bulldawg3111 Posted November 14, 2006 Report Share Posted November 14, 2006 I just got a new N2 and I am trying to do the bypass. However I do not see the silver sticker to peel on the back of the headunit. I have removed the cage and the only thing I see uner the cage is a silver metal plate that can be removed with two screws. I removed this silver metal plate, but the only thing that is under it is a ribbon cord, not the R197 pins. This silver metal plate is at the very front of the head unit under the cage. Could someone please post a picture of the entire head unit and the silver sticker. I saw some of the other pictures of the R197 pins but they are so zoomed in that I cannot tell their location relative to the headunit. Thanks for any help. Quote Link to post Share on other sites
PaisanNYC Posted November 14, 2006 Report Share Posted November 14, 2006 This is a pic of the N3, but the sticker is in the same spot on both units Quote Link to post Share on other sites
bulldawg3111 Posted November 14, 2006 Author Report Share Posted November 14, 2006 Can you take a picture that is zoomed out so I can see the relative location on the unit. Or can you try and explain the exact location of the sticker on the unit. Thanks Quote Link to post Share on other sites
whtcrxghst Posted November 14, 2006 Report Share Posted November 14, 2006 Ummm, Its right above the big white sticker that says PIONEER on the bottom of the head unit Quote Link to post Share on other sites
PaisanNYC Posted November 14, 2006 Report Share Posted November 14, 2006 Ummm, Its right above the big white sticker that says PIONEER on the bottom of the head unitLOLOL! I thought the picture might have given this insight Quote Link to post Share on other sites
bulldawg3111 Posted November 15, 2006 Author Report Share Posted November 15, 2006 Well I guess my unit does not have the sticker or hole for the R197 pins. I have a factory refurbished unit. It is any chance thay may have put a different metal casing around the head unit? Does the N1, N2, and N3 all have this hole for the R197 pins? I wil get a digital cam later and take a picture of the bottom of my unit. This will really be a wrench if I can't bypass the unit. Quote Link to post Share on other sites
PaisanNYC Posted November 15, 2006 Report Share Posted November 15, 2006 Does the N1, N2, and N3 all have this hole for the R197 pins? Yes. The N3, though, does not have the pins, rather Pioneer made it much easier and simply put a flip switch underneath the sticker Quote Link to post Share on other sites
bulldawg3111 Posted November 16, 2006 Author Report Share Posted November 16, 2006 Here is a pic of the bottom of my n2. They metal cage has been removed. So where is the silver sticker? Quote Link to post Share on other sites
cntrylvr79 Posted November 16, 2006 Report Share Posted November 16, 2006 Have you tried peeling back either of the 2 stickers in the red squares? Quote Link to post Share on other sites
bulldawg3111 Posted November 16, 2006 Author Report Share Posted November 16, 2006 No, the R197 pins are not under either of those stickers. There is a hole hidden under the Pioneer sticker on the right but it is not shaped like the hole from previous pictures that I have seen on the forum, and I don't see R197 pins in this hole. Help?????????? Quote Link to post Share on other sites
madmanfrommars Posted November 20, 2006 Report Share Posted November 20, 2006 Off topic, where did you get the reconditioned avic? Quote Link to post Share on other sites
robtse Posted December 3, 2006 Report Share Posted December 3, 2006 take your index finger and feel the top part of the pioneer sticker on the right. if u feel a opening bigger thena screw then bingo. Quote Link to post Share on other sites
Termist Posted December 4, 2006 Report Share Posted December 4, 2006 I believe recondition units have N1 cases to prevent from easy-access tampering. Probably have to do what N1 guys do, and disassemble everything to get to the mainboard. Quote Link to post Share on other sites
antonio010 Posted December 8, 2006 Report Share Posted December 8, 2006 My refurbished unit looked just like that. If I recall correctly the sticker was on the other side. It was plain white though, did not have VOID all over it. Quote Link to post Share on other sites
