jmoe316 Posted October 29, 2008 Report Share Posted October 29, 2008 I hope there's some major improvements with V2.0. I don't think it would be as simple as copying back over the data.zip after the update because there may be some new stuff in the data.zip that is needed. Is it pretty much a given that all mods will have to be redone after V2.0? Quote Link to post Share on other sites
Vorian Posted October 29, 2008 Report Share Posted October 29, 2008 Only one way to find out! Quote Link to post Share on other sites
paradroid Posted October 29, 2008 Report Share Posted October 29, 2008 most mods are cosmetic , just BU the modded files and put them back after the upgrade Quote Link to post Share on other sites
lava10t2 Posted October 29, 2008 Report Share Posted October 29, 2008 That is if testmode isn't locked out... Quote Link to post Share on other sites
BorisM Posted October 29, 2008 Report Share Posted October 29, 2008 Update includes a new DATA.ZIP, which at least appears to be cleaned up, compared to what they released originally -- UI files are not replicated outside of UI subfolders. Of course this time morons added thumbs.db to the archive, but еоршы will be easy to fix. Quote Link to post Share on other sites
Vorian Posted October 29, 2008 Report Share Posted October 29, 2008 Can anyone test to see if you can make changes to the DATA.ZIP in the new update BEFORE doing the actual update? I'm curious to see if their update does a checksum to verify the DATA.ZIP. Quote Link to post Share on other sites
flyboyindy Posted October 29, 2008 Report Share Posted October 29, 2008 And the answer is YES! You can still boot up your unit in Test Mode with the 2.0 upgrade! Just finished updating, replaced my image.res, data.zip, and map color files, and everything works GREAT! Just thought you all would like to know! Quote Link to post Share on other sites
lemonhead Posted October 30, 2008 Report Share Posted October 30, 2008 I upgraded, went back into testmode and replaced the new unmodded data.zip with my modded one. Worked fine. Quote Link to post Share on other sites
rv7flyer Posted November 9, 2008 Report Share Posted November 9, 2008 I replaced my modded data file after the update and now I get "system starting up" screen all the time. Had to put the 2.0 data.zip back in. Bummer. I would like to go back to all my modded files over a faster avic. Quote Link to post Share on other sites
