Daylight Savings Issue
Sometimes playing around with the time zones and auto correct will give you the right time but after a couple weeks it may switch again. it seems as though the software doesnt realize that day light savings ended this weekend but it SHOULD recognize the change in the next few weeks. this was an error that pioneer corrected but if you do not have the new software you will still experience the bug.
  • 3 months later...
I am having problems with this also. I have the 3.0 update and even if I change time zones it changes back in a few minutes. Also, the clock on the map is different from the clock on the radio. The map is whatever timezone I set it to (for a few minutes anyway) and the radio is always the same time as "auto correction on" which is an hour ahead. Has anyone figured out how to fix this?
when your changing your time zones, do you have auto correction turned OFF?
  • 3 weeks later...
Since Sunday I am having the problem that my arrival time seems to be one hour later than the actual arrival time should be. Time it gets from the GPS looks OK, also time displayed on map (right hand upper corner Diaftia skin) is correct. (Timezone =GMT+1)
Any ideas? More people experiencing this?
