Easty Posted June 9, 2009 Report Share Posted June 9, 2009 I just noticed that the warning is still there when the unit is booting. It is NOT there after that. I guess it runs another program during boot that also needs to be modified. //Tomi B. There is more of this text in the video EXE file. Quote Link to post Share on other sites
tk421 Posted June 9, 2009 Report Share Posted June 9, 2009 I just noticed that the warning is still there when the unit is booting. It is NOT there after that. I guess it runs another program during boot that also needs to be modified. //Tomi B. There is more of this text in the video EXE file. What line is this text found? (it's still in the av.exe file?) I searched for it, but couldn't find another spot where it was. Quote Link to post Share on other sites
ggarcez Posted June 9, 2009 Report Share Posted June 9, 2009 Excellent Work!!!! Now we can install another video AUX without the need of changing the Av source in the AV Setup... Regards GUGA Quote Link to post Share on other sites
Jfinley0 Posted June 9, 2009 Report Share Posted June 9, 2009 I tried it and the reverse image still comes on. Did I miss something? The image is not as dark as before. Sorry, didn't quite catch that. Do you mean that you can still see the image from the camera or the "CAUTION: IMAGE MAY APPEAR REVERSED" text at the top of the screen? You'll currently still get the text during boot up. It seems the text is also in another file which is active while the unit is starting up. //Tomi B. Thanks. It does go away after it is done booting. Great Job! Quote Link to post Share on other sites
Easty Posted June 10, 2009 Report Share Posted June 10, 2009 I just noticed that the warning is still there when the unit is booting. It is NOT there after that. I guess it runs another program during boot that also needs to be modified. //Tomi B. There is more of this text in the video EXE file. What line is this text found? (it's still in the av.exe file?) I searched for it, but couldn't find another spot where it was. It's around 06ba0 i replaced the caractors with spaces just like in the Av exe and the message is totally gone now even on boot up here is the file. Video.zip Quote Link to post Share on other sites
PassiveJJ Posted June 10, 2009 Report Share Posted June 10, 2009 Would this modified file would work to remove the message on the F700BT? Has anyone tried it? Should be the same file right?? Quote Link to post Share on other sites
tk421 Posted June 10, 2009 Report Share Posted June 10, 2009 Would this modified file would work to remove the message on the F700BT? Has anyone tried it? Should be the same file right?? I have done this on my 700bt and it works perfectly. Just make sure to back up your original av.exe file! Quote Link to post Share on other sites
keithmaestas Posted September 26, 2009 Report Share Posted September 26, 2009 Is there a way for me to do this on a 900bt? I tried copying the av file posted, but no luck. Quote Link to post Share on other sites
whoopidoo2 Posted September 27, 2009 Report Share Posted September 27, 2009 I keep getting that the av.zip file is corrupt. I've tried on two boxes, opening the zip with winzip and winrar. Just me? Quote Link to post Share on other sites
docBliny Posted September 27, 2009 Author Report Share Posted September 27, 2009 I keep getting that the av.zip file is corrupt. I've tried on two boxes, opening the zip with winzip and winrar. Just me? I think the recommended Zip program has been 7zip to avoid these types of problems. //TB Quote Link to post Share on other sites
whoopidoo2 Posted September 27, 2009 Report Share Posted September 27, 2009 7-Zip is failing as well, and I've tried now on 3 machines. The video.zip I'm not having a problem with, just the av.zip. Thoughts? Quote Link to post Share on other sites
whoopidoo2 Posted September 30, 2009 Report Share Posted September 30, 2009 Can someone that is able to download this av.zip file and open it successfully email or PM it to me? I had a couple of colleagues at work try also, and the file is still showing corrupt. Thank you. Quote Link to post Share on other sites
datapaal Posted September 30, 2009 Report Share Posted September 30, 2009 the Zip file is corrupt Quote Link to post Share on other sites
whoopidoo2 Posted October 2, 2009 Report Share Posted October 2, 2009 Still begging for file if anyone has it since the download is corrupt. Quote Link to post Share on other sites
dericn Posted October 13, 2009 Report Share Posted October 13, 2009 Here's a RAR file containing both the Av.exe and Video.exe files. These files are ones I edited myself from the 3.0 update currently installed on my F700. I do NOT know if they will work on other models (but they should) MAKE SURE YOU HAVE A BACKUP OF YOUR ORIGINAL FILES IN CASE YOU NEED TO RESTORE! Unrar them (use WinRAR) and place both on your SD card (along with the testmode folder) Boot with the SD card and copy both files to the APL directory on My Flash Disk Remove SD card and reboot Many thanks to Tomi B. for discovering this, and Easty for finding the duplicate in Video.exe!... -Eric Av_Video.rar Quote Link to post Share on other sites
