BrianF Posted July 23, 2009 Report Share Posted July 23, 2009 Strange, i have done the update and everyting is perfect, mutch faster etc. but on the screen (see pictures) i see Pioneer navigation software 2009 but on device info i see V2.001000 , must be 3.0 i think, and mapversion 2.000400 but i have the newer maps.What can be the reason for that? Hi Etienne, The reason is that there are a couple of text (HTM) files that contain the version information in the root of your flash, if you change them for the ones in the Ver 3 download fron The pioneer site your version number will then be correct. Quote Link to post Share on other sites
etienne22 Posted July 23, 2009 Report Share Posted July 23, 2009 @BrianF Thanks it's ok now Quote Link to post Share on other sites
bitman Posted July 23, 2009 Report Share Posted July 23, 2009 Is it possible to copy the files to a sd card, so that the unit will do the update from 2.0 to 3.0 automaticly? So it would be very usefull to know the directory structure of the official update SD cards. Perhaps its quite simple to create a sd card from the 3.01 update files on pioneers website which will update all except the Igo 8.3 & maps. Second step is to know the update routines, so that we will be able to build a second navigation update SD card... just my 2 cents Christian still F900 V2.0x EU... why create an automatic system as it is actually only updating WinCE and then deleting APL, DATA & ALP2 and then copy new APL, DATA & APL2 on the deck... Quote Link to post Share on other sites
bitman Posted July 23, 2009 Report Share Posted July 23, 2009 Strange, i have done the update and everyting is perfect, mutch faster etc. but on the screen (see pictures) i see Pioneer navigation software 2009 but on device info i see V2.001000 , must be 3.0 i think, and mapversion 2.000400 but i have the newer maps.What can be the reason for that? Hi Etienne, The reason is that there are a couple of text (HTM) files that contain the version information in the root of your flash, if you change them for the ones in the Ver 3 download fron The pioneer site your version number will then be correct. and guess what, i have those files on my web site for download Quote Link to post Share on other sites
lays526 Posted July 23, 2009 Report Share Posted July 23, 2009 i just wanted to say that it works like a charm dankje wel meester backupper der nederlanden. zal morgen kijken of de nieuwe weg bij ekkersrijt al bekend is Quote Link to post Share on other sites
manulolo Posted July 23, 2009 Report Share Posted July 23, 2009 Completed update to version 3.010100 (EU). Some things: -To avoid the problem of versions, you must copy the html files, but there are two that are not anywhere (well, I guess downloading the U.S. version, if there are), and the file is LPUE080DATA.HTM and LPUE080DATA.VER but do not have the greatest importance, I have changed manually with the following: Navigation Data Release Record 2009 title> head> [2009 Navigation Data Release Record] Product: AVIC-F500BT/AVIC-F700BT/AVIC-F900BT 20090420 10:00 File Release: DATA Release Version: 2.000100 20090420 pre> body> html> DATA folder v3, I have downloaded from here: http://www.bit4net.com/files/avic/newst ... 3/DATA.zip (bitman thank you very much;) Although it is not necessary if you do not want change. To the point, my impressions: First configuration: - APL V3.010100 - APL2 version of 2.07 (more EZRIDER.EXE hacked license) - Maps 2009 The speed increase is very noticeable when you press, no longer occur breaks track (this was for me the most important) in mp3 VBR. Second and current configuration: - APL V3.010100 - APL2 version of 3.010100 (igo 8.3) from here ftp://www.turboss.com/f900bt/EUf900bt - Maps 2008 The initial start was slow, successive times was correct. My feeling is that the navigator is slightly slower than before. But it goes perfect. I noticed two main things: first, that the maps are considerably older than the first configuration, tested with practical examples. The second, now put the file in the folder speedcam.txt Speedcam, radars are inserted alone, no need to make any mod as before. I am investigating that now I have to change lines in sys.txt, to see the horizon, and have greater inclination 3D is enough to add 3d_max_tiltlevel = 9000? Or is it also necessary to add the default option, like this? defaulttilt3d = 8300 For me this would be enough for now, by the way I see it all right. Thank you all for your support. Quote Link to post Share on other sites
etienne22 Posted July 24, 2009 Report Share Posted July 24, 2009 The maps in the update we have here are they the newest teleatlasmaps at the moment? I see 2008.10 but there are already 2009.02 maps Quote Link to post Share on other sites
manulolo Posted July 24, 2009 Report Share Posted July 24, 2009 No, not the newest, is the next step, they can use the 2009 maps, but are not compatible with igo of 8.3, we have to use the igo of 8.3 maps to be out there own igo, if there are. Find the maps is easy, the problem is the license and do not know if that will hack the ezrider.exe. Quote Link to post Share on other sites
avic_weo Posted July 24, 2009 Report Share Posted July 24, 2009 guyz, just a question: did anyone notice there are actually 2 data.zip in the APL2 folder I posted? I was browsing through my unit and found this out. One is in \My Flash Disk\APL2\iGo, and the other one is one level below, in CONTENT. Of course this could have to do with an old mod I did in 2.x, because there is an info.txt inside with a reference to Yuri theme. But I just wanted to make sure... Weo Quote Link to post Share on other sites
etienne22 Posted July 24, 2009 Report Share Posted July 24, 2009 No, not the newest, is the next step, they can use the 2009 maps, but are not compatible with igo of 8.3, we have to use the igo of 8.3 maps to be out there own igo, if there are. Find the maps is easy, the problem is the license and do not know if that will hack the ezrider.exe. I found the newest EUR maps 2009.02 for iGo 8.3 on another forum. With firmware 2.0 and iGo 8.0 it was possible to install the newest maps. Now it is not more possible? Quote Link to post Share on other sites
manulolo Posted July 24, 2009 Report Share Posted July 24, 2009 I also found maps 090424 for "igo 8.3" and license files. When I try, I tell you, the penalty is that I can not try them until maybe next Monday. Greetings. Quote Link to post Share on other sites
StephWRX Posted July 24, 2009 Report Share Posted July 24, 2009 You need to have a "hacked" ezrider file to use other licence files we have it for the IGO 8.0 but not for the 8.3 for the moment... Quote Link to post Share on other sites
gallois Posted July 24, 2009 Report Share Posted July 24, 2009 guyz, just a question: did anyone notice there are actually 2 data.zip in the APL2 folder I posted? I was browsing through my unit and found this out. One is in \My Flash Disk\APL2\iGo, and the other one is one level below, in CONTENT. Of course this could have to do with an old mod I did in 2.x, because there is an info.txt inside with a reference to Yuri theme. But I just wanted to make sure... Weo I was going to ask do we need to replace the data.zip with the V3 version. There is a link to it here http://www.bit4net.com/files/avic/newst ... 3/DATA.zip The only reason is that there seems to be a mixture of key beep sounds. One quite harsh on the menu screen and a much nicer softer beep for navigation screen and internal menus. Is this correct or should it be all just the new soft sound? Quote Link to post Share on other sites
gallois Posted July 24, 2009 Report Share Posted July 24, 2009 There is only one data.zip folder in the official F710 update, in the APL2 folder. It's also considerably larger (more sounds and fodlers) than the one that I linked to earlier, so not sure if that one is ok to use. Quote Link to post Share on other sites
gallois Posted July 24, 2009 Report Share Posted July 24, 2009 Can confirm you don't need the data.zip in the nested folder. There are two sets of 'data' data.zip and another folder called data in the root. The annoying beeps are in that folder, but you can replace them really easily. Just look in your new data.zip from the update and copy them across then replace the ones you don't like. I now have nice soft button sounds all around! Quote Link to post Share on other sites
Join the conversation
