b1n2fra Posted April 9, 2008 Report Share Posted April 9, 2008 the navigation finds my location but never puts me on the street. Its always to the left or to the right of the street. i turn it turns but never puts me on the street . any help. Quote Link to post Share on other sites
Julius Posted April 9, 2008 Report Share Posted April 9, 2008 Is the vss wire hooked up? Quote Link to post Share on other sites
whtcrxghst Posted April 9, 2008 Report Share Posted April 9, 2008 And where is the antenna? Quote Link to post Share on other sites
b1n2fra Posted April 9, 2008 Author Report Share Posted April 9, 2008 the antenna is on the dash with the little black peice under it. The vss wire is not hooked up. What exactly does the vss wire do for the system. Quote Link to post Share on other sites
Julius Posted April 9, 2008 Report Share Posted April 9, 2008 It tracks the position of the car. Quote Link to post Share on other sites
b1n2fra Posted April 11, 2008 Author Report Share Posted April 11, 2008 In the wire harness what is the pink wire for. Is this the vss wire. Quote Link to post Share on other sites
countertorque Posted April 11, 2008 Report Share Posted April 11, 2008 I think the VSS wire supplies speed input to the navigation unit. I don't think it reports the position of the car. That's what the GPS does. The symptom you describe matches what my unit does when it is not getting good GPS reception. When it's not getting a fix, it will use whatever other information it has (speed, accelerometers, I'm not sure what else) to estimate what it thinks is happening. This is called "dead reckoning." It's not nearly as accurate and it gets worse the longer you go without a fix. The unit does not need VSS input if it has solid info from GPS. Can you tell us how many orange satellites you are getting if you go to Menu -> Settings -> Hardware Settings -> Connection status? Quote Link to post Share on other sites
b1n2fra Posted April 12, 2008 Author Report Share Posted April 12, 2008 I have afew friends and people I know of that never hook up the vss/speed wire and the nav works great. I have all the satellites and my position is right where I am but not on the street. I tried to fix my position and that worked for min untill I made a few turns. I know the maps aren't 100% acurate and other nav systems put you on the street if its off a lil bit. The street names doesnt even come up so I cant really use the navigation. Quote Link to post Share on other sites
b1n2fra Posted April 12, 2008 Author Report Share Posted April 12, 2008 Please help. Would a hard reset fix this and if so how do I perform one and if I did that would it erase my firmware updates Quote Link to post Share on other sites
jwq Posted April 12, 2008 Report Share Posted April 12, 2008 I think the VSS wire supplies speed input to the navigation unit. I don't think it reports the position of the car. That's what the GPS does. The symptom you describe matches what my unit does when it is not getting good GPS reception. When it's not getting a fix, it will use whatever other information it has (speed, accelerometers, I'm not sure what else) to estimate what it thinks is happening. This is called "dead reckoning." It's not nearly as accurate and it gets worse the longer you go without a fix. Actually, the dead reckoning is pretty accurate but it requires the Vss. This gives information on distance travelled, and is actually more accurate, and quite a lot faster, then the GPS. You'll notice the map updates in the display will be a lot smoother with the Vss.... So, in short, hook up your Vss! Quote Link to post Share on other sites
b1n2fra Posted April 12, 2008 Author Report Share Posted April 12, 2008 which wire is it. is it the pink one that says something about speed. And still dont understand how is this gonna put me on the street. i have all satellites lit up, so how is it dead reconing. Quote Link to post Share on other sites
jwq Posted April 12, 2008 Report Share Posted April 12, 2008 which wire is it. is it the pink one that says something about speed. And still dont understand how is this gonna put me on the street. i have all satellites lit up, so how is it dead reconing. GPS info will get you accurate to around 5 meters at best, and it's only updated every couple of seconds.... That's quite a margin for error looking at streets.... Quote Link to post Share on other sites
b1n2fra Posted April 12, 2008 Author Report Share Posted April 12, 2008 Which wire is the vss wire in the power harness. Im still not understanding how is this wire gonna fix my location the map. Im not ahead or behind where im susposed to be, im either to the right or the left of the road. Sometimes like when im on an e-way its so far left it shows me on the opposite side of the eway. Quote Link to post Share on other sites
jwq Posted April 12, 2008 Report Share Posted April 12, 2008 Which wire is the vss wire in the power harness. Im still not understanding how is this wire gonna fix my location the map. Im not ahead or behind where im susposed to be, im either to the right or the left of the road. Sometimes like when im on an e-way its so far left it shows me on the opposite side of the eway. check click:installation manual , page 10 & 11. It's for the HD3, but the Z2 is the same... Quote Link to post Share on other sites
bigred Posted April 13, 2008 Report Share Posted April 13, 2008 check your position/tilt mount setting in the unit. if the unit thinks its mounted at an angle to the road its on, when it is actually mounted straight on, it will throw off the GPS Quote Link to post Share on other sites
