Tomaszek_22 Posted July 9, 2008 Report Share Posted July 9, 2008 I had my Z2 for 6 months now and everything worked fine with the bypass and everything. Today all the sudden it wont start up. It just stays on a black screen saying that my navigation is loading......... and nothing happens after that for more even after 20 min. I tryed to restart it but still no result. The button works to filp up the display to remove the cd but thats it. PLEASE HELP!!!!!!! Quote Link to post Share on other sites
skicrave Posted July 9, 2008 Report Share Posted July 9, 2008 Click here Quote Link to post Share on other sites
bobclevenger Posted July 17, 2008 Report Share Posted July 17, 2008 My Z2 has been locking up upon bootup. I downloaded the update firmware and burned it to a CDR. I put the CDR in the Z2 and it started the update process; the process continued; it copied 92 files. The screen then said that the update had failed and that it was restarting. It repeats the "failed, restarting" message as long as it is powered up. Disc in, disc out --- no difference. Power down and power back up --- no difference. Any ideas? Quote Link to post Share on other sites
disputecobalt Posted July 27, 2008 Report Share Posted July 27, 2008 the same thing has happened to me, i followed the instructions on the pioneer website exactly and now its doing what yours is. If you find out a solution can you send me a pm on how to fix it, im gunna call pioneer on monday. Quote Link to post Share on other sites
GOLDCYLON Posted July 29, 2008 Report Share Posted July 29, 2008 Click here Quote Link to post Share on other sites
bobclevenger Posted July 29, 2008 Report Share Posted July 29, 2008 Goldcylon, please look two posts above yours. We have already followed that link, and also the directions posted there. The problem seems to be that if your AVIC Z2 (or Z1) is failing to boot up it won't finish the upgrade. Just leaving the CDR in the drive will cause your unit to be ready to finish the upgradewhen it finally IS ready to boot. This seems to be temperature related; it is more likely to boot up when the entire car is cool. Quote Link to post Share on other sites
GnatGoSplat Posted July 29, 2008 Report Share Posted July 29, 2008 I had both these problems when I first got my Z2. I had the first problem as soon as I received it. I had the second problem with the endless update loop after I tried to update it in an effort to fix the first problem, and it failed at 99%. The solution was to enter Service Mode... search the forum for the instructions on that. Then go into the System Update menu options and tell it to update the firmware or flash from your CD. When this completes, your AVIC should be fine. Unfortunately, I don't remember the exact text of the menu options, but I hope you can figure it out with my vague description. If you really need exact menu option text and keystrokes, let me know and I'll walk you through it, but I'm hoping you can figure it out. Quote Link to post Share on other sites
bobclevenger Posted July 29, 2008 Report Share Posted July 29, 2008 Sounds a little different. I had no way to get into service mode. There were no menus and the only buttons that would respond were the volume and track buttons. No menus and no way to get into them. I had to wait until the unit was cool enough to actually finish booting. It is working fine now. Quote Link to post Share on other sites
kyzmyss Posted August 7, 2008 Report Share Posted August 7, 2008 My Z2 has been locking up upon bootup. I downloaded the update firmware and burned it to a CDR. I put the CDR in the Z2 and it started the update process; the process continued; it copied 92 files. The screen then said that the update had failed and that it was restarting. It repeats the "failed, restarting" message as long as it is powered up. Disc in, disc out --- no difference. Power down and power back up --- no difference. Any ideas? Same thing happened to me. Pioneer said it was a normal incorrect error message. He said to wait an hour or two which I did not have. I left the disc in and drove to work. It constantly kept cycyling saying "failed, restarting". Finally, after about 15 minutes, it downloaded one more item from the disc. I believe when it is restarting, it is checking the 92 files it downloaded...could be wrong, but I waited, and now it works fine. FYI. Kris Quote Link to post Share on other sites
djkrugger Posted September 16, 2008 Report Share Posted September 16, 2008 I had that problem (unable to update due to non boot)i forced write in service mode, but when i did so i noticed that version was something like 3.000** i know latest is platform:2.000500 hdd app: 2.140000! now when i reset the unit it says:"THERE IS NO APPLICABLE PROGRAM" , the unit is a Z2 sept 07. i went to service mode and it says: PLATFORM [2.000500] RECOVERY [2.000000] BOOTLORDER [2.000000] CPU CORE[00000004] APL PROGRAM[uNKNOW] GPS PROGRAM[1.200000]. now notice that apl program is unknow, my question is does anybody know how can i get the apl? is in the pioneer test disk? Quote Link to post Share on other sites
GnatGoSplat Posted September 16, 2008 Report Share Posted September 16, 2008 3.000 is Z3, it looks like you tried overwriting Z3 software with Z2 software. The APL should be on the Pioneer Z2 update, since the rest of your programs are already downgraded to Z2, you might as well try the Z2 APL. You can also try toggling the update source to HDD and see if you can update back to a Z3. Otherwise, cheapest thing to do is to download the Z3 image and Acronis True Image, then unlock your drive, copy Z3 image to it, then reinstall. Another option is to buy an update drive. Quote Link to post Share on other sites
djkrugger Posted September 16, 2008 Report Share Posted September 16, 2008 Ok now i understand, the unit is not mine, seems that the owner tried to update with a z3 version and that's why it didn't start at first! guess that my best choice is to remove the hdd and do it in a PC. Quote Link to post Share on other sites
djkrugger Posted October 6, 2008 Report Share Posted October 6, 2008 OK, i did the z3 mod and it worked like a charm!, just one detail to remark is that i never needed to unlock the drive! Maybe if you remove the battery and the ignition power together it won't lock-up? worth trying. Quote Link to post Share on other sites
garrettoomey Posted October 6, 2008 Report Share Posted October 6, 2008 OK, i did the z3 mod and it worked like a charm!, just one detail to remark is that i never needed to unlock the drive! Maybe if you remove the battery and the ignition power together it won't lock-up? worth trying. I have yanked the drive with the Z booted up, and the drive is still locked... Quote Link to post Share on other sites
dvcobra Posted October 8, 2008 Report Share Posted October 8, 2008 My unit has froze up during startup several times and my Library starts shifting songs and playing half way throught some then starts skipping and wont stop. If I do this upgrade will this upgrade effect the 2 wire Bypass that I have done? Quote Link to post Share on other sites
