deekae Posted July 31, 2008 Report Share Posted July 31, 2008 Hey guys just found about this cool forum and I previously had the avic-n1 for the past 4 years. I would of had a few less headaches had I known before. Anyways, I just installed the 700bt into my 2003 audi a4 and had a few questions that i couldn't find searching. 1. Is there a mute "button" to lower the music volume? 2. I have a Pioneer XDV-P90 6 disc DVD changer. I read on the forum that CD changers do not work, but what about DVD changers? 3. I hooked up the ILL wire correctly but at night the map looks the same. Thanks guys. I will post up pics when all finished! Quote Link to post Share on other sites
dericn Posted July 31, 2008 Report Share Posted July 31, 2008 1.) If you press and hold the volume knob it will mute, but since it takes a few seconds to mute, I find it much easier to just turn the volume down/off... 2.) I don't know, but I highly doubt it 3.) This one confused me at first too. Adjust the illumination level while you have your lights ON. It will remember that setting -Eric Quote Link to post Share on other sites
terron Posted July 31, 2008 Report Share Posted July 31, 2008 There is a mute button option amongst one of the wiring harnesses; try rigging a switch up and see if it works Your DVD changer should work provided that it can use IPBUS; call Pioneer and confirm with them for sure. You'll have to sacrafice AV1 to the IPBUS unfortunately Quote Link to post Share on other sites
HiFiSi Posted July 31, 2008 Report Share Posted July 31, 2008 If you hold down the volume button it mutes the source, i think. Just pushing it activates the voice commands, but if you hold it down, it mutes. From what I remember, there are no disk (CD or DVD) changers that work with the F-series units. The day/night map colors are automatically changed by the time of day. The illumination wire only switches between the two different brightness settings for the screen. Quote Link to post Share on other sites
