proto24 Posted December 29, 2007 Report Share Posted December 29, 2007 Hey the other day my car was broken into. The 2 guys that did it took the unit out of my car and left on the side of my driveway. The stole the gps antenna and left a 2 in scratch on the screen. I would rather not have to spent $60 on a new antenna and 51 to fix the screen. I love the unit but if it means doin such i will. But am just wonderin if there are any other suggestions. The crappy part is that alarm never went off. Something must have been faulty. Because after it happened i messed around w/ the car seeing if the alarm would go off if i opened door from inside and did not go off. Then after that opening the front door and hood. The alarm is aftermarket, the alarm is Viper. It sucks because no one was apprehended and i gotta fix my car out my my pocket because of someone else. Quote Link to post Share on other sites
HiFiSi Posted December 29, 2007 Report Share Posted December 29, 2007 If the screen is scratched, the only recourse its to get a new screen. There's no way around that. Quote Link to post Share on other sites
Two_Cold Posted December 30, 2007 Report Share Posted December 30, 2007 Who screwed up the alarm installation? Quote Link to post Share on other sites
proto24 Posted December 31, 2007 Author Report Share Posted December 31, 2007 as far as the alarm goes idn. It was professionally done so there shoudltn have been a problem. Ya i guess i will have to get it fixed. Quote Link to post Share on other sites
superjet Posted December 31, 2007 Report Share Posted December 31, 2007 Is the LED on solid? If it is, your alarm was in valet mode. Quote Link to post Share on other sites
04ctd Posted December 31, 2007 Report Share Posted December 31, 2007 you can sometimes wax scratches out of plastic... but i dunno about the LCD face. FWIW, start with ~800 grit paper, then 1000, then 1200, (may try & keep it wet, maybe not possible on a D3) then metal paste wax, then regular car wax. if the scratches won't come out with 800, start over with 600. it's painful, but can be done on old plastic radio faces, like when we had removable faces, and they always got scratched real bad. Quote Link to post Share on other sites
knight20 Posted December 31, 2007 Report Share Posted December 31, 2007 From the post, the scratch is on the screen itself. You do not want to sand any kind of screen, unless you wanna strain your eyes trying to look at a fuzzy picture. Quote Link to post Share on other sites
04ctd Posted December 31, 2007 Report Share Posted December 31, 2007 From the post, the scratch is on the screen itself. You do not want to sand any kind of screen, unless you wanna strain your eyes trying to look at a fuzzy picture. yeah, but you can do wonders it's basically "wet sanding" the plastic. the old plastic faces would come 100% clear like polishing yellow headlites. it would give it a try before i popped 300 bones for a new screen. cheaper get a new unit at that price point & new warranty, Quote Link to post Share on other sites
elgordo12 Posted December 31, 2007 Report Share Posted December 31, 2007 Try to use rubbing compound, there are two kinds. Buy both (red & green) (Turtle wax) You can get them in any auto part. First rub on the red like wax, and work it on, then use the green one to smooth it out. I use this on ipod’s, cellphones, wrist-watches, headlights. Quote Link to post Share on other sites
04ctd Posted January 1, 2008 Report Share Posted January 1, 2008 Try to use rubbing compound, there are two kinds. Buy both (red & green)(Turtle wax) You can get them in any auto part. First rub on the red like wax, and work it on, then use the green one to smooth it out. I use this on ipod’s, cellphones, wrist-watches, headlights. yep. use the rubbing compound between the metal paste & the regular car wax. you are basically just going from rough to smooth to fine to silky smooth. Quote Link to post Share on other sites
proto24 Posted January 3, 2008 Author Report Share Posted January 3, 2008 the rubbing compound did not work and im afraid to wet sand it Quote Link to post Share on other sites
HiFiSi Posted January 3, 2008 Report Share Posted January 3, 2008 Wet sanding is pretty much going to ruin the screen. It might get the scratch out, but the only way to get the wet sanding marks off the screen would be to polish it. Unfortunately, and LCD screen isn't meant to have a glossy finish on it, which is what you'd probably end up with if you went to town on it with some plastic polish. And even if you found some way to get the sanding marks off of it and get it back to the matte-like finish it originally had, I doubt it's ever going to look quite right. I know it sucks, but you're probably going to have to get the screen replaced, man. Quote Link to post Share on other sites
