Anyone needing wire info
By brachoza · Jul 19, 2006in Vehicle Specific Wiring💬 183 posts👁️ 87,850 views
Page 8 of 8
Posted Oct 01, 2011 · 17:51 UTC#176
Trying to put a 920BT in my 2011 F250 with Sat ans Sync
Have you done any installs like this?
Jason
Posted Oct 04, 2011 · 23:52 UTC#177
I have a 2010 dodge ram with a Z1 that I am trying to connect a stock backup camera to. The camera has 5 wires, a backup feed, camera supply, camera return, camera shield and a ground. You have any ideas how I could get it to work?
Posted Oct 12, 2011 · 03:35 UTC#178
I am going to put the x930bt in my cadillac seville 2000 with bose 8 speaker system
I know i need to use a GMOS-06 to make it work with my stock speakers
i notice the back of the pioneer unit has 3 female rca's but the GMOS-06 has 4 male RCA's is this impotratn do i need to be able to use all 4 on the harness so will that not work right with my system ?
also is there any difrance to bypassing the lock out feature on the 930bt using the GMOS-06 or is it the same as in the Youtube videos i have sean to repin part of the harness to make it work in drive
thanks
Posted Nov 12, 2011 · 05:41 UTC#179
Hi
Would appreciate any guidance on installing in a Toyota F J Cruiser delivered in Australia. Specifically need wiring for the hands free controls on steering wheel (radio, phone). Rear vision camera and microphone.
I have it installed (well sort of) ..Radio reception not the best...seems to be slightly off tune for each FM channel?
Any help very much appreciated
Cheers
Lou
Posted Nov 12, 2011 · 15:29 UTC#180
To use your steering wheel buttons - you need adapter - like AXXESS ASWC for instance, or some other manufacturers can offer you similar products, Toyota uses simple resistive interface- so it is simple.
Your unit already has input for rear view camera- probably it should be NTSC type- but I am not 100% sure. You need connect you camera (even $30 one from e-bay will work, and take wire from your reverse light (+12v) back to unit and connect it to "reverse signal input" wire on harness. Microphone should be in the box as well.
Also it is lots of complains about radio reception quality... so unfortunately we have to live with it. May be they will release some software update to fix it?
BTW here is installation manual for X930BT but it can be used for all new line of Pioneer's HU.
Edited Nov 12, 2011 by Ralpharn
Posted Nov 15, 2011 · 01:09 UTC#181
Thank you very much Ralpharn it gives me hope that I might be able to get the factory steering wheel buttons talking to the AVIC. I'll let you know how it goes.
Posted Oct 05, 2017 · 08:10 UTC#182
:cool:  :cool:   No that's 2 different wires. One of them is the reverse wire which tells the avic when the car is in reverse and the other one labeled speed sense is the vss wire you're looking for. I just post both out of habit. Saves people from asking for the vss and then later having to ask for the reverse wire.  :???:  :???:  :???:
:eek:  :eek:  The color listed the first one is the color of the majority of the wire, the second color is the color of the stripe on it. If the installer knows anything just show him the post and he'll know what to do with the info.  :|  :|  :|
Posted Mar 01, 2020 · 17:34 UTC#183
HI I need the Speed Sensor Wire Location. 2003 Lexus GX 470 TIA
Page 8 of 8
