hanibal Posted August 21, 2009 Report Share Posted August 21, 2009 come on can we get a proper answer? Quote Link to post Share on other sites
stan-the-man Posted August 24, 2009 Report Share Posted August 24, 2009 I got mine to work Just one question : is it possible to simulate the route or anything? I would like to change few things in direction/distance color but cant see those due to not having gps signal Quote Link to post Share on other sites
BorisM Posted August 24, 2009 Report Share Posted August 24, 2009 I got mine to work Just one question : is it possible to simulate the route or anything? I would like to change few things in direction/distance color but cant see those due to not having gps signal  Sure. Pick a point, set it as start (I think default skin would ask something about turning off GPS tracking). Pick another point, set it as destination. Then go into Route menu and hit Simulate. Quote Link to post Share on other sites
stan-the-man Posted August 24, 2009 Report Share Posted August 24, 2009 You are legend Boris!!!! Works perfect, now I can mess around without going to the car everytime Awesome!!! Quote Link to post Share on other sites
jr_00_22 Posted August 24, 2009 Report Share Posted August 24, 2009 For those still having problems or getting errors try using the World License, Hacked 3.01 ezrider, and new map that is found here viewtopic.php?f=34&t=26742&p=184021&hilit= place them in the correct place and it should work (it did for me). Quote Link to post Share on other sites
BorisM Posted August 24, 2009 Report Share Posted August 24, 2009 You are legend Boris!!!! Works perfect, now I can mess around without going to the car everytime Awesome!!! Â You're quite welcome! Quote Link to post Share on other sites
stan-the-man Posted August 24, 2009 Report Share Posted August 24, 2009 For those still having problems or getting errors try using the World License, Hacked 3.01 ezrider, and new map that is found here viewtopic.php?f=34&t=26742&p=184021&hilit= place them in the correct place and it should work (it did for me). Â /\that's right. I used hacked ezrider with the license that works on my unit with new map and I also switched the language file to English. Otherwise you will have menu in Ukrainian language Quote Link to post Share on other sites
diaftia Posted August 24, 2009 Report Share Posted August 24, 2009 For those still having problems or getting errors try using the World License, Hacked 3.01 ezrider, and new map that is found here viewtopic.php?f=34&t=26742&p=184021&hilit= place them in the correct place and it should work (it did for me). Â The same files for (ezrider, license and map data) did not work in my emulator. When I put them into my NAV they worked fine. I cannot seem to change the data.zip or maps in the emulator. I can get the original data.zip to work flawlessly but nothing other than that. If I put my mods in the emulator the screen starts and immediately crashes. I wish this would work as it would save me a CRAP load of trips out to the car to test. I need to do more digging I just have not had the time to mess with it in the short term. Quote Link to post Share on other sites
stan-the-man Posted August 25, 2009 Report Share Posted August 25, 2009 diaftia- Mine didn't work (was crashing etc) because I forgot that I added another font which I forgot to copy over together with my data.zip. Make sure all the additional files that you had used in your custom data.zip are also copied over. As Boris mentioned earlier use only one map with the emulator (the one you know worked fine in your unit for example together with ezrider, and license file) Quote Link to post Share on other sites
jr_00_22 Posted August 26, 2009 Report Share Posted August 26, 2009 For those still having problems or getting errors try using the World License, Hacked 3.01 ezrider, and new map that is found here viewtopic.php?f=34&t=26742&p=184021&hilit= place them in the correct place and it should work (it did for me). Â The same files for (ezrider, license and map data) did not work in my emulator. When I put them into my NAV they worked fine. I cannot seem to change the data.zip or maps in the emulator. I can get the original data.zip to work flawlessly but nothing other than that. If I put my mods in the emulator the screen starts and immediately crashes. I wish this would work as it would save me a CRAP load of trips out to the car to test. I need to do more digging I just have not had the time to mess with it in the short term. Â did you delete the license that was already in content/license? if you did that is where you went wrong. Did you use the base map to run emulation? if you did this is where you went wrong. it does not like basemap. Pass that how far are you getting before crash? Quote Link to post Share on other sites
jr_00_22 Posted August 27, 2009 Report Share Posted August 27, 2009 Here is the complete 3.x emulator I am using (with instructions). It has a texas map and english lang. Download and Mod away  http://rapidshare.com/files/271970819/Avic_Emulator.zip.html Quote Link to post Share on other sites
diaftia Posted August 27, 2009 Report Share Posted August 27, 2009 did you delete the license that was already in content/license? if you did that is where you went wrong. Did you use the base map to run emulation? if you did this is where you went wrong. it does not like basemap. Pass that how far are you getting before crash? Â This did it! I think I removed the original license as well as possibly copying over the basemap file. This is going to make testing SOOOO much easier. Quote Link to post Share on other sites
vansmack2 Posted August 27, 2009 Report Share Posted August 27, 2009 Here is the complete 3.x emulator I am using (with instructions). It has a texas map and english lang. Download and Mod away  http://rapidshare.com/files/271970819/Avic_Emulator.zip.html   Thanks for the upload I will try it out. Quote Link to post Share on other sites
diaftia Posted August 27, 2009 Report Share Posted August 27, 2009 Do you guys know how to get it to default to the Map when it loads? Mine is defaulting to the destination menu and its hard to get over to the map. Quote Link to post Share on other sites
marco899 Posted September 4, 2009 Report Share Posted September 4, 2009 Thanks guys, got it running. Quote Link to post Share on other sites
