard theres something you need to change in cardinfo, so if you can explain this i would be gratefull.
Edited Dec 17, 2023 by benjolol
Posted Dec 17, 2023 · 18:27 UTC#216
I use notepad on Windows. But any editor that edits and saves text files and doesn't insert formatting data (like Word). Also make sure you save the file name exactly the same without adding a ".txt" extension.
You'll need to browse this thread for info on replacing cardinfo. Several people have written detailed instructions. I haven't messed with this stuff for 5 years.
Posted Dec 19, 2023 · 21:35 UTC#217
Yeah i believe that, but i think people have removed those threads, since I havent seen any tutorial on that
Posted Dec 20, 2023 · 03:01 UTC#218
Did you get Shortfuse installed?
If you've read through this thread you should have all the info you need. There's no guide - just posts from people saying what worked. Note that pages 6 - 8 have a lot of helpful info.
An F9310bt is basically the same as an F930bt and does not require a different Cardinfo file. Only early series like F910 or 920 need it to ne compatible with the version that Godzilla posted.
That's about all I can tell you since I've never installed this update. But the process is the same as all the previous updates (2013, 2015, 2017). So you might find better guides in those threads.
Edited Dec 20, 2023 by RonS
Posted Jan 02, 2024 · 12:35 UTC#219
I removed backup copy files but still get this error, what could be wrong
Posted Jan 02, 2024 · 13:10 UTC#220
There must be something wrong with your SD.  Ideas: What size? Format FAT32. What files are on it? Should be only the files from my unzipped file. The write protection tab should be turned off.
Maybe try a different SD. Don't use a large SD (1 - 8 GB work well.
Posted Jan 02, 2024 · 13:14 UTC#221
I did actually use 32 GB SD, maybe thats the reason, was also formated FAT32 and there was shortfuse script with map update
Posted Jan 02, 2024 · 13:28 UTC#222
No map update on this SD! Just the Shortfuse files. After it is successfully patched you can format the SD and use it for the map update (or use two SDcards). On the map update do not add or modify any  files except if you need to replace Cardinfo (which you should not need for your model).
Posted Jan 02, 2024 · 13:35 UTC#223
Could that be a problem rather than size of SD card?
Posted Jan 02, 2024 · 13:44 UTC#224
Maybe. It is easy to try.
Posted Jul 26, 2024 · 08:34 UTC#225
On 5/12/2020 at 11:33 PM, godzilla said:
Thanks for providing the software..
ive tried to uplaod it onto my F930BT but im beeing asked for my " pioneer password".. i tried finding the asnwer here in the thread but with no luck so far.
Thanks in advance!
Gr Timo
Page 9 of 10
