brian8pie Posted October 12, 2006 Report Share Posted October 12, 2006 How hard/easy will it be to install a Z1 on my 06 Grand Cherokee without factory navigation?? Any help will be greatly appreciated! Quote Link to post Share on other sites
DJ Machismo Posted October 12, 2006 Report Share Posted October 12, 2006 As long as there is a Double DIN opening for the radio, you should be more than fine. -Litos Quote Link to post Share on other sites
sportsfan21 Posted October 12, 2006 Report Share Posted October 12, 2006 Just make sure you actually have a double din opening. I dont know about the 06 models, but I know that in the past, a lot of Jeeps had 1 3/4" DIN openings, not double din openings. Go to Crutchfield.com and put your model car in. They are really good about what fits in what car. Quote Link to post Share on other sites
brian8pie Posted October 12, 2006 Author Report Share Posted October 12, 2006 Even if it is a Din and a half could i still make it work? Quote Link to post Share on other sites
sportsfan21 Posted October 12, 2006 Report Share Posted October 12, 2006 You [i]could[/i] but it would take modification of the dashboard. Quote Link to post Share on other sites
cntrylvr79 Posted October 13, 2006 Report Share Posted October 13, 2006 The only hard part will be making the z1 fit. You will have to modify the dash that surrounds the radio. The stock radio is a little big smaller and has those stupid bumps on the side. It's nothing a bit of work can't fix for you though. Quote Link to post Share on other sites
ashil Posted October 18, 2006 Report Share Posted October 18, 2006 I installed a AVIC D2 in my jeep G.C. and had to get the dash modifed, you can get a bezel from jeep that will fit it. I had all the work done at a local audio place for $200 Quote Link to post Share on other sites
equinn2823 Posted October 26, 2006 Report Share Posted October 26, 2006 you can get a new bezel from any jeep dealer that will work for the factory nav system and metra makes a kit to fit a double din radio in this opening. your jeep has a din and a half size radio. the z1 is double din and jeeps rec nav unit is bigger than double din. the bezel is less than a 100 and the kit about 30. Quote Link to post Share on other sites
