Nikemike Posted June 11, 2008 Report Share Posted June 11, 2008 Alrighty, i have another question. Im gonna order my D3 tomorow, but i need to know what else im gonna need. most imporantly what i need to make it look flush in my dash. i drive an 06 charger, and my radio has two little halfmoon outcropings where the voluming and tuning nobs are. what kind of kit am i going to need to make the D3 look smooth? http://media.automotive.com/evox/stilll ... 4sa/57.jpg Pic for refrence. Thx in advance Quote Link to post Share on other sites
HiFiSi Posted June 11, 2008 Report Share Posted June 11, 2008 Only the Chargers equipped with the factory nav system will have an opening tall enough for a double DIN unit... If you look at the mounting kit for that opening, http://retailer.installationexcellence.com/productfeatures.aspx?retailerid=1944&productid=2470&sid=0D5CBDFD-D41E-409E-88DC-D7B320842933&vehicleid=215306 you'll see that with the single DIN opening, there's only enough room left for a short pocket underneath. I think you would either have to find a trim panel from a charger that has the taller opening for the nav unit or you'll have to go with a custom trim panel... Here's the kit for the 06 Charger with factory the nav unit, which specifies it will work with a double DIN unit: http://retailer.installationexcellence.com/productfeatures.aspx?retailerid=1944&productid=8567&sid=0D5CBDFD-D41E-409E-88DC-D7B320842933&vehicleid=215306 Quote Link to post Share on other sites
Nikemike Posted June 11, 2008 Author Report Share Posted June 11, 2008 Dam. i was afraid of that. so, what do you think im looking at? do i need a major modifaction to alter the size of my center dash? or is there some way that this is just gona pop out and be able to slide a new one in? Quote Link to post Share on other sites
HiFiSi Posted June 11, 2008 Report Share Posted June 11, 2008 Like I said, you can pop out that silver trim panel and replace it with the one made for the Charger with factory nav and you will be able to use that second mounting kit and not have to do any custom work. I'm sure it's a less expensive (and easier) route depending on how much you can find that trim panel for. Quote Link to post Share on other sites
Nikemike Posted June 11, 2008 Author Report Share Posted June 11, 2008 ahhh i see, well, once again, thank you very much Quote Link to post Share on other sites
TwlVoltz Posted June 11, 2008 Report Share Posted June 11, 2008 new panel runs about $100 from the dealer Quote Link to post Share on other sites
superjet Posted June 11, 2008 Report Share Posted June 11, 2008 Order the it online, just get the part # from the dealer. Quote Link to post Share on other sites
