b3soul Posted March 24, 2011 Report Share Posted March 24, 2011 Hello! Im attempting the 2 wire bypass on my z2. I burned the iso file to a cd using cyberlink biting software. When I insert the cd in the drive it says cd rom inserted but nothing happens. I pushed map and it just went to the map screen. My hardware screen indicates my ebrake wire is grounded because it says "on". I copied the file back from my disc to the computer successfully so I assume the burn was ok. Am I doing something wrong. How do I get this z2bypass file to update my unit?? Thanks Quote Link to post Share on other sites
b3soul Posted March 24, 2011 Author Report Share Posted March 24, 2011 Oops burning software not biting. Hahah Quote Link to post Share on other sites
willbest Posted June 28, 2011 Report Share Posted June 28, 2011 Hello! Im attempting the 2 wire bypass on my z2. I burned the iso file to a cd using cyberlink biting software. When I insert the cd in the drive it says cd rom inserted but nothing happens. I pushed map and it just went to the map screen. My hardware screen indicates my ebrake wire is grounded because it says "on". I copied the file back from my disc to the computer successfully so I assume the burn was ok. Am I doing something wrong. How do I get this z2bypass file to update my unit?? Thanks In order to bypass my unit, I used a guide to change the pin outs on the harnesses, thus causing a permanent ground loop to avoid the e-brake hassle. I don't know of any cd image that would help, or why you would want one? Quote Link to post Share on other sites
garrettoomey Posted June 28, 2011 Report Share Posted June 28, 2011 In order to bypass my unit, I used a guide to change the pin outs on the harnesses, thus causing a permanent ground loop to avoid the e-brake hassle. I don't know of any cd image that would help, or why you would want one? The CD image is for early model Z2's. The 2 wire did not work without a firmware upgrade. Just FYI... Quote Link to post Share on other sites
