rock99rock Posted October 15, 2008 Report Share Posted October 15, 2008 What program do you open "navigatemap_800_480.ui" in to modify? i tried notepad but it was mostly unrecognizable characters. Thanks! Quote Link to post Share on other sites
BorisM Posted October 15, 2008 Report Share Posted October 15, 2008 It should open in Notepad just fine (it is a straight text file). I usually edit it in EditPlus, but I do have a license for it... Quote Link to post Share on other sites
BorisM Posted October 15, 2008 Report Share Posted October 15, 2008 since the data file is already big enough here some code to change the compass button into a navigation cancel button. ; have fun, bt Thinking about it, there's on need to define the compass twice, and have iGO keep track of navigating thу route for yet another model. You could have just one compass, and in onRelease have code like this: onRelease='runif navigation.HasRoute 1 sc_CheckAndDelete' and then code sc_CheckAndDelete in navigatemap.ui to be something like runif navigation.HasRoute sc_btnARM_Delete_OnRelease This might be a bit cleaner approach, because it does not force iGO to keep track of yet another model... Ypoiu probably could even have it in the onrelease code itself, but I can't check it right now becasue IPAQ emulator I use has different model (for some reason they make different builds for different manufacturers with some chnages ot core functionality...) Quote Link to post Share on other sites
beratta Posted October 31, 2008 Report Share Posted October 31, 2008 it works great!! Quote Link to post Share on other sites
WeApOn Posted November 15, 2008 Report Share Posted November 15, 2008 I'm using the linear compass mod.. I suppose I may have to alter the code a bit to get this to work? Quote Link to post Share on other sites
Bman69 Posted November 17, 2008 Report Share Posted November 17, 2008 well if your using keepers data zip with that linear compass mod then he tells how to change the delete route button To make the compass the stop nav button in my data zip you need to change the following line in navigatemap_800_480.ui ;Stop Nav Button with this ;Stop Nav Button Quote Link to post Share on other sites
WeApOn Posted November 22, 2008 Report Share Posted November 22, 2008 I'm not using that ZIP file. Just using the linear compass mod, so I would think it might be a different button name on there. Gonna try to experiment. Quote Link to post Share on other sites
V2A2 Posted January 30, 2009 Report Share Posted January 30, 2009 I just spent the better part of 15 minutes thumbing thru the file directory looking for the "navigatemap_800_480.ui" file. Can anyone give a quick hint where the file is located? Quote Link to post Share on other sites
dumpystig Posted January 30, 2009 Report Share Posted January 30, 2009 DATA.zip > ui_pioneer > 800_480 > ui > navigatemap_800_480 Quote Link to post Share on other sites
S4 Posted February 13, 2009 Report Share Posted February 13, 2009 Thinking about it, there's on need to define the compass twice, and have iGO keep track of navigating thу route for yet another model. You could have just one compass, and in onRelease have code like this: onRelease='runif navigation.HasRoute 1 sc_CheckAndDelete' and then code sc_CheckAndDelete in navigatemap.ui to be something like runif navigation.HasRoute sc_btnARM_Delete_OnRelease This might be a bit cleaner approach, because it does not force iGO to keep track of yet another model... Ypoiu probably could even have it in the onrelease code itself, but I can't check it right now becasue IPAQ emulator I use has different model (for some reason they make different builds for different manufacturers with some chnages ot core functionality...) Did you end up trying this? Or anyone else? Quote Link to post Share on other sites
BorisM Posted February 13, 2009 Report Share Posted February 13, 2009 Thinking about it, there's on need to define the compass twice, and have iGO keep track of navigating thу route for yet another model. You could have just one compass, and in onRelease have code like this: onRelease='runif navigation.HasRoute 1 sc_CheckAndDelete' and then code sc_CheckAndDelete in navigatemap.ui to be something like runif navigation.HasRoute sc_btnARM_Delete_OnRelease This might be a bit cleaner approach, because it does not force iGO to keep track of yet another model... Ypoiu probably could even have it in the onrelease code itself, but I can't check it right now becasue IPAQ emulator I use has different model (for some reason they make different builds for different manufacturers with some chnages ot core functionality...) Did you end up trying this? Or anyone else? No... it's been too cold to run to the car to check out mods Quote Link to post Share on other sites
nguyenphananh Posted March 7, 2009 Report Share Posted March 7, 2009 Hi Im new to this forum. Really interested in doing this mod. Please let me know if I did it right: So I unzipp the DATA.ZIP, then pull up and open that file, then add in these 2 lines, then REZIPP the DATA file, then recopy this new DATA.ZIP file back into the flash(replace the original DATA.ZIP) ?? Im doing it correct?? I did this and nothing change, no cancel button in the compass. Can someone please point me out where I did wrong?? Thank yyou Quote Link to post Share on other sites
dumpystig Posted March 7, 2009 Report Share Posted March 7, 2009 Open DATA.zip > ui.pioneer > 800_480 > ui. > navigatemap800_480 That's where you will find the text you need to edit Quote Link to post Share on other sites
nguyenphananh Posted March 7, 2009 Report Share Posted March 7, 2009 Open DATA.zip > ui.pioneer > 800_480 > ui. > navigatemap800_480 That's where you will find the text you need to edit Hi I need to clarify... so after added these lines, I have to ZIP THE WHOLE DATA file, then copy the whole thing back to the flash?? Quote Link to post Share on other sites
nguyenphananh Posted March 8, 2009 Report Share Posted March 8, 2009 I added these line and copied DATA.ZIP back to the flash... the message "The system is start up, please wait" stuck on the screen and wouldnt go away.... only put the origin DATA.ZIP file back would fix this... I tried many times and it didnt help. I only modd these navigate 800 480 ui, replaced the EZRIDER, add the license file (IGO..something...), but did not replace other files... could this be the problem?? please help me... Im so frustrate at this. BTW, my unit is 500BT. Anybody from the los angeles or orange county area? please let me know... Thank you Thank you in advance Quote Link to post Share on other sites
