eldeep Posted November 17, 2009 Report Share Posted November 17, 2009 I have tried to add voices Loquendo in Spanish but don't workCan anyone help me? Have same problem,, tried everything, replaced various vesrsions, complete reinstall,, no avail,, Finally installed "normal" non tts voices and works perfectly,, you can find them on this forum,, If anybody has succeeded (Spanish TTS) plseadvice us how to,, Thanks Quote Link to post Share on other sites
BorisM Posted November 17, 2009 Author Report Share Posted November 17, 2009 I have tried to add voices Loquendo in Spanish but don't workCan anyone help me? Have same problem,, tried everything, replaced various vesrsions, complete reinstall,, no avail,, Finally installed "normal" non tts voices and works perfectly,, you can find them on this forum,, If anybody has succeeded (Spanish TTS) plseadvice us how to,, Thanks Doesn't AVIC's build of iGO use RealSpeak (Nuance) voices, not Loquendo's. It is probably missing DLLs required to use Loquendo ones... Quote Link to post Share on other sites
eldeep Posted November 18, 2009 Report Share Posted November 18, 2009 Hi Boris,, Thank for the answer,, problem with Spanish is that is seems that there is no Spanish realspeak voice available (have US unit and this comes with weird mexican voice, and this one (and the us voices) work well),, searched on this forum and many others,, For my units (have 2 F500) no problem,, but I have friends who dont speak a word English,, If someone can post the realspeak part ("scansoft" directory) from a EW unit,, sure this would have Spanish voice included,, until now didnt find nothing,, Thanks again,, Quote Link to post Share on other sites
BorisM Posted November 18, 2009 Author Report Share Posted November 18, 2009 Hi Boris,, Thank for the answer,, problem with Spanish is that is seems that there is no Spanish realspeak voice available (have US unit and this comes with weird mexican voice, and this one (and the us voices) work well),, searched on this forum and many others,, For my units (have 2 F500) no problem,, but I have friends who dont speak a word English,, If someone can post the realspeak part ("scansoft" directory) from a EW unit,, sure this would have Spanish voice included,, until now didnt find nothing,, Thanks again,, You're welcome. Don't have a European unit, but I'm sure somebody here would have it... Quote Link to post Share on other sites
ill.die.trying Posted December 13, 2009 Report Share Posted December 13, 2009 got a quick questions to users using this mod, does the album art still show when using this mod? Quote Link to post Share on other sites
amigo Posted December 18, 2009 Report Share Posted December 18, 2009 Hello. I have a pionner F900BT and use the last lexa skin (GJ6.9.2p_800x480) and commonlib. All right. I want to ask if I can use newer skin (eg GJ6.14.p_da) and if so how. Thanks. Quote Link to post Share on other sites
amigo Posted February 4, 2010 Report Share Posted February 4, 2010 Ultimately it is so difficult to be done? Quote Link to post Share on other sites
xdanx Posted February 19, 2010 Report Share Posted February 19, 2010 I was able to get this mod working but I can't to remove the girl in front of the car and the car image is position to the right of the road instead of the center. Can someone help me??? Quote Link to post Share on other sites
eldeep Posted February 22, 2010 Report Share Posted February 22, 2010 Hi Xdanx,, Search in sys.txt for female.mdl and change it to another one that you can find in GFX folder,, (speedbike,, sportscar,, chopper or whatever),, Good luck,, Quote Link to post Share on other sites
ca229872 Posted August 14, 2010 Report Share Posted August 14, 2010 Hi bsharp8, I'm having the same problem that you had when I try to acccess MSNDIRECT, - the same error message comes up. How exactly did you solve the msndirect problem? I did read the posts, but I can't begin to figure out "It looks like an original data.zip file!!! Make sure, that you are correctly has been installed skin into content\skin folder" - what that means, or what it suggests I do. Any help would be so appreciated! thank you, ic 1. You may not to rename skin. The skin name must be "GJ6.9.2p_800x480.zip" 2. You must put it into content\skin folder 3. if you are use an european device, download the file sys.txt from this post and put it into IGO`s root directory, if your version is US.... i don`t know what to do, it will be better to ask it from anybody, who uses an american device There is a new version of skin. Now it`s possible to disable not used parts of the screen behind lateral buttons, top and the bottom bars from MAIN MENU - SETTINGS (pioneer map size) Hello, I´m from Spanish. I don´t speak english very well. I´ve download this files ("GJ6.9.2p_800x480.zip") and sys.txt but I need a data.zip. Thanks from Spain Quote Link to post Share on other sites
