Joculardude1 Posted October 25, 2006 Report Share Posted October 25, 2006 Just FYI, at night the screen is really bright and when driving slow everyone can see you. A good way to stop that is making the screen black or turn off. the screen turns off but the system is still on. To do this just hold down the [v] button for five seconds and it turns off. to turn it on just tap the screen. I havent read anything on this and thought it would be helpful!! 8) Quote Link to post Share on other sites
sportsfan21 Posted October 25, 2006 Report Share Posted October 25, 2006 Or you can set the dimmer and it will dim at night so its not that bad 8) Quote Link to post Share on other sites
Wireless King Posted October 25, 2006 Report Share Posted October 25, 2006 [quote name="sportsfan21"]Or you can set the dimmer and it will dim at night so its not that bad 8)[/quote] How would you set it to do that automatically? Thanks! Quote Link to post Share on other sites
ducatiboy Posted October 25, 2006 Report Share Posted October 25, 2006 Hit MENU, then the MAP tab and press the DAY/NIGHT DISPLAY till it's automatic. From the manual page 49: 1 Touch [Map] in the navigation menu. 2 Touch [Day/Night Display] to change the setting. Each time you touch the key changes that setting. Automatic*: You can change the colors of a map between daytime and nighttime according to whether the vehicle lights are On or Off. Day: The map is always displayed with daytime colors. ❒ To use this function with [Automatic], the Orange/white lead of the navigation system must be connected correctly. Quote Link to post Share on other sites
Wireless King Posted October 25, 2006 Report Share Posted October 25, 2006 Thanks DB, You'd Da Man! Quote Link to post Share on other sites
