beven6 Posted October 17, 2008 Report Share Posted October 17, 2008 ok so i spend the day installing the avic z2, everything went well except for the fact that the ipod cable that i had bought does not seem to read my ipod, has anyone had any issues with this or could help me out. also i did the 2-wire bypass and i get all the features now but for some reason its not reading the maps, its stuck on my current location and does not want to tell me where i am at, i did not download the files and was wondering if that could be the issue. could it be that i never spliced into the vss wire?? and one last problem is that my service engine soon light had come on after the instal.. any idea of why it might have come on. Thanks Quote Link to post Share on other sites
MPTonyT Posted October 17, 2008 Report Share Posted October 17, 2008 What ipod adapter are you using? if your not using the CD-IB100II then thats your issue. The high speed cable from the D3 will not work with the Z2/3. What vehicle is it installed in? YMM? what all did you have to remove / disconnect to get the factory radio out? Did you connect the GPS antenna? if not that is why its not updating also if you dont have good satellite reception then you need to relocate it. You can check thins in the harware screen. Quote Link to post Share on other sites
beven6 Posted October 17, 2008 Author Report Share Posted October 17, 2008 i installed it in my 2006 350Z, i just went to best buy and picked up the pioneer ipod cable for pioneer that fits into the port in the back of the radio it has 3 square corners and then one curved corner which if i remember correctly.. fits into that bus port. it just doesnt want to even connect my ipod to the radio.. the cable does nothing I am going to try and move the antenna because i believe that might be the issue with it Quote Link to post Share on other sites
garrettoomey Posted October 17, 2008 Report Share Posted October 17, 2008 You have the wrong ipod cable. You need CD-IB100II, as MPTonyT has stated above. The correct unit will have a small box that will plug into the Z and also require power and ground. Quote Link to post Share on other sites
MPTonyT Posted October 17, 2008 Report Share Posted October 17, 2008 Also to add to waht Garrett said you will need to search the infiniti forum. I know theres a way to reset the service engine soon light by cycling the ignition. my co worker did it on my bosses G35 a few days ago. Not sure exactly what he did though. Quote Link to post Share on other sites
beven6 Posted October 17, 2008 Author Report Share Posted October 17, 2008 well i went up to best buy today since my buddy use to work there and they gave me the cd-Ib100II but i need to get the ip-bus cable, which i was wondering who sells that, and do i need to use the power supply spot on it? since this is the older version for the ipod im a little confused with it. So they just gave me the black box. they also took care of my check engine light, they just cleared the code, but if it comes back up ill just take it to a dealer since its still under warranty. Quote Link to post Share on other sites
NickyD32 Posted October 17, 2008 Report Share Posted October 17, 2008 the ib100II is connected just as you said... its 3 square corners and one rounded... there *should* be a cable that comes with it that is identical on both ends... plug one into each end, obviously. then, you have to run power (yellow) and ground (blk).. and it should work. and also your service engine light may have come on if you disconnected something with the airbags... a plug or something like that. i dont know how the 350z is, but it could be your problem. and VSS really isn't necessary. it just tracks your speed when you lose GPS signal. so yeah relocate your antenna. i find it works better OUTSIDE the car, not the ghetto dash mount. Quote Link to post Share on other sites
beven6 Posted October 17, 2008 Author Report Share Posted October 17, 2008 what do you mean.. the people at best buy just gave me that black box with the ipod connecting wire that comes out of it, i have to get the other cables for it, i know i need the ip-bus cable but not sure where to get it from but do i also need the power supply cable as well? Quote Link to post Share on other sites
ryan420 Posted October 17, 2008 Report Share Posted October 17, 2008 1)ipbus cable 2)power cable 3)black box w/ipod cable Quote Link to post Share on other sites
beven6 Posted October 18, 2008 Author Report Share Posted October 18, 2008 ok im new to all this, and it was my first radio i have installed. where would i get the first 2 at, besides online.. radio shack? Quote Link to post Share on other sites
MPTonyT Posted October 18, 2008 Report Share Posted October 18, 2008 Your local car stereo shop should have them. But they should have came with them. If they didnt give them to you you need to go back and demand the rest of the parts. Its not fair to you to try and track down these parts. Speed Sense BLUE (AC) AT A/C AMPLIFIER UNDER RADIO IN DASH ALSO VIOLET OR WHITE/GREEN AT PASSENGER SEAT HARNESS You will want to hook up VSS or the Nav will be blotchy and the arrow will jump every time the Sat antenna pings the satellite. I have my antenna mounted in the dash on the little metal square that came with it. the only thing on top of it plastic NO METAL wich works great for me. I have installed about 200 NAV units and never had a problem mounting it there. SAT Radio is a little more touchy though. Quote Link to post Share on other sites
beven6 Posted October 18, 2008 Author Report Share Posted October 18, 2008 well they gave me it for free, and just told me i needed to get the wires so im not really complaining. the arrow is not jumpy at all but if i ever does then i will end up tapping into the vss also early today i burned those files to a disc using nero software from a pc as an image and put it in and it took a minute and then when i clicked on maps it said the maps have already been updated, so i reset it and it worked for about 10 minutes and then locked me out again, should i try re-burning it? you guys have been very helpful.. thanks a lot!!! Quote Link to post Share on other sites
VBLUE42 Posted October 18, 2008 Report Share Posted October 18, 2008 You should be able to find the other cables you need on ebay if you cant source them anywhere else. Quote Link to post Share on other sites
beven6 Posted October 18, 2008 Author Report Share Posted October 18, 2008 ok so i picked up everything i need for the ipod adaptor, where do i tap the yellow wire into, the wire harness? i know i ground the black one but unsure what to do with the yellow? Quote Link to post Share on other sites
MPTonyT Posted October 19, 2008 Report Share Posted October 19, 2008 connect the yellow to the yellow on the back of the unit. You should be good to go. Also.... be sure the IP Bus cable is plugged into the "out" port on the black box. Quote Link to post Share on other sites
