termn8er Posted August 28, 2008 Report Share Posted August 28, 2008 Just wanted to get input on some charges I was quoted to install: Z2, XM and BT and steering wheel kit to use my existing controlls. With the car kit they are quoting $450. Does this sound in the ball park? Thanks Quote Link to post Share on other sites
NickyD32 Posted August 28, 2008 Report Share Posted August 28, 2008 that's about the range... at CC we charge about 200 for P/L on double-din, another 50 or so apiece on XM/BT, and b/t 75 and 100 for steering wheel controls... so that plus taxes is about 450. Quote Link to post Share on other sites
superjet Posted August 28, 2008 Report Share Posted August 28, 2008 What kind of car? Do you already own the steering wheel control module? Quote Link to post Share on other sites
termn8er Posted August 28, 2008 Author Report Share Posted August 28, 2008 It is a Hyundia Azera. The steering column has controls, so the $450 includes the module to continue to use them. Quote Link to post Share on other sites
NickyD32 Posted August 28, 2008 Report Share Posted August 28, 2008 yeah i'd say its a good price... does that have a factory amp that needs to be bypassed? Quote Link to post Share on other sites
superjet Posted August 28, 2008 Report Share Posted August 28, 2008 Sounds about right, be sure to ask about the dimmer wire, vss wire and if they are willing to do the bypass. Quote Link to post Share on other sites
termn8er Posted August 29, 2008 Author Report Share Posted August 29, 2008 "Sounds about right, be sure to ask about the dimmer wire, vss wire and if they are willing to do the bypass." I know they mentioned the dimmer wire and VSS wire. Are these related to the bypass? Also, I just recieved my Z3 updated drive. Is the bypass possible via hack? I got it from Toomey from this board. Thanks for all the input. Quote Link to post Share on other sites
garrettoomey Posted August 29, 2008 Report Share Posted August 29, 2008 The dimmer and VSS have nothing to do with the bypass. You will need to ask about it specifically. Print the bottom of this link and take it with you: (courtesy of Ducatiboy) http://www.sminntech.com/z1flash.html#newbypass Quote Link to post Share on other sites
termn8er Posted August 29, 2008 Author Report Share Posted August 29, 2008 Thanks and by the way, thanks for the extemely quick turnaround of the new drive. I can't wait to get everything installed! I will post again, once I do the upgrade. Quote Link to post Share on other sites
superjet Posted August 29, 2008 Report Share Posted August 29, 2008 Sorry, I should have been a little more specific. Ask them if they will be hooking up the dimmer wire and the vss wire. Often times installers will skip these two things. VSS can be difficult to find at times, and some installers like to claim the dimmer wire fries things in cars when hooked up, which is totally untrue. A lot of shops will only hook up the brake wire correctly, for liability reasons. Quote Link to post Share on other sites
termn8er Posted August 29, 2008 Author Report Share Posted August 29, 2008 So I know they mention the VSS wire having to do with the Nav ability to truly determine how you are traveling etc. So my question is, how to I confirm they have installed the VSS and Dimmer wires? I trust them, but I just want to make sure, since these are important and I am paying for them. Thanks Quote Link to post Share on other sites
slab42 Posted August 30, 2008 Report Share Posted August 30, 2008 Yeah $450 sounds on par for that. Ask them before hand to make sure they hook up VSS, reverse and illumination (not dimmer). When they try and tell you you don't need them, tell them that you want it done anyway. Then when they are done, go into the connection status menu and verify they are all connected Quote Link to post Share on other sites
